Old 03-31-2008, 09:46 PM   #541
regg151's Avatar
Send a message via ICQ to regg151 Send a message via AIM to regg151 Send a message via Yahoo to regg151
yea still running the savage still in full race trim. Retired the R40 at the end of last season only comes out now for fun runs.
The Boyz are still around although everyone is busy with other things life tends to do that. will pass along your message.
This season I'm going full out on the IGT looking forward to the spec class racing this year, winning comes down to setup and skill bankroll will have very lil to do with winning really levels the playing field.
If they don't get enough guys for a spec class I still have a brand new picco .26 to blast down the back straight that thing has enough power to push my savage towards the 55 MPH mark the IGT should be no problem since it's about 8 pounds lighter then the savage.
regg151 is offline   Reply With Quote
Old 04-01-2008, 10:14 AM   #542
Jspeed's Avatar
Check it out!
Here at Tampa's Hard Rock Casino the "Young Guns of the IRL will be racing the Kyosho Inferno GT cars.
Looks like they'll be some more IGT Spec racers out there soon.
Jspeed is offline   Reply With Quote
Old 04-01-2008, 01:53 PM   #543
GMartinez's Avatar
Trader Rating: 85 (100%+)
lmk where you going to race it @ I assume FBF I moved before they built the new track tell me the conditions & I will pm you a set up as for 20-22 depending on how the flow of the track more agressive turn in on power
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 04-01-2008, 02:55 PM   #544
regg151's Avatar
You got PM
Old 04-02-2008, 12:48 AM   #545
MikaR's Avatar
Originally Posted by GMartinez View Post
universals are not longer you can actually use the lightweight universals from the 777 they fit on the Gt as well as some other parts will work on it also
rods,turnbuckles,shock pistons,torque rods we tested 20 & 22 knuckles on the Gt
the difference in length between original MP7.5 front universals and the Kanai version (later 777) is not much. I think in the Kanai original uni's were installed at rear and new front uni's were used in combination with new caster blocks and front upper arms. However, these are not needed with IGT since onroad cars usually benefit less caster so the stock 17deg is fine, of course universals are an improvement, either these or the new lightweight ones. Here's a pic of the difference, however (original MP7.5 front universal on left, Kanai on the right)
I did the bearing mod for the 2-gear, it is a 6x12x4 bearing. I'm not sure if this actually improve anything
MikaR is offline   Reply With Quote
Old 04-02-2008, 11:55 AM   #546
Jspeed's Avatar
Cool mods.
The bearings in the second gear & brakes were the 1st thing I did to mine.
Old 04-02-2008, 01:30 PM   #547
YBSLOW's Avatar
Originally Posted by Jspeed View Post
Cool mods.
The first thing I did to mine was machine some Zero degree castor "C" hubs and machine a aluminum solid spool for the front.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source
POWER MASTER Fuel,
Protoform Bodies, Avid Bearings
YBSLOW is offline   Reply With Quote
Old 04-02-2008, 03:20 PM   #548
act2007's Avatar
Trader Rating: 46 (100%+)
Thumbs up
Check it out!
Jspeed, I hope you'll have video for this race!
act2007 is offline   Reply With Quote
Old 04-03-2008, 12:37 AM   #549
MikaR's Avatar
Interesting. Where did you get those caster blocks?
Solid spool sounds also good...
You know, have BBF tactyl diffs in my offroader, going to test them in my IGT in the summer, too. Do you think these advanced limited slip diffs would actually work in an onroad car? They definitely work on loose conditions.. I have the feeling guys in the south (of Europe) are using these in their rally games..though it's a bit difficult to find any good info in the web.
Old 04-03-2008, 06:15 AM   #550
YBSLOW's Avatar
YBslow will release the solid spool and zero degree "C" hubs in a few weeks.
YBSLOW Racing
POWER MASTER Fuel,
Old 04-03-2008, 07:32 AM   #551
FREELANCE_RCer's Avatar
Trader Rating: 27 (100%+)
Have you tested the aluminum spool how long will it going to last for long hour runs.
Do you plan on making steel spool too?
FREELANCE_RCer is offline   Reply With Quote
Old 04-03-2008, 08:01 AM   #552
YBSLOW's Avatar
We get about 4 gallons of gas out of the ultra-liteweight spools in the x-ray for the un-anodized ones and longer than that for the anodized ones.
The IGT spool has replaceable outdrives so all you have to do is replace the outdrives.
I will post some pics this weekend.
YBSLOW Racing
POWER MASTER Fuel,
Old 04-04-2008, 03:18 AM   #553
masterrch's Avatar
Default check these out
http://www3.towerhobbies.com/cgi-bin...&I=LXSTC4&P=SM
these look like they would work at 100mm they are only 4mm bigger
than stock and are readily availble and cheap to boot
Rich
masterrch is offline   Reply With Quote
Old 04-04-2008, 06:18 AM   #554
Jspeed's Avatar
The “Legends vs.Young Guns of IRL” event at the Hard Rock Casino was a lot of fun.
Ryan Hunter, Al Unser Jr., Arie Luyendyk Jr., Johnny Rutherford, A.J Foyt IV and
the beautiful Danica Patrick raced Kyosho Inferno GT cars against each other!
Each driver’s car was painted by Ronnie Setser to match their INDY paint schemes. They crashed, rolled, flipped, cart wheeled and kept on going strong. Several local television & radio celebrites also had the opportunity to drive the IGT cars.
In the end, they all had a great R/C experience with the Kyosho Inferno GT cars!
Old 04-04-2008, 11:13 AM   #555
MikaR's Avatar
Looking good! Our season is about to start and we have lots of drivers waiting to get their IGT's on the track.
GT class--buggy-based on road! duneland Nitro Off-Road 5 03-20-2012 11:03 AM
JRX-S based 4wd buggy?? Why was the idea scrapped? cpatel529 Electric Off-Road 33 12-08-2007 06:19 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 1 12-26-2006 11:40 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 13 09-30-2006 10:31 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 8 03-21-2006 01:05 PM
