Old 02-23-2008, 08:31 PM   #421
regg151's Avatar
Send a message via ICQ to regg151 Send a message via AIM to regg151 Send a message via Yahoo to regg151
Ohh what a crock as if they don't mark up the damn things enough they have to pass along the cost to the consumer. I like the nissan better anyway oh well another week or so and I join the IGT club.
regg151 is offline   Reply With Quote
Old 02-24-2008, 05:45 AM   #422
lil-bump's Avatar
Trader Rating: 83 (100%+)
Hello
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 02-26-2008, 04:36 PM   #423
Infiniti Tech's Avatar
Send a message via MSN to Infiniti Tech Send a message via Yahoo to Infiniti Tech
Anybody got a decent setup??
www.rcraracing.com
Infiniti Tech is offline   Reply With Quote
Old 02-26-2008, 04:50 PM   #424
garen's Avatar
I posted this setup on the Motonica GP thread a few weeks ago. This is the setup I ran at the Silverbowl in Vegas.
Here is my IGT in detail:
Tires: Medial Pro IAS Tarmac 60 shore front, 45 shore rear (car had a very slight push)
Diffs: Front 35,000 GS Oil, Rear 5,000 GS Oil
Camber: -1 front, -2 Rear
Toe: +0.5 each side front, -2 Fioroni 7.5 rear toe block and -0.5 rear Fioroni 777 Uprights
Anti-Squat: Fioroni 7.5 +2 block
Shock Position: middle hole on tower, outer hole on arms (front and rear)
Shock Piston: Fioroni dual action front and rear, groove side up
Shock Oil: 1,000 GS
Shock Springs: I used some springs I got from Taiwan…they are for Revo, they are progressive, and much stiffer than the black springs. I have been told Kyosho is making option springs. The front springs are stiffer than the rear springs, so any combo of stiff rear and stiffer front is a good start.
Rear Arm Position: inner upper hole on hub, middle hole on tower
Rear Upright position: upper hole (I think this is the normal position)
Droop: With the car sitting on 20mm blocks (Hudy blocks) 7.5mm rear (measured at the lowest point of the rear uprights), 8mm front (measured at the lowest point of the front c-hubs)
Ride Height: 10mm rear (measured at the rear of the chassis), 5mm front (measured right behind the front arms)
Engine: Radical .21 Torque
Clutch: Fioroni Twin Turbo black shoes with optional stiff springs
Clutchbell gears: 15/19
Front a/b blocks: front upper arm is in the lower hole on the tower and the matching position for the lower arm used Fioroni 7.5 arm mounts.
Steering plate: middle hole (I used Fioroni’s 7.5 plate)
Brakes: No pads used with Fioroni’s ferodo brake disc
Wheelbase: long, but I would have liked to have tried the short.
Sway Bars: Kyosho silver, 2.5mm thick F/R
Body: Aston Martin
Servos: Airtronics 358 steering, 737 throttle
My car (which I had borrowed) had the helical cut gears, which may or may not be geared for truggy. No e-clips on the car. The 2 speed is set to shift early (it would not shift at all in the first qualifier).
Team VTX gold aluminum and titanium hardware throughout for weight reduction, carbon fiber side guards for weight reduction and good looks!
I made sure the drivetrain spins free and all suspension parts are bind free
bpengines-usa.com fioroni-usa.com motonica-usa.com
Airtronics Avid RC Byron Fuels VOX Engines
VMR Tires - available at http://motonica.ipower.com/store
garen is offline   Reply With Quote
Old 02-27-2008, 08:13 AM   #425
Xray prince's Avatar
Default GT Setup With Center Diff?
Fellas the car has been around long enough now....so I kno theres a racer out there who has tried just about all the drive train configurations.........How does the car work with a center diff?.....wht would b a middle ground for pinion..spur gear is 46t..not to slow out of the hole but b able to run a 160ft straight?.was thinkin 17 or 18.....and wht diff oil for the center......been readin some say 150k up to 300k center........and I also hav a torsen diff in a 7.5 buggy....would this help in the front or rear in any way?..........thanks fellas
Xray prince is offline   Reply With Quote
Old 02-27-2008, 09:04 AM   #426
Trader Rating: 15 (100%+)
I've been considering a center diff for this upcoming season (we run them on parking lot tracks) but only because I dislike the performance and reliability of the stock 2-speed so much. If the 2-speed worked with high-torque engines I'd stick with it.
I believe that if you run 150K to 300K oil it's really not going to act like a diff at all. Rather it will act like a single-speed.
The biggest question is whether you like your rear a little loose so that you can powerslide the car or whether you want your rear planted.
If your style is to powerslide the car somewhat, a center diff won't help you and the only reason to put one in would be if you dislike the 2-speed and you just want something solid there (with 150K to 300K oil).
If on the other hand you like your rear planted then a center diff could help your cornering somewhat but you'd want to put something more like 30K oil in there. In this case I'd try 50K front, 30K center, and 10K rear.
I can't speak to the torsen diffs. I have some impressions about their purpose but I need to learn more.
Arboleda is offline   Reply With Quote
Old 02-27-2008, 10:37 AM   #427
Taylorm's Avatar
Originally Posted by Bfly View Post
I'm also intrigued by this class but kinda hesitant due to the fact I have a hell of a time finding kyosho parts without paying through the nose.
