Trinity G4 - Team Magic G4 E-Type
#2956
An original tank sorted the problem out, it looks perfectly sealed now. Only problem now is that it's a bit too small, but that's easily sorted out with some hot air and then some compressed air
#2957
New 3mm chassis
question for TM, Is that true the old side plate cant use with the new 3mm chassis? My 4 mm chassis still ok. But i m wondering what if i really need a new chassis and I already have all the Kfactory option parts installed. Included the old Graphite side plate. Is that mean I have to buy the new side plate again?
#2958
i need to put a engine in my g4 do i need to put anything special, like a engine with an sg crank. i know it has to be a non pull start engine. any suggestions would be great.
chris
chris
#2959
Originally posted by Z00M
I use the K-Factory tank that came with the Mongoose G-4.
Just remove the lid and put a little extra tension on the spring. I have done this with all kits as a build step so I guess I don't really know if the tanks leaked if left standard.
TIA.
#2961
chris
chris
Check in your manual as it will tell you what is required in there as well.
#2962
chris
chris
#2963
Originally posted by daniz24
If you are using engine other than from Novarossi family, then I think you have to do some modification on the handle from hitting by the carburetor
So whatever you choose shouldn't be a problem.
#2964
If the carb hits the handle you just have to rotate the carb a little bit, on about every engine i have to do this..
On MTX3's you have to grind away material though when using Sirio-engines, it can be the same with the G4 but i haven't tried those yet.
#2965
I have the team magic pro version of the G4. box stock.
Any general ideas on what to adjust -- the car tends to push coming out of corners. I would like it to bite more.
Hope to hear your ideas! Thank you.
#2966
softer dampening......
no front sway bar.........
#2967
also try different caster, usually more caster, different front tires, one softer than using now, and less rear toe-in. maybe different body....less rear wing perhaps?
#2968
Originally posted by SalvadoriRacing
i can't hell you with that.....
i run full white bodies only hahahahahahahha!
but i do know that there are some sticker to put before painting, something like the drawings in surfboards.....
Hi Salvadori !! ..
You are right, i use Team Orion's inner stickers in order to avoid showing to the people the bad painter i am heheheh !!! ... its easy, just put the stickers from the inside and apply painting ... and you will get an amazing finish ...
cya !
Pat
#2969
Thank you for the suggestions people! I wil try them out.
#2970
wright tire size.
what is the wright size to true the front and rear tires.
and what ofset to get in the tires ,is 1 degree good or more.
