Old 12-03-2008, 09:52 AM   #1651
-R2-'s Avatar
Originally Posted by Zootcapri View Post
From some other photos it looks like a single speed. Can anyone verify that or does it have a two speed. The chassis looks cool. Should someone mention to them that two of the tires are mounted in the wrong direction. Left front and right rear seem correct... for the tread pattern... I am not sure how much difference it makes anyway. I can't find mention of price. Anyone know?
At least they aren't promoting this for the 'new ROAR class' and it doesn't have 'picvot ball's like the OFNA.
'picvot ball's
That was done by the mag. not by us but if we make some new suspension, you'll know we may name it like that
SOAR SEIKI 998,Truggy, Buggy and Electric
Flashpoint Fuel/Savox/
-R2- PAINTS/PRO-LINE RACING/AIRTRONICS
-R2- is offline   Reply With Quote
Old 12-03-2008, 10:26 AM   #1652
RogerHewson's Avatar
Send a message via AIM to RogerHewson
Picvot balls, sounds like a high tech. We will soon offer a "Picvot Ball conversion Kit"
Roger
RogerHewson is offline   Reply With Quote
Old 12-03-2008, 12:24 PM   #1653
Zootcapri's Avatar
If I am not mistaken the 'picvot ball' conversion makes the OFNA legal in ROAR's new IGT Class (there is soo much wrong with this sentence)
Zootcapri is offline   Reply With Quote
Old 12-03-2008, 04:26 PM   #1654
Trader Rating: 284 (100%+)
Default engine conversion
does anyone know what parts i need to convert my pull start to a non pull start? Buggy flywheel works? do i still use the same clutch bell? thanks.
rcdoktor2 is offline   Reply With Quote
Old 12-04-2008, 08:07 AM   #1655
MikaR's Avatar
and which car are you talking about? For the Kyosho .28 you cannot basically buy a backplate, you'll have to do it yourself.
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 12-05-2008, 05:48 PM   #1656
Erchur's Avatar
Has anyone done the IGT2 brake pad upgrade (i.e., acre brake pad Kyosho part# IFW324). I just ordered them and the set only comes with two pads, where as the stock version uses four pads and two disks. Am I supposed to order two sets of IFW324 (i.e, four pads) and keep using the two disks or am I supposed to use only two pads and one disk in the upgrade?
Eduardo Romero
Serpent America-Desoto Racing, Novarossi, KO Propo, Byron's Fuel, Alpha Tires, Alpha Body
Erchur is offline   Reply With Quote
Old 12-05-2008, 05:57 PM   #1657
wwoodruff
Guest
Posts: n/a
Default You only need one set.
You will only need one set of pads and one rotor, unless you plan on running hour long races, then you could put another set on the other side of the 2-speed.
Old 12-05-2008, 06:24 PM   #1658
Default mikar
mikar,
i have the gt1. looking to put in a regular sg shaft os non pull start engine. will the stock clutch bell fit this conversion?
Old 12-05-2008, 08:06 PM   #1659
Zootcapri's Avatar
Don't try to race the two rotor setup. If you use the sintered pads there is not enough room. If you use the stock pads and rotors they will fail in the rigors of racing. The ??122 rotor and the sintered pads are the best brake available for this car. With my GT and my GT2 braking performance was great with that combination. I raced a box stock GT2 (except radio & servos) and in the first two 5 min qualifiers I wore out the centers of the dual disk rotors (text and photo a few pages back in this thread*edit54*). I took the good braking system off the GT and installed on the GT2 and 'shazam' won the B main and bumped to the A.
Old 12-05-2008, 11:48 PM   #1660
MikaR's Avatar
Originally Posted by rcdoktor2 View Post
mikar,
Right. In GT2 yes, but not directly in GT1. In GT1 you have to cut the cranck or buy the few parts that GT2 uses (clutch nut, cranckshaft extension piece) for SG shaft engine. I believe you can use the same flywheel though GT2 uses a smaller dia one.
Old 12-06-2008, 07:22 AM   #1661
Winner's Circle's Avatar
One side is all you need. This will give you consistent hard stopping braking.
Lee Muse
leemuse3445@comcast.net
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 12-06-2008, 10:05 AM   #1662
CurveTracer's Avatar
You do not have to cut the SG crankshaft.
If you use the Kyosho engine mount and plate and the Kyosho clutch bell the pinions will line up with the stock transmission spur gears
Kyosho Stock engine mount KYOIF108
Kyosho Stock engine mount plates KYOIF107.
I mounted and raced with a stock Ofna .28 engine in this configuration.
"Yellow Jacket" Mugen MTX-6, Picco Torque
TeamNITRO RC Club, Lynwood, Illinois
CurveTracer is offline   Reply With Quote
Old 12-06-2008, 12:24 PM   #1663
R2 (DJ),
Please check you PM I have a setup question for you on the DM-1.
vadn1 is offline   Reply With Quote
Old 12-08-2008, 04:04 AM   #1664
Hello from France,
we raced the first round of the Rally Game Challenge.
More pictures to come with some explanation...
romuald31 is offline   Reply With Quote
Old 12-08-2008, 11:32 AM   #1665
MikaR's Avatar
Are you running with the same rules as in Italy, no 2-speed allowed, only spool or center diff?
GT class--buggy-based on road! duneland Nitro Off-Road 5 03-20-2012 11:03 AM
JRX-S based 4wd buggy?? Why was the idea scrapped? cpatel529 Electric Off-Road 33 12-08-2007 06:19 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 1 12-26-2006 11:40 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 13 09-30-2006 10:31 AM
WTB: .21 NovaRossi based on-road engine parts Speed_Racer R/C Items: Wanted to Buy 8 03-21-2006 01:05 PM
