Old 05-13-2003, 04:27 PM   #1
Wearing of Rear Tires
Just a quick question about tires. I am running Front 26mm 40 and Rear 30mm 37. Now my problem is that the front tires last longer than the rear ones about double. The track I run is not fantastic and is tight and small.
Is this normal, or is it my driving style?
ttektek is offline   Reply With Quote
Old 05-14-2003, 12:35 AM   #2
rrgt_kid's Avatar
keep truing the fronts down to suit or you keep plenty of rears to rotate! usual rule is 2 sets of rears to 1 set of fronts.
to start with true the front down 0.5-2mm depending on gearing and your drive train ratios.
rrgt_kid is offline   Reply With Quote
the outer edge of my rubber tires are wearing so fast Molala3 Electric On-Road 2 04-25-2008 04:51 AM
HELP! wearing armature shaft Cristian Silva Australian Racing 42 03-17-2007 12:56 AM
HELP! wearing armature shaft Cristian Silva Electric On-Road 24 03-14-2007 06:22 PM
Wearing shaft.. Cristian Silva Australian Racing 20 01-31-2007 05:14 PM
Wearing Spurs / Pinions JP-NZ Electric On-Road 3 01-06-2005 03:02 AM
SEO by vBSEO 3.5.0
