Trinity G4 - Team Magic G4 E-Type
#2701
Originally posted by daniz24
This my rear solid axle modded to front spool.
Haven't any chance to tested it though...
#2702
Do you have experience with front spool? Please share some info...
#2703
New Pulleys are in
#2704
build advise
just bought a G4 Evo kit with the K-factory steering, etc. Is this steering OK?
I think I remember something about the rear tires wearing faster than fronts and an upgrade of some sorts for that problem. Is this a problem on the newer kits? If so what is the upgrade.
Is there anything else of significance that I should be aware of and upgrade when I am building the kit.
Also...gearing....the track I will primarily run is pretty tight and overall is 170' x 75'
Give me a starting point for pinions and spurs
thanks
mark
thanks
mark
#2705
I think all car will have rear tyres wear faster than front's. From my experience, G4 is one of the most balanced car for tire wear.
For building tips, you have to check the movement of suspension arm and also the shock plastic o-ring because sometimes they are pretty tight and can cause the shaft can't move smoothly.
For optional parts, one of the most important is the rear belt tensioner. For tight track, you might want to try 19 & 23 pinion gear.
#2706
...and use the stock spur gears??
#2707
Yes
#2708
what motor
thinking about the Rossi Pixy black 5-port.....I have seen hp figures of 1.8, is that correct.
Anyone running one of these?
What do you recommend, this or another?
#2709
steering G4 Evo
OK, my eyes hurt from searching pages.....I have the new EVO with the new K factory steering, does this come with the updated steering blocks or do I need to still buy them (K1481)
Any other specific mods I should be aware of for the steering?
thanks
thanks
#2710
hitek: the G4 you got should have the new steering blocks if your kit came with the new steering system. as soon as you install the steering check if it hits the belt, also when you tighten the servo saver. you will notice that the screw will eventually hit the belt. so, find the perfect adjustment in the servo saver and grind the screw using a dremel. the steering system as welll may need some grinding. and let me know on the pixy engine, i've been wanting to try out that engine eversince
#2711
thanks for the help..........sounds like the G4 will be a great car if the steering issues are resolved.
unless someone points me in a different direction I think I will pick up the 5 port black pixy
#2712
Re: what motor
#2713
I have not run the 5 port turbo version, but I have run the 3 port roar legal, was fast but I ran it against my sirio equivalent and the Sirio was much faster.
#2714
#2715
bros,
i do not know if you are all talking about the black pixy, shinny silver cooling head with black body, 5ports.
I got one. If it is, i can tell you, this engine is required a lot of run in. Will cramp when started on the starter box easily during run-in.
among other engines, the latest jp- blue with 5 ports, should be the fastest.
