Old 07-10-2010, 09:09 AM   #3976
BigMiles's Avatar
Originally Posted by williamw View Post
My GT electric car is based on an MP777, my GT2 is based on an ST-R chassis, 777 based. Everything important from the 7.5 based cars fits. To run either with a two speed will require some machining to make room for gear clearance. On my GT2 I also needed to move the tank forward for clutch bell clearance (I'm assuming the same would be required for the shorter chassis). The chassis is made from much better materials along with everything else.
On my Thunder Tiger I used a dremal to sink the center shaft bearings deeper into the housings so I wouldn't have to alter the pan. I shimmed the whole transmission upward 3/16 to provide space fo the 1st gear spur. Then I just got the Associated fuel tank that is taller but not as long to clear the 2-speed clutch bell.
Miles
MBX5-T/XTM 24.7, TMAXX Classic, Blitz, Rage Brushless
Thunder Tiger EB-4 S2 converted to 1/8 Super GT On Road /Picco .28
It's Alive! It's Alive!
BigMiles is offline   Reply With Quote
Old 07-10-2010, 11:08 AM   #3977
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
Originally Posted by Jspeed View Post
My "GT Open" car has the Sirio CL7R STI .21 On-Road engine.
Both .28s & .21s seem to have different advantages to them.
At Ipanema Sports GT events, you can use any header/pipe combo you want in our "Open" or "Spec" class.
so some onroad engine work well with the weight of these car because friend of mine have O.S. .21onroad and its not doing the job in his DM-1, my other friend have hyper 9 port not doing the job as well they can't keep up with my GO-7port, i like my GO but i sort of looking at the picco & nova onroad engines...kinda miss the speed of my mrx4x so im looking for opinions thanks
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
Old 07-10-2010, 11:26 AM   #3978
The DM 1 is probably a pound or more heavier than the GT2. With a bunch of money it might be possible to cut a half pound off the car. The Ipanema body alone probably weighs a couple of ounces less than the Protoform.
The new OS .25 might be the perfect compromise for the DM 1, then again the guys at Ofna all use P9 or P7 Evo Piccos.
williamw is offline   Reply With Quote
Old 07-10-2010, 02:50 PM   #3979
bobbyblaze's Avatar
i thought the DM-1 lighter than the I-GT cars...o.s. not like they use be only thing i like from o.s. is their carbs...i going to give murnan modified or clockwork a holla
Old 07-10-2010, 07:54 PM   #3980
mosaics12's Avatar
Originally Posted by *1speedy View Post
nice...would try them
kyosho inferno GT2 pro.. kyosho ultima sc.. HPI savage X.. tamiya m-05 pr
mosaics12 is offline   Reply With Quote
Old 07-10-2010, 08:32 PM   #3981
Use the torquey on-road engines like the Nova 35plus or the Flash Special. Also, make sure the gearing is correct. We used 15/19 pinion with 49/45 spurs at Homestead. We chose the 35plus for the GT Worlds. TQ by more than 4 secs and cruised to the victory. Engine performed perfect the whole event.
Desoto Racing
Novarossi America, Serpent America, TOP Engines, Matrix Racing Tires, ProCircuit, Titan/Blitz Products, Xceed Products, KO Propo, Enneti, ArrowMax
info@desotoracing.com, www.serpentamerica.com
jdesoto is offline   Reply With Quote
Old 07-11-2010, 04:49 AM   #3982
kmichael's Avatar
Very good information thanks,looking to get back into GT racing
kmichael is offline   Reply With Quote
Old 07-11-2010, 05:51 AM   #3983
MugenDrew's Avatar
Trader Rating: 28 (100%+)
35+21 TUNED is the best bang for the buck. itll put a big old smile on your face...
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 07-12-2010, 12:06 AM   #3984
FREAKAH's Avatar
Does anyone know if 777 components(diff cases, radio tray, center diff mount, etc.) will bolt on a GT2 chassis plate?
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 07-12-2010, 07:10 AM   #3985
Cool
Most plastic parts will work, including the diff cases, bulkheads and center diff mounts, but the radio tray, front support, and steering bell cranks will not work. (some guys use the 777 bell cranks, but I have not tried it. I would use the GT2 stuff).
Old 07-12-2010, 11:37 AM   #3986
bobbyblaze's Avatar
i like the Flash Special...right now i'm running 48/44 spur & 16/20 pinion ..i was thinking about going to 17/21 just to get alittle more top end speed
Old 07-12-2010, 11:41 AM   #3987
Cool
Does it make sense to spend alot more on the engine than the car itself? Just my two cents.
Old 07-12-2010, 01:10 PM   #3988
BigMiles's Avatar
I live in Long Beach, CA. I can't believe the closes DM-1 48 tooth spur gear is 40 miles away. OFNA needs to get more distributors in Los Angeles.
Miles
Old 07-12-2010, 01:20 PM   #3989
Finally!! New upgraded GT2 2-speed evolva based tranny in hand. Installing tonight. First impression tomorrow.
Ferenczy36 is offline   Reply With Quote
Old 07-12-2010, 02:30 PM   #3990
Jspeed's Avatar
If you wish to run the "IGT2" chassis length you can use the "STR" (not the STRR, its much longer) chassis with a slight mod to the spur opening and drilling 2 new holes for moving the gas tank slightly forward.
There's also a new chassis (Mika has it now!) that also allows you to use all the 777 steering bellcranks too.
I went with the STR, since the newer one was not offered yet.
You could also just use the 777 chassis you already have now, if you're creative. It would be very close to a IGT1. If the engine's location in the 777 is different and you're putting in a 2 speed, you might have to check on the center drive shaft lengths.
Jspeed is offline   Reply With Quote
GT class--buggy-based on road! duneland Nitro Off-Road 5 03-20-2012 11:03 AM
JRX-S based 4wd buggy?? Why was the idea scrapped? cpatel529 Electric Off-Road 33 12-08-2007 06:19 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 1 12-26-2006 11:40 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 13 09-30-2006 10:31 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 8 03-21-2006 01:05 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
blarks
