Trinity G4 - Team Magic G4 E-Type
#1967
Originally posted by JoeRocket
If I shorten my receiver wire will this affect my range? It is about 14" long, and I would like to cut about 4" off.
If you find the aerial too long take a small piece of fuel tubing and insert it over the aerial and antenna tube to hold the excess from flapping about. Dont tie-wrap the excess with the other cables etc from the servos or battery.
#1969
Originally posted by ttektek
One question for you guys which the difference between the 27 and 26 tooth? Should I purchase one?
To get equal front and rear tire rollout (front pulls the same as the rear), use about 2.5 mm smaller front tires than the rear tires.
#1970
So basically with the stock gearing and the same sized tires on all 4 corners, the back is going to have more push than the front has pull? thats retarded i would much rather have the front pull the car, especially with the front one way in there.
Mike
Mike
#1971
Mike
Mike
#1972
Thats exactly what i mean, so with the stock gearing the 27 tooth and all 4 tires the same size the front is pushed by the back or is it equal to both tires? Hmm... i might have to get that 26 tooth pulley since i do not have a tire truer for foams and i usually run rubber tires.
mike
mike
#1973
Of course if you want MORE overdrive, then the 26T front side pulley is the answer when you run it with front bigger and rear smaller tires.
#1974
Yeah i like having the front pull the rear around. It suits my driving style
Mike
Mike
#1977
v6 and brooklyn
What is going on in Jackson tomorrow? I may stop by after running in the morning.
#1979
v6
I need another day to finish breaking in the engine and fine tune the car. I still have not go the 2 speed tuned yet.
#1980
v6
call me later. I will meet up with you down there. Are Richie or Roshon going?
