Old 03-18-2008, 01:32 PM   #511
dlarry's Avatar
I purchased a Inferno GT and I cannot get it to shift. Have done several adjustments to 2 speed but does not seem to want to go into second. Any other suggestions would be appreciated.
Thank You
David Larry
Shepherd Velox V8, Serpent 411 Eryx 4.0, Novarossi, Bryons Fuel, Airtronics
dlarry is offline   Reply With Quote
Old 03-18-2008, 02:53 PM   #512
garen's Avatar
you sure it's stuck in first? it might be starting out in second gear.
bpengines-usa.com fioroni-usa.com motonica-usa.com
Airtronics Avid RC Byron Fuels VOX Engines
VMR Tires - available at http://motonica.ipower.com/store
garen is offline   Reply With Quote
Old 03-18-2008, 03:03 PM   #513
Trader Rating: 15 (100%+)
If you pull the two-speed assembly off the car and remove the second-speed spur gear you can look at the part that has the pin with some plastic around it. If that pin and plastic looks like it's got virtually no wear then indeed you may be stuck in first. If on the other hand it's got some wear then I second Garen's guess that you're in second.
I assume you've already played with adjusting the grub screw in and out that's meant for tuning early / late shifting? I've had the spring wear and had to replace it. The symptom from a worn spring seems to be early shifting...
Last idea - You should be able to hear the car shift holding it off the ground. If you go from idle to full throttle over, say, 6 seconds or so you'll hear the clutch engage and you should later hear (and feel a snap from) the second gear engagement. I think this is a better way of figuring out whether it's shifting at all then on the track...
Arboleda is offline   Reply With Quote
Old 03-18-2008, 03:08 PM   #514
Zootcapri's Avatar
Two things:
1- How is the engine running? Is it running clean and reving pretty high. The shift is harder with a tight engine that is being broken in as it won't rev to the shift point.
2- Loosen the adjustment screw. Careful though... too loose and it shifts very early and you may not notice that it did shift. At Vegas, with the big track several of us were thinking that it wasn't shifting. The truth of the matter was the speeds basically kept the tranny in second and it wasn't shifting.
Your actual mileage may vary....
Zootcapri is offline   Reply With Quote
Old 03-18-2008, 04:06 PM   #515
Jspeed's Avatar
David,
If you don't have the 15/19 clutch bell gears yet, get them. Most of the people having trouble with shifting have the 14/17 gears.
You can also talk to George & Tony about it.
Jspeed is offline   Reply With Quote
Old 03-18-2008, 04:47 PM   #516
dlarry's Avatar
Thanks for all the help. I will try it all tomorrow.
David Larry
Old 03-19-2008, 07:35 AM   #517
ESWLFSE's Avatar
Send a message via Yahoo to ESWLFSE
You may find the plastic partially worn away exposing the 2mm pin and causing inconsistent engagement. I found that installing a hard 3mm pin and trimming away the excess plastic to fully expose the pin in the contact area seems to work well.
ESWLFSE is offline   Reply With Quote
Old 03-20-2008, 08:12 PM   #518
Robert R's Avatar
I am running 14/19 with Novarossie 21 + 35 and having no luck to shift. I need to figure this out before our Las Vegas race in few weeks. I am very fast in corners but i have to get off thorttle in straight away. Do you thing going to other gears is going to help.
Robert R is offline   Reply With Quote
Old 03-21-2008, 03:54 PM   #519
Default hpi
can i run my super hpi car in this new class, its 280 or 300mm. buggies r 310mm . 18tz motor
roaddog2448 is offline   Reply With Quote
Old 03-21-2008, 04:04 PM   #520
Zootcapri's Avatar
There are several posts for rules in this thread... you may want to look at them and see if that car fits in... especially the 'buggy based chassis' part.
Old 03-21-2008, 04:05 PM   #521
Zootcapri's Avatar
What did you find out? Did you get it to shift?
Old 03-21-2008, 06:25 PM   #522
dlarry's Avatar
Will be trying it at track tomorrow. Put a new motor and entire new 2 speed. Hopefully it works tomorrow at the track. last chance to test before big race in Kissimmee.
David Larry
Old 03-23-2008, 05:35 PM   #523
JLock's Avatar
Here is my Kyosho IGT with the OFNA McLaren body on it and Zootcapri's engine installed. It has been tested and tuned on 20% nitro this time. Now, if I can get my hands on that OFNA Porsche body.
JLock is offline   Reply With Quote
Old 03-23-2008, 06:20 PM   #524
dlarry's Avatar
Here is a pic of my Inferno GT that I will be running at the US Open in Kissimmee, Florida.
David Larry
Old 03-23-2008, 07:54 PM   #525
GMartinez's Avatar
Trader Rating: 85 (100%+)
Nice Dave now I really got to wear my shades lol
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
GT class--buggy-based on road! duneland Nitro Off-Road 5 03-20-2012 11:03 AM
JRX-S based 4wd buggy?? Why was the idea scrapped? cpatel529 Electric Off-Road 33 12-08-2007 06:19 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 1 12-26-2006 11:40 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 13 09-30-2006 10:31 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 8 03-21-2006 01:05 PM
