Old 04-11-2011, 06:08 AM   #5581
Pit-racer's Avatar
I would definitely go with the LiFe rx packs. The biggest I can find in a hump pack is LiFe 6.6V 1700mAh. They do make a 2100mAh but not in hump. You can get yours at igthobbies.
www.igthobbies.com / Serpent Eryx 3.0 / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 Red
Pit-racer is offline   Reply With Quote
Old 04-11-2011, 06:15 AM   #5582
Maximo's Avatar
if you guys are looking for a real banger on a budget we now have the Argus A52's in stock....These are made in the same factory as the D Alpha engines.... 2.17 HP and 86 oz/in , drilled/filled crank, tungsten slug...for only $225.00
http://www.thenitroshop.com/
Maximo is offline   Reply With Quote
Old 04-11-2011, 06:45 AM   #5583
Pit-racer's Avatar
Great work there Neal. That sounds like a great buy definitely.
Old 04-11-2011, 08:22 AM   #5584
WildBillMassey's Avatar
Gotta remember with LiFe packs is if you are using High Voltage servos, you will not get full potential unless you use Lipo.
Either way, they are better than Nimh for sure. Reedy and Protek both make 1700mah LiFe packs.
Former owner of The Nitro Pit and IGT Hobbies
Now living in the Great White North.
You may think you know what you're talking about, but the only person you're fooling is yourself - Wild Bill Massey
WildBillMassey is offline   Reply With Quote
Old 04-11-2011, 09:08 AM   #5585
JLock's Avatar
Not necessarily true, WB. I have a Futaba digital for steering and Hitec analog high torque for throttle/brake and the LiFe rx pack worked fine with very little current draw. I felt I got full use/potential out of both servos during my quals and main the last SWCS race. I will let folks that want to try the LiFe pack know that you should balance charge it every time as not to jack up the per cell voltage (unbalance the pack).
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 04-11-2011, 09:30 AM   #5586
Sorry for the confusion, I was speaking about the Hitec servo's that are the 7.4v High Voltage. They need Lipo to reach their full potential, but will also work fine with the LiFe, but at a lower torque and speed rating.
Old 04-11-2011, 09:42 AM   #5587
I just built up a 2-cell Li-ion pack to try. It's 4000 mah and weighs in 20 grams lighter than Nimh.
People spend their lives worrying about death. I'm sliding in broadside h ollering "Wow, what a ride"
spooky 1 is offline   Reply With Quote
Old 04-11-2011, 10:56 AM   #5588
JLock's Avatar
I don't use HV servos. I feel that it is overkill at times. But, if you use a LiPo rx pack, I would definitely recommend using the HV servos with a receiver that can take 7.4v as to eliminate the voltage regulator and not burn up your radio gear in the car.
Texas 5
Old 04-11-2011, 12:18 PM   #5589
bassman2's Avatar
So if we use LiFe pack we'll need to have a charger that charges LiFe pack right?
Andy Liu "Flyin' Hawaiian"
2015 teams/sponsors:
Serpentamerica/Desoto Racing, Murnan Modified Motors, VP powermaster Fuel, Sweep Racing USA, Speed Passion, BUKU performance products
bassman2 is offline   Reply With Quote
Old 04-11-2011, 12:30 PM   #5590
JLock's Avatar
That is correct. I have a Hyperion charger to charge mine. Many of the new chargers on the market now give one the capability to charge LiFe batteries.
Texas 5
Old 04-11-2011, 12:38 PM   #5591
Pit-racer's Avatar
If you don't have a charger yet Bassman, you may use mine at the track to charge up, until you find the one you like. Spooky's pack sound awesome as well.
Old 04-11-2011, 12:55 PM   #5592
Most chargers (if not all) that charge Lipo can charge Life. I don't know the exact settings to do that but I've seen lots of racers charge their Life packs like that. I don't use HV servos and I use Lipo packs but since I use Spektrum brand recievers they allow me to use the Lipo without a regulator in place. I have been using this set up for years now and I haven't had any problems with any servo. This just to clarfy can be done ONLY with Spektrum brand recievers. They regulate the voltage output to the servos to 6.0V.
jneg is offline   Reply With Quote
Old 04-11-2011, 01:44 PM   #5593
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
thats sweet, i run the k.o. propo gear, the receiver can use a lipo with out regulator, but they do not regulate power, i have servo's that can hang, BUT i run LIFE wich most servo's can hang with without a reg as its 6.6 volt, or a goosed up nimh pack. VERY IMPORTANT when running LIFE packs, YOU MUST break them in, for 20 cycles at least, i've Swollen 3 packs by not taking the proper time to just keep bumping em' up, if they drop below 60% for first 20-30 cycles i believe, They CAN and WILL swell, i've done it!! expensive lesson, but i've been running them before protek got there hands on them, and they include that handy info i posted, most likely more accurate also...
Thinking on maybe a Tekno 1/8 Nitro Buggy?
TommyBlazin is offline   Reply With Quote
Old 04-11-2011, 01:52 PM   #5594
bassman2's Avatar
I have a ThunderPower 610C and it does charge LiFe batteries as well. I just called them to confirm. I'll need to set it at "A123" setting for LiFe batteries. Cool, more weight to come off my open car
Old 04-11-2011, 02:05 PM   #5595
Pit-racer's Avatar
Your gonna need some to keep it from flying away!
GT class--buggy-based on road! duneland Nitro Off-Road 5 03-20-2012 11:03 AM
JRX-S based 4wd buggy?? Why was the idea scrapped? cpatel529 Electric Off-Road 33 12-08-2007 06:19 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 1 12-26-2006 11:40 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 13 09-30-2006 10:31 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 8 03-21-2006 01:05 PM