Anyone have any good links for parts and the tires?
www.gasrccar.com Lee Muse
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
Old 02-27-2008, 09:15 PM   #428
Xray Prince,
boy do I have the answer for you... I run my H7RG (car similar to the IGT)at SS Speedway in Tampa, Florida. The back straight there is approx 180ft. The last time I ran on the track I ran a single speed center diff (prior to that I had a 2-speed combination from a DM-1 & Hyper 7.) With the single single speed center diff, my lap times were just as good as some of the top drivers at the track with the stock IGT 2 speeds units. With the single speed center diff, I can adjust the car for brake bias and I feel this give the car has more braking power. I know for a fact that on smaller to medium size tracks the single speed cars can run with 2 speed cars.
This is my set up with single speed.
front diff - 50k
center diff - 100k
rear diff - 10k
Center diff and parts are from a kyosho mp777/ mp-7.5 (both cars share the same diff)
44T plastic gear from Kyosho for the center diff case, the spur gear is a direct fit to the kyosho buggy diff.
Clutch bell 15T
OS speed Vspec .21 w/ T2050 tune pipe.
Inside each diff front, center and rear I removed one of the two cross bar and two of the four smaller gears.
Around this particular track fell I could have done better with a rear diff with 7k or 5k diff oil.
If you have to use your torsen diff, install in front.
Here is a video I took of the track, so you get an idea of the size of the straight and the infield layout.
http://www.stage6.com/user/vadn1/vid...-GT-Spec-Class
You will need divx to view the video.
vadn1 is offline   Reply With Quote
Old 02-27-2008, 11:27 PM   #429
Default Single speed IGT
Vadn1 thanks for the info.......I hav read atleast 100 pages of info about the car...but no one seemed to put me at ease about the single speed.....Im going to b running at SpeedworldRaceway...medium size layout...with all the prob I hav read about the 2speed......seems like everyone would b going to single.......and most of the cars tht I hav personally seen or watched on youtube seem to shift into 2nd way early anyway....so if im going to run a 17 or 18/46 I should just b barely losing a little on the bottom wright............with a onroad.21 C5 rody mod wht clutch and clutchbell would u use?
Old 02-28-2008, 12:30 AM   #430
MikaR's Avatar
somehow it seems difficult to understand that the 2-speed is intended with the stock engine and if you want to use anything more powerful (a race .21) then the single speed (regular center diff) is the choice.
I feel that the IGT class is not only about going fastest but having fun together and hear/feel car shifting is part of this fun.
If you really want to go fast then Evolva is the option as it has the gear box you need to do so.
MikaR is offline   Reply With Quote
Old 02-28-2008, 03:13 AM   #431
Jspeed's Avatar
The Kyosho Inferno GT cars at SS Raceway in our “Spec” class race every weekend. The 2 speed works very well for us. The majority of our cars use the 15/19 clutch bell set-ups and shifting is not a problem. We have a lot of fun with them.
The cars equipped with the 14/17 gear set do seem to shift too early, but once they go to the 15/19, they're good to go.
Most of our racers are looking forward to racing our “Spec” cars at the 3rd Annual US Open Sedan Championships at Kissimmee this April.
Jspeed is offline   Reply With Quote
Old 02-28-2008, 06:17 AM   #432
Xray Prince,
I saw the pictures of the Speedworldtrack and it looks very close to the layout of SS Speedway. With that C5 mod onroad engine, I would strongly recommend you use a 15t bell if you are down on speed then change to the 16T bell or get the plastic 44T spur gear (from kyosho) . Remember you will need to get around in the infield fast, you motor will take care of the rest on the longer straight. You will have a true onroad engine in your car, it is designed to rev to the moon and then some. I used a 1/8 offroad engine, and it was having no problems keeping up with .28s with 2-speed units.
Also try the link below its to the IGT proboards, forum dedicated to the Inferno GT. There is someone there trying to make a single speed solid spool set up. Maybe you can go this route if you dont want the weight of the center diff.
http://infernogt.proboards102.com/in...lay&thread=957
Old 02-28-2008, 06:16 PM   #433
Originally Posted by vadn1 View Post
Xray Prince,
front diff - 50k
center diff - 100k
rear diff - 10k
Clutch bell 15T
Thx for the video Vadn1, I hope to get over to SS soon but it will probably be a few months. I am almost done with my DM-One though. I cannot wait.
bbunker is offline   Reply With Quote
Old 02-28-2008, 07:21 PM   #434
Let me know when you go out there, I will bring out my DM-1 as well. Just PM when you do.
Old 02-29-2008, 04:42 AM   #435
Big Jeff BBQ's Avatar
I was wondering what set up is working for your group!
I have got a IGT but not long enough to figure every thing out as far as set up goes.
Any info would help!
Jeff E
Blowin Snoke BBQ
Blowin' Smoke BBQ
Special Thanks To:
Steve Pitts
Kevin Hutchinson
Big Jeff BBQ is offline   Reply With Quote
GT class--buggy-based on road! duneland Nitro Off-Road 5 03-20-2012 11:03 AM
JRX-S based 4wd buggy?? Why was the idea scrapped? cpatel529 Electric Off-Road 33 12-08-2007 06:19 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 1 12-26-2006 11:40 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 13 09-30-2006 10:31 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 8 03-21-2006 01:05 PM
