Old 01-11-2009, 02:05 PM   #1786
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
AFM and rest of the crew,
Well, i joined the big boys and today i raced first time my OFNA DM-ONE, the format its simple, 3 x 5 minutes qualifying, lower 10 minutes mains and A-Final 25 minutes.
I qualyfied very bad being my first time with the car and bumped up to the A-Main, ended 3rd so im very very happy.
This cars are a lot fun to drive and very very fast, i used my GO Engines .21 5 ports + EFRA 0801 GO pipe ... 9 minutes and 50 seconds runtime very good ...
cya and thanks for all, next race again in 3 weeks
bye,
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 01-12-2009, 06:07 PM   #1787
viperbill1963's Avatar
Send a message via Yahoo to viperbill1963
Thumbs up body
Originally Posted by Jspeed View Post
What track was that LH?
Those rules are great and along the same lines we at RC Pro Series were thinking. I like it, time for some "Stock Car" R/C road racing!
now that would be cool seeing nascar style body duking it out
team associated RC8.2E tekin esc and motor jr z9100s servo spektrum rx
X-FACTORY X-6 square tekin esc lrp motor spektrum rx soon to be a cube
viperbill1963 is offline   Reply With Quote
Old 01-12-2009, 06:28 PM   #1788
Jspeed's Avatar
Yea, that would be cool on hi-banked tracks. GT500 racing too!
Jspeed is offline   Reply With Quote
Old 01-13-2009, 07:55 PM   #1789
Default igt2 clutch
fella's i'm having a problem with blowing clutch springs the original spring and
mips. I didn't see anything about the clutch it's self not being changed but the gearing can. I'm thinking about the three shoe clutch will this be ok?
steven57rc is offline   Reply With Quote
Old 01-13-2009, 08:25 PM   #1790
Jspeed's Avatar
If you're running the aluminum 2 shoe clutch, it tends to mushroom just like a 3 shoe except over the spring and cuts away at it. If you switch it out to the KC45 carbon unit and you'll have no more problems.
Old 01-13-2009, 08:45 PM   #1791
I'm breaking springs while breaking in engine. Springs used are stock, tmaxx,and strong Mips snaping on the ends and center. strange ha
also what bearings are used instead of bushings for the second gear?
Old 01-14-2009, 10:48 AM   #1792
Speyederjedi's Avatar
Does anyone know if there are any centax type clutches available for these 1/8 Buggy-Based On-Road cars? I have an older OFNA GTP and would like to test a centax type clutch if there is one available.
Regards,
Speyederjedi
Speyederjedi is offline   Reply With Quote
Old 01-14-2009, 10:52 AM   #1793
wwoodruff
Guest
Posts: n/a
Default Someone has done it!
I read somewhere it has been done, but it did require some mods to the chassis. Werks makes a centax type clutch for offroad buggies that would probably work with no mods.
Old 01-14-2009, 10:53 AM   #1794
Tabushi's Avatar
Regards,
Speyederjedi
Which clutch are you using ?, i mean, i made my debut on GT Class in my country (GT Class based on 1/7 OFNA DM ONE Chassis) and i used aluminum 3 shoe buggy like clutch with hard spring and i loved it !
cya
Old 01-14-2009, 11:01 AM   #1795
cya
I'm using the stock 3 shoe clutch, but I'd like something that would allow the engine to spool up to a higher RPM before engaging. I've seen a couple of races of this class and I'd have to say that the biggest drawback to these kits are the clutches. The clutches engage too early and due to the weight of the car it takes them to long to get up to speed,but that's just my opinion. I think an adjustable centax type clutch would make a big difference in performance.
Regards,
Speyederjedi
Old 01-14-2009, 11:22 AM   #1796
Tabushi's Avatar
Regards,
Speyederjedi
I felt what you say but only on the first qualy when i used 0.9mm springs, with 1.1 the problem was solved,
Old 01-14-2009, 11:56 AM   #1797
MikaR's Avatar
Regards,
Speyederjedi
Too hitec IMO. These cars are meant to be simple. In Inferno shorten the length of the spring, get a stronger one and/or enlighten the shoes if needed.
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 01-14-2009, 01:40 PM   #1798
I guess we would have to agree to disagree. I feel that in any kind of racing you want to maximize the power offered from your engine. If your clutch is engaging before the engine is operating in it's power band then you're at a disadvantage even if every other racer is in the same situation. Besides, centax clutches are not that complicated and are easy to adjust. If you ask me, pulling a motor to change out your shoes or springs is much more difficult of an adjustment than holding a spring nut in place and turning the flywheel without having to pull the engine out of the car. Running a centax clutch would actually be easier. IMO.
Regards,
Speyederjedi
Old 01-14-2009, 02:29 PM   #1799
kmichael's Avatar
Regards,
Speyederjedi
I agree,I used the centax from the 950 and that was one less problem and easy to adjust which made the car more controlable
kmichael is offline   Reply With Quote
Old 01-14-2009, 03:22 PM   #1800
Jspeed's Avatar
I think what MikaR is trying to explain is that the concept of the GT class racing is to try to lower the overall costs associated with on-road racing, to adapt to the current world wide economic situation and to offer RC racers an opportunity to compete in a more level playing field.
There has been way too many heated debates on this thread & other threads about “Spec vs. Open” GT car racing.
There’s no debating that an “Open” GT car would produce superior speeds & lap times, but the true issue we fellow RC racers should consider with this new breed of on-road racing, are the growth and future of our sport.
My personal opinion are that these GT cars is: they are fun, very durable, spectator friendly, accessible and moderately priced; in comparison to Sedan & true 1/8 scale vehicles.
GT cars are a great “stepping stone” for newer racers into the higher ranks, a class for experienced racers that wish to compete with a more simple chassis design and for any racer that wish to be able to continue to enjoy the RC racing experience during this challenging financial climate.
Nitro Sedans & 1/8 scale cars do offer racers with the ultimate in speed & complexity, so there is really not much need for the GT cars to escalate to that level, since those types of classes already exist.
Mexico has the best example of what can be done with the GT class. They have a huge number of Spec racers attending their events. The rules are set in stone, they are having fun and there is little “in-fighting” between the people that would otherwise be good friends.
If “the proof is in the pudding” the Mexico GT class is a shining example of what does work very well.
Be it “brand” specific or not, “they’ve got it going on”, while here in America and elsewhere around the world, we’re just spinning our GT car wheels.
GT class--buggy-based on road! duneland Nitro Off-Road 5 03-20-2012 11:03 AM
JRX-S based 4wd buggy?? Why was the idea scrapped? cpatel529 Electric Off-Road 33 12-08-2007 06:19 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 1 12-26-2006 11:40 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 13 09-30-2006 10:31 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 8 03-21-2006 01:05 PM
