Old 06-26-2010, 05:54 AM   #3856
bigjez's Avatar
That new body looks good.
bigjez is offline   Reply With Quote
Old 06-26-2010, 04:22 PM   #3857
Originally Posted by -R2- View Post
Check this one out, I call it the R2 "Release"
You guys need to put that into production! Looks Fantastic.
williamw is offline   Reply With Quote
Old 06-26-2010, 05:18 PM   #3858
tbo713's Avatar
ANY GT RACERS IN THE D.C. AREA WE'RE TRYING TO SETUP A RACING CLUB IN D.C. AT R.F.K PARKING LOT SO LOOK ON THE RACERS FORUM AND RESPOND TO THE BLOG
tbo713 is offline   Reply With Quote
Old 06-26-2010, 07:31 PM   #3859
BigMiles's Avatar
Hey SNRScion, I may take you up on those shock towers. My car pushes real bad. Maybe I can take some weight off the rear with your product.
Miles
MBX5-T/XTM 24.7, TMAXX Classic, Blitz, Rage Brushless
Thunder Tiger EB-4 S2 converted to 1/8 Super GT On Road /Picco .28
It's Alive! It's Alive!
BigMiles is offline   Reply With Quote
Old 06-26-2010, 09:48 PM   #3860
Registered User
snrscion's Avatar
Trader Rating: 21 (100%+)
Send a message via AIM to snrscion Send a message via Yahoo to snrscion
Hear are some towers I made for the DM1 and Ultra GTP2 and Late Model
DM1 Front
DM1 REAR
ULTRA GTP/LATE MODEL FRONT
ULTRA GTP/LATE MODEL REAR
snrscion is offline   Reply With Quote
Old 06-27-2010, 09:32 AM   #3861
MikaR's Avatar
D**n, this looked great today on the street - found a closed end street with new tarmac, put a big smile on my face to burn some rubber there.. especially like the open rear of the body and smoke coming out when taking off..
this weekend tracks were closed due to national holiday (mid-summer you know) but hopefully soon......
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 06-27-2010, 09:49 AM   #3862
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
same here, my buddies backed out of meeting this weekend so i went to the parking lot set some cones and had a blast
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
Old 06-27-2010, 10:01 AM   #3863
bobbyblaze's Avatar
Default help!
i know this is a nitro section but i need alittle guidness from electric GT racers, i'm looking to get another car to covert to electric and there are few brands out there and i don't know which to pick so ya opinions will be taken seriously
losi
tekin
tekno
castle creation
novak
which one you recomend?
one more thing, whats the difference between 1700k, 2050k, 2200k & 2650?
thanks, Bobby
Old 06-27-2010, 10:25 AM   #3864
Raman's Avatar
Trader Rating: 56 (100%+)
Bobby,
I'll try to address what I know.
Brushless systems: Tekin vs Castle vs Novak. Tekin gets my vote. Novak is behind the game in 1/8 scale brushless systems. I prefer Tekin over Castle because it gives you the option to run sensored as well, which for on-road purposes is important. If you plan on doing offroad then go with Castle because the Tekins cooling fans bust real easy after big off road jumps.
As far as the KV for the motor. First you need to decide how many cells you want to run. 4S, 5S or 6S. It seems GTe racing is leaning towards 4S. Personally I prefer 5S, I find it to be the happy medium, you get longer run times and less heat.
Once you decide how many cells you plan on going with, you can use this chart to select the motor KV. You want to pick a motor that keeps you in the 30k - 35K rpm range.
http://www.impaktrc.com/product_info...oducts_id=3076
I went with a 1700KV system with 5 cell. Right in the centre of the RPM range. If need be, I can gear up to reach the desired top speed.
Hope this helps.
Raman is offline   Reply With Quote
Old 06-27-2010, 11:18 AM   #3865
Cool
losi
tekin
tekno
castle creation
novak
thanks, Bobby
My converted Kyosho GT has their e-conversion, fits perfectly and is holding up just fine. I put a Mamba Monster w/2200 KV motor. I'm running 4S at the moment and I'm around 35000 rpm, about in the middle of the RPM range of the motor. Temps are below 150 without cooling fans or holes cut in my Subaru body. It runs mid 40's. I have not checked the run time, but everytime I charge the batteries I have only used about 2100 mah out of 4500. These are very inexpensive hardcase Turnigy batteries from Hobby King.
Higher voltage would be nice and work better but the batteries cost quite a bit more, you really need well matched packs.
I'm not racing it so I did not see the need for the sensored motor setup from Tekin. I am also not crazy about soldering 10 gauge wire anymore, especially on a $200.00 speedo. The Tekin setup is more expensive than the Mamba. The Mamba is also very tough in this application. It drives great!
When I'm ready the 2200 KV motor and a 6S pack will put me just under 70 MPH!
Old 06-27-2010, 11:23 AM   #3866
Cool
Its time for some new tires, the GRP's are just about gone. I am going to try some Ipanema Road Stars (I run on concrete).
Old 06-27-2010, 11:29 AM   #3867
bobbyblaze's Avatar
good info guys ......i see i have my homework cut out for me
is 2speed needed for these apps?
hobby king do have great prices
Old 06-27-2010, 11:31 AM   #3868
MikaR's Avatar
Good looking Subaru, William!
Old 06-27-2010, 11:35 AM   #3869
Cool
Not for me, more complexity (brake servo needed), although it helps keep the speedo cooler. I would think a 2 speed would also have problems shifting as the batteries go down unless your are interested in speed runs. MikaR has a 2 speed setup in his.
If you want to go 100 mph, probably needed.
It's almost 100 degrees in Louisana with high humidity. I am very happy with my big electric Sube. The setup I am using was recomended by Castle, including the gear ratio, 18 /46. I have a spool instead of a center diff and run the plastic Kyosho spur with n/problems.
Old 06-27-2010, 11:36 AM   #3870
Thanks Mika! Very simple paint job, next one will be much nicer. I love rally cars!
GT class--buggy-based on road! duneland Nitro Off-Road 5 03-20-2012 11:03 AM
JRX-S based 4wd buggy?? Why was the idea scrapped? cpatel529 Electric Off-Road 33 12-08-2007 06:19 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 1 12-26-2006 11:40 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 13 09-30-2006 10:31 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 8 03-21-2006 01:05 PM
