Old 03-11-2011, 12:26 AM   #5266
Has anybody tried a Schumacher/Picco 28 in their GT car?
They're going really cheaply out of England.. I find it kind of interesting because it could work in all four of my RC's - DM1, SC8, and 2x LST2's... Would I really be losing RPM's with the Rotostart backplate though?...
-Team Associated RC8.2, RC8T CE, & SC8 with 1.) Argus A52/0801, 2.) RB Fire 11/2058 or 053, 3.) RB Blast V9/2045, 4.) Nosram RS.30RR/JP-4, & 5.) modded Nosram RS.21RR/086
-LST2 #1 with Losi 454 & LST2 #2 with Dynamite Big Red .28
-Ofna DM-1 with silver Mach 427/2047
-TT MT4 G3
Herrsavage is offline   Reply With Quote
Old 03-11-2011, 08:58 AM   #5267
Speyederjedi's Avatar
Herrsavage,
You'll probably lose a few rpm's due to the roto-start but you may be able to disengage it to add a few more revs. I did that to my stock OFNA Force .28 pull start engine. I've always used a starter box so I disengaged the pull start on that engine for a few more top-end revs. Don't know how much the spring, pin and oneway bearing with pull start hold back the revs but I'm sure there is a difference once it is disengaged. That's a nice looking Picco BTW! I have a Picco JL Team Turbo .28 that I am still breaking in. It only has about 10 tanks of fuel through it but I can tell it's gonna really pull in the mid range.
Regards,
Speyederjedi
Schumacher Mi5/Serpent Cobra GT
Novarossi Kappo Rally .21/Novarossi Kangaroo .21
Airtronics M8/Spectrum
SWEEP Tires
Speyederjedi is offline   Reply With Quote
Old 03-11-2011, 02:54 PM   #5268
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
guys i just picked up 2 sets of the aluminum optional shock sets<with pistons> kyosho for the gt2, i couldnt get the optional springs as they didnt have at the moment, question is what oil should i run front and rear, they seem to be 2 hole pistons, these are the nice upgraded aluminum shocks, i will be getting the springs this weeks as well. i was told run 2 sets of the optional NOT stock black springs on these shocks and ill be set, just no shock oil info...thinking 60 front 70 rear, w/optional black springs all the way around/ lmk...damm this gt2 climbing WAY higher in price than i wanted to, it better ne fun, or imma be pissed off to say the least...im like 1k into a ROLLER at this point!@!!!!! thanx dudes
Thinking on maybe a Tekno 1/8 Nitro Buggy?
TommyBlazin is offline   Reply With Quote
Old 03-11-2011, 03:00 PM   #5269
WildBillMassey's Avatar
I run 1000 diff oil in mine with the IGW004-8022 springs. Dialed!
Now that the temps are rising, I will go up to probably 1300 diff oil.
Former owner of The Nitro Pit and IGT Hobbies
Now living in the Great White North.
You may think you know what you're talking about, but the only person you're fooling is yourself - Wild Bill Massey
WildBillMassey is offline   Reply With Quote
Old 03-11-2011, 03:01 PM   #5270
I ran a set of those shocks for a while , and with the two hole piston I ended up running 2000wt oil. Stock front spring and other black spring rear. Didn't like how much I was having to mess with them , so I went back to the stock shock. I hope you have better luck with them. Let me know when you get them figured out and maybe I'll try mine again.
People spend their lives worrying about death. I'm sliding in broadside h ollering "Wow, what a ride"
spooky 1 is offline   Reply With Quote
Old 03-11-2011, 03:14 PM   #5271
hey bill is that with the brass pistons or regualr, and did my order ship out
Old 03-11-2011, 03:16 PM   #5272
what problems were u having exactlly/ the kyosho shocks, well on my old m3 the caps would leak if not built correctlly, but it seems u running way to heavy oil, for 2 pistomn shocks, i was things 60f and 70 r or so....what problems did u have?
and when u say 2000 weight thats like 200 weight in oil conversion? just want to make sure what yall are doing? or is it straight up 2k diff oil....what kind of problems would u be having just curious?
Old 03-11-2011, 03:51 PM   #5273
That is with the upgraded shocks using the 2-hole piston. It seems high to us off-road guys, i know, but my car got way better when I went from Kyosho 600ish fluid to 1000 diff fluid. Look at this pic, the car is moving into a corner, just off power, coming off the back straight, she is sitting level and hooked up!
Order shipped out yesterday evening.
Old 03-11-2011, 07:47 PM   #5274
1k diff fluid in the NEW shocks? with the new black springs all the way around is the setup?OR is it 1000 kyosho shock oil, wich in turn is like 100 weight oil,,,, as 600 is like 60 weight/ im assuming theres a big difference?"
Old 03-12-2011, 06:43 AM   #5275
KYOSIL1000
http://www.igthobbies.com/product_p/kyosil1000.htm
Old 03-13-2011, 06:08 AM   #5276
simplechamp's Avatar
Trader Rating: 73 (100%+)
I was always under the impression that was the case. I know I bought some HoBao shocks awhile ago, and they came with some tubes of oil rated as #300, and they were pretty thin like a 30-40wt oil from other companies. It's very likely #1000 Kyosho is pretty close to 100wt from other companies.
Some companies use wt to rate the oils, but that seems to vary from company to company so it's hard to compare them. Then others use the true standardized cts (centistokes) value to rate. I think when you see oils rated as #xxx like Kyosho and HoBao they are using the cts values.
Serpent 811Be - Jammin X2 Carbon e-GT conversion - Axial SCX10 Honcho
simplechamp is offline   Reply With Quote
Old 03-13-2011, 06:55 AM   #5277
Pit-racer's Avatar
Hope this helps a lil .... not all brands are there but you get a ballpark..
www.igthobbies.com / Serpent Eryx 3.0 / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 Red
Pit-racer is offline   Reply With Quote
Old 03-13-2011, 09:20 AM   #5278
thats what i figured, cause i ALMOSt threw losi 1k diff oil in there...LOL...i wouldnt of done that j/k ..hey how do you like the powermaster fuel, im going to make the switch myself?
btw looks to be like losi 62.5 front maybe 60 rear... or so on...
Old 03-13-2011, 05:04 PM   #5279
Pit-racer's Avatar
Thumbs up
I use Powermaster exclusively now for all my nitro cars. Now that they teamed up with The King of Fuels VP you can't go wrong.
Old 03-15-2011, 02:41 AM   #5280
Jspeed's Avatar
Check out Jojo's & Nelly Cruz's newest Ipanema Blackhawk Warrior creation.
Looking good fellas!
Jspeed is offline   Reply With Quote
GT class--buggy-based on road! duneland Nitro Off-Road 5 03-20-2012 11:03 AM
JRX-S based 4wd buggy?? Why was the idea scrapped? cpatel529 Electric Off-Road 33 12-08-2007 06:19 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 1 12-26-2006 11:40 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 13 09-30-2006 10:31 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 8 03-21-2006 01:05 PM
