High speed needle setting on MR-12
My problem is that my running time is less than 5mins (I need at least 5mins as that is a standard round at my track), on my car as I have to run rich, or else the cars starts to bog down? I am running 20%, and running the standard plug?
Can someone help me please?
Sami
Sami
Re: High speed needle setting on MR-12
Sami
Sami
there is no real setting for these engiens!!!
this problem could be your plug, temp of day, sea level!!!
Jeremy.
Thank for the replies.
rrgt_kid, I am running 20%, in Melbourne in 20 celius (66 F)
How many turns do you have out and what plug should you suggest I use (or what plug do u use?)
Sami
Sami
Sami
Sami
No I just the stock motor, no turbo button? Are you running one, is it better and where can I buy one?
this is going to sound really stupid, but i have that same engine, and its my first engine with a three needle carb (i have run OS's for quite some time)... which is the low end, and which is he middle (end?). also the idle screw.. i know with OS motors to open up the idle you go in, same thing with the mugen?
thanks!
thanks!
