Old 03-09-2009, 09:16 PM   #1996
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Ok guys, video with music : http://www.vimeo.com/3536193
cya,
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 03-14-2009, 10:04 AM   #1997
Trader Rating: 286 (100%+)
Default GT2 3 shoe set up
Hey guys, On another topic looking to convert my GT2 to a non pull engine and 3 shoe clutch set up. I installed the IFW110 flywheel but cannot get this to work. Using the GT2 clutch bell as well. When I install the outside screw with the retaining nut, it is too tight. What am I missing here? Plus the outside bearing is not even touching the SG shaft. Any help or comments please? Thanks.
rcdoktor2 is offline   Reply With Quote
Old 03-14-2009, 12:56 PM   #1998
Suspended
Just wanted to let you guys know you can get all carbon fiber parts for the OFNA and Inferno at www.maxvelocityracing.com.
If you want to stand up the front and rear shocks or stand up the servos or just make your car lighter to increase the power to weight ration you can find them there.
Cheers
GT class--buggy-based on road!-dsc_0158.jpg   GT class--buggy-based on road!-dscf1255.jpg   GT class--buggy-based on road!-carbon2.jpg
GT Speed Freak is offline   Reply With Quote
Old 03-14-2009, 01:05 PM   #1999
I just bought the set of Max Velocity carbon fiber parts for my DM-1 Spec new off eBay. What a difference between what I got and the pictures shown here. I oculd have made them better with a Dremel, and I still might. The edges were not clean, only one side was smooth, some of the holes on th eshock tower ran together. Well, you get the idea. Why did they change the quality all of a sudden. I feel cheated.
aft53 is offline   Reply With Quote
Old 03-14-2009, 05:40 PM   #2000
That is strange, I ordered 2 sets of CF parts for my DM-1 and one for my Spec car and mine came out great. I'm glad someone makes these parts for the DM-1. You should contact Max Velocity, there emial is on their site.
vadn1 is offline   Reply With Quote
Old 03-14-2009, 06:01 PM   #2001
foampervert's Avatar
Send a message via MSN to foampervert
Default pardon my ignorance...
hiya folks,
this sounds like a fun class but i do have some questions...
-do these gt1/gt2 cars use buggy (mp7.5) arms or are they shortened arms?
-can the gt cars be converted from mp777 or mp9?
-must .28 engines be used? or can regular .21 engines be used instead?
thank you for all the help and info.
Shalom and God Bless!
-alexander
During heats, i use durex for both front and rear, with Hard inserts.
Sorex, i meant Sorex.
foampervert is offline   Reply With Quote
Old 03-15-2009, 10:28 AM   #2002
wwoodruff
Guest
Posts: n/a
They use stock 7.5 arms.
I am in the middle of converting a 777, everything fits, but you will need parts from the 7.5 and GT2. Also short shorter shocks for the rear and on-road springs front and rear.
It does not look like anything from the MP-9 will work with the older cars.
I converted a mugen MBX5 once, and used the stock shock towers with Ofna body mounts and a modified front bumper.
You will however need to do some milling for the 2 speed if you plan to use it. I had some custom made motor mount blocks made so I could use a shaft start system. I think the GT2 mounts are standard type now, so that is not an issue.
Unless you plan to race, any engine you want.
Have fun.
Old 03-15-2009, 12:49 PM   #2003
Default thanks for the info!
Have fun.
thanks a bunch!
I have a big stack of old, moldy 1/8th buggies ready to be converted...
shalom and God Bless!
-alexander
Old 03-16-2009, 07:28 AM   #2004
dude-'s Avatar
Default igt2
Hi folks, what is your opinion on this. The IGT2s can do 50-55 easily. I run my car on an oval track going for top speed. What .28 engine will give me the max rpm to acheive good top speed. Should I consider going to a .21 to get higher revs.
The axial .28 1s is decent but it only gets me up to 60.
I was going to go with Axial .28RR or the Ninja .21.
What do you guys do to get more top end.
thanks.
dude- is offline   Reply With Quote
Old 03-16-2009, 10:55 AM   #2005
Jspeed's Avatar
www.ipanemasports.com
Jspeed is offline   Reply With Quote
Old 03-19-2009, 02:33 PM   #2006
wwoodruff
Guest
Posts: n/a
Looks like an off-road motor, what model CRF is it?
Old 03-19-2009, 02:53 PM   #2007
Jspeed's Avatar
Team Orion CRF .21 US Spec
Old 03-25-2009, 06:59 PM   #2008
rsperson's Avatar
Default shaft start backplate for GXR28SG engine
Does anyone know which shaft start backplate fits this engine.
rsperson is offline   Reply With Quote
Old 03-26-2009, 06:28 PM   #2009
wwoodruff
Guest
Posts: n/a
I don't believe there is one that will work.
Old 03-26-2009, 10:00 PM   #2010
Timmo's Avatar
Trader Rating: 15 (100%+)
Is this Will??
Timmo is offline   Reply With Quote
GT class--buggy-based on road! duneland Nitro Off-Road 5 03-20-2012 11:03 AM
JRX-S based 4wd buggy?? Why was the idea scrapped? cpatel529 Electric Off-Road 33 12-08-2007 06:19 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 1 12-26-2006 11:40 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 13 09-30-2006 10:31 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 8 03-21-2006 01:05 PM
