Old 01-22-2010, 11:46 AM   #2731
Timmo's Avatar
Trader Rating: 15 (100%+)
It's getting closer and closer.I wonder if Homestead has any sample pics of the new layout??
Timmo is offline   Reply With Quote
Old 01-22-2010, 09:53 PM   #2732
Does anyone know if silencers are available for this platform. If so, does it really do anything?
I was looking at a thread for the Baja 5b and saw someone who had a dual exhaust set up with twin silencers. Looked and sounded great. Just wondering if it was possible to do something similar with this platform.
I have a Inferno GT2 BTW.
soulstice is offline   Reply With Quote
Old 01-22-2010, 10:10 PM   #2733
J-milz's Avatar
Trader Rating: 38 (100%+)
Are lipo conversions allowed at the upcomming race in Fla? Are they competitive?
J-milz is offline   Reply With Quote
Old 01-23-2010, 12:37 AM   #2734
Jspeed's Avatar
If you mean the Ipanema Sports 2010 GT World Championships event at Homestead/Miami Speedway, brushless/lipo converted cars are not racing with us. Sorry, only fuel cars this time around.
Jspeed is offline   Reply With Quote
Old 01-24-2010, 06:43 AM   #2735
Doug M's Avatar
I have been asked to post some pictures of the area where we are expanding Homestead RC Raceway. This will be pretty mundane stuff since we are in the preparation stages of getting everything ready. Anyone who has prepared race tracks before knows that proper planning and sequencing are the keys to a good race track. It will be a few weeks before we will be able to show you the total layout and how it all will come together.
Photo 1
You can look at the first picture and see the existing track layout from a satellite view. You can imagine the existing straightaway extending into the expansion area ending in a sweeper. Then there will be some as yet to be determined right and left turns leading back to the existing track just before the white line where the timing loop is located. The original straightaway length is 165 feet/50 meters, it is expected to be increased to about 280 feet which converts to about 85 meters. The original total racing line track length is 650 feet/198 meters is expected to be increased to about 950 feet which converts to about 290 meters.
Photo 2
This picture shows the expansion area for where the extended track at Homestead RC Raceway will be. The blue van is dragging concrete blocks to grind off the sharp edges of the asphalt. Later this area will be pressure cleaned to remove the sand, dust, rocks and whatever other type of debris that may be on the surface. After the area is pressure cleaned, weighted tires will be dragged to add smoothness and actually add rubber to the racing surface. All of this is being done to help reduce tire wear and increase traction. If you look closely you can see where the color of the asphalt has started to change color where the blocks have been dragged.
Photo 3
This picture shows the area where the fence and fence posts were removed. You can see that the fence post holes have been filled and smoothed. You can also see the simple rig made from 4X4ís that was made to drag the concrete blocks. Later more blocks were added to cover a larger area.In the back ground you can see the grandstand area for Homestead Miami Speedway. You can also see the blue chalet tents that will be used for the racers and mechanics pit area.
A big thank you goes out to Duncan Chin and David Duperrouzel for all their work in heading up this part of the project this past weekend.
Our intention is to make sure everyone attending The Ipanema Sports 2010 GT1/8 GT World Championship on March 19,20,21, will have a fantastic race track to compete on along with a great time and making new friends at Homestead RC Raceway facility.
Only 54 days to go!
GT class--buggy-based on road!-hrcrsatview.jpg   GT class--buggy-based on road!-23-01-10_1113.jpg   GT class--buggy-based on road!-23-01-10_1110.jpg
Doug M is offline   Reply With Quote
Old 01-24-2010, 07:48 PM   #2736
Jspeed's Avatar
Fantastic!
That's great news, a big thank you to all of ya'll at Homestead!
Old 01-25-2010, 04:54 PM   #2737
mcsquish's Avatar
Now those are great ideas on how to prep the area!
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Never argue with an idiot, they'll just drag you down to their level and beat you with experience.
