Trinity G4 - Team Magic G4 E-Type
#2206
Originally posted by brooklynrc
anyone knows when that steering fix will hit the stores?
Still wondering how rc_alan's fix went
#2208
Originally posted by vones
Team Magic announced that they are releasing their 3mm chassis for G4.K1479..........
#2209
Originally posted by rbboy
vones: hi! is that the same with the one that came with the evo kit or different?
#2210
the chassis that comes in the evo kit is basically the same as the standard g4 but with slightly altered battery shot and titanium in colour, the 3mm k-factory will be similar too the 4mm hop-up item, alot of people moaned that the 4mm chassis was too heavy, hence the 3mm
#2211
I've held my original G4 and EVO chassis side to side and can't notice any difference in color, the tank has more clearance tho..
#2212
#2213
Hi guys, i recently bought a team magic G4 with an engine second hand off this bloke,
just wondering if there was anything i should look out for wearing..or any known problems on the G4.
o yeah, its the e-class version, with low friction belts or something
Matt
Matt
#2214
Raving_monkey, I hear from some guys that the low-fricion belts don't last too long. I you need replacements, try the Kyosho Special belts. They should be an even swap on to your car and I haven't had to changed them all season. And make sure your pulleys aren't worn. Sometime a little pebble could chunk a tooth and make it sharp which will eventually weaken the entire belt.
Congrats and good luck with it!
#2215
kid, do you have the kyosho beltnumbers?
#2216
Special Belt Part #s
Owens, Here you go ...
-_Kyosho Special Front Belt (210) V-One RR
- Kyosho Special Rear Belt (192) V-One RR
- Kyosho Special Middle Belt (375) V-One RR
Also try to check them out on this page at Tower:
http://www2.towerhobbies.com/cgi-bin...NE&S2=&S3=&S4=
#2217
thanks dynomite, i will keep an eye on them to look for any wear on the belts, or chipping on the pulleys.
#2218
if you need any thing in a hurry microtech stock all g4 parts.
#2219
hey jason, never knew you was on here
i get quite a few things from microtech (mainly shells/wheels/tyres and xray spares)
do you race at halifax? ( remember seeing you down there once)
Matt
Matt
#2220
try and get there when i can, halifax is one my favorite tracks.