Dirt Burners Racing - R.I.P. BB / Kolors by Kropy / CEFX / One Eighth Racers
mcsquish is offline   Reply With Quote
Old 01-26-2010, 05:15 AM   #2738
ALMS FAN's Avatar
looks like we will have plenty of room to max out those RPMSSSS
This is going to be a World Class Event
KYOSHO EVOLVA
NOVAROSSI ENGINES
JR Racing
KO Propo
Spektrum
ALMS FAN is offline   Reply With Quote
Old 01-29-2010, 07:17 AM   #2739
43 more days til the GT Worlds
Bubba Cola is offline   Reply With Quote
Old 01-29-2010, 09:01 AM   #2740
Default question for Doug M
I was wondering Doug, if you plan on moving the drivers stand to the new center of the track? You also said that you grind the new asphalt and drag the track with rubber tires, wondering if the rubber takes place of seal coating it? Thanks for the hard work you and your crew are doing to make this event top notch!!
bigcat17 is offline   Reply With Quote
Old 01-29-2010, 09:30 AM   #2741
Doug M's Avatar
The drivers stand will be relocated to the center of the track.
We are not dragging blocks (grinding) on new asphalt. This asphalt is very old. As asphalt ages it develops a lot of sharp edges over time so by dragging the blocks it will remove a lot of the sharp edges that create a lot of excessive tire wear.
We drag the tires to help smooth the surface even more and it will actually create a groove and improve traction. It is not necessary to seal coat the surface after these procedures although we will go ahead and do this so it will match the existing track and look a lot better in all the pictures that will be taken.
Jeff Vargas and many other driving forces are working very hard to organize an event to insure the racers will have fond memories of for many years to come whether they win or lose. The crew at Homestead Raceway just wants to make sure this is carried out and help produce a race track that will meet those standards.
Old 01-31-2010, 01:02 AM   #2742
Jspeed's Avatar
Thank you Doug and please be sure to thank everyone at Homestead working on the facility. Ya'll are great!
Get those "GT" cars ready fellas, we're gonna have big time fun in a few weeks.
Old 01-31-2010, 04:24 AM   #2743
Doug M's Avatar
Default Homestead progress photos
Here are some more pictures showing the progress at Homestead Raceway as we prepare for the Ipanema GT World Championship. Please remember this is a work in progress and is much like watching a house being remodeled, where it looks very crude until all the paint, decorations and fixtures are installed.
Picture 1, this is where we left off last week with the surface being prepared.
Picture 2, shows a roughed in layout after measurements were taken to get things lined up.
Picture 3, go-kart tires and escalator handrail made it much easier to rough in a layout.
Picture 4, this is the short chute coming into a lefthander coming back into the existing track and across the timing loop.
Picture 5, the perimeter barrierss have been put in place.
The rest of the progress report will be in the next post.
GT class--buggy-based on road!-23-01-10_1112.jpg   GT class--buggy-based on road!-30-01-10_1120.jpg   GT class--buggy-based on road!-30-01-10_1126.jpg   GT class--buggy-based on road!-30-01-10_1127.jpg   GT class--buggy-based on road!-30-01-10_1316.jpg
Old 01-31-2010, 04:28 AM   #2744
Doug M's Avatar
Picture 6, now the track crew is getting serious about working on the infield barriers.
Picture 7, racers are still using the original circuit as the track crew continues to work on the infield barriers.
Picture 8, the infield barriers are now in place.
Picture 9, this photo gives you a good view of the expanded track area.
Picture 10, the hardest working guys at Homestead RC Raceway who accomplished all of this in one day! A very big thank you to (L-R) David Duperrouzel, Duncan Chin, and Joe Chin.
Over the next few weeks the expanded area will be sealed and striped. The drivers stand will be relocated to the outside center and the pit lane will be moved and reworked. If possible I will try to post photos as things of importance happen.
GT class--buggy-based on road!-30-01-10_1323.jpg   GT class--buggy-based on road!-30-01-10_1325.jpg   GT class--buggy-based on road!-30-01-10_1543.jpg   GT class--buggy-based on road!-30-01-10_1544.jpg   GT class--buggy-based on road!-30-01-10_1545.jpg
Old 01-31-2010, 07:59 AM   #2745
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
WOW ... hats off for the Homestead crew,
I really hope to make it for the event ...
cya in March !!
Pato Concha
Chile - Southamerica
Tabushi is offline   Reply With Quote
GT class--buggy-based on road! duneland Nitro Off-Road 5 03-20-2012 11:03 AM
JRX-S based 4wd buggy?? Why was the idea scrapped? cpatel529 Electric Off-Road 33 12-08-2007 06:19 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 1 12-26-2006 11:40 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 13 09-30-2006 10:31 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 8 03-21-2006 01:05 PM
