Old 02-03-2010, 06:23 AM   #1471
epowr_Racing's Avatar
Originally Posted by wingracer View Post
epowr, there is more to "Punch" then just a spring setting, though that is important as well. Gearing, two speed set-up, tuning, motor and other things all come into play as well. For instance, the Flash isn't quite as punchy as the 35+21 so getting everything spot on is even more critical.
My current clutch set-up for a Mugen 3 shoe.
Lightened flyweights slightly by cutting some material from the inside of each shoe. Most people just drill a whole in them, does the same thing.
Orion CRF spring. Set to .9mm from end of threads to face of the nut. Adjust as needed. I often go to 1.0mm or even more if I need more snap.
Yellow shoe.
At least a .6mm gap from shoe to bell. Sometimes go to .7mm. This was often too much for the old 4 shoe clutch but the 3 shoe can take it. In my opinion, this is one of the most critical settings.
Then space the inside of the bell to take most, but not all of the free play out.
Thanks Wingracer, i'll try that set up, but most of the guys at the event were actually running the Collari 35+ or the Rb , so maybe next time i should walk with a 35+ lol..., as far as the gears well it due the size of the track i ran a 16/50 -19/47 , just coming out was an issue for me, but other wise the "laughing Ninja" got named this weekend lol... did pretty good
Think, Feel, Operate: Control The Power Of Dreams...
Serpent 966TE,.21 Flash Novarossi, AE TC-6 ,17.5 R Speedpassion, Xray NT1 2011 Spec, .12 Novarossi, Ko Propo radio & Servos
epowr_Racing is offline   Reply With Quote
Old 02-03-2010, 11:33 AM   #1472
lavaandy's Avatar
Default ceramic bearings
ceramic bearing clean the grease out or leave it in that is the question thanks
Team Timezone www.Timezoneracing.com Team CRC, Mukune designs
lavaandy is offline   Reply With Quote
Old 02-03-2010, 12:45 PM   #1473
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
def clean it out, re-oil w/ceramic oil, or i use mobil-1 ...but thats a preference
Thinking on maybe a Tekno 1/8 Nitro Buggy?
TommyBlazin is offline   Reply With Quote
Old 02-12-2010, 11:51 AM   #1474
Hi there,
I have two servos here. Futaba BLS451 and BLS452. The 452 has a bit more torque and the 451 is a hair faster. Which one would you put on the steering?
Yes, I could simply try both on the steering but would like to hear your thoughts anyway...
Until next time, Stefan
fulcrum2 is offline   Reply With Quote
Old 02-12-2010, 09:23 PM   #1475
asw7576's Avatar
Originally Posted by fulcrum2 View Post
Hi there,
I would settle with Futaba BLS351 , one for steering, one for throttle / brake.
6.0V , 217 oz-in. , 0.13 sec/60
Old 02-13-2010, 03:06 AM   #1476
Roelof's Avatar
Send a message via ICQ to Roelof
For serious racing for sure on the steer it is too slow. I went from 0.1 sec to 0.07 sec servo's and I noticed the gain in speed in a better stering response and better positioning of the car.
On throttle it will work but a faster servo can make a difference in a crash or right time braking.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 02-13-2010, 03:37 AM   #1477
Roelof, how about my question regarding Futaba 451/452? Any thoughts?
In the perspectiv of your last post probably the faster one on the steering...
Thanks for looking into this. Regards, Stefan
Old 02-13-2010, 06:16 AM   #1478
Roelof's Avatar
The BL452 is with .14 sec slow. The 451 is with 0.1 sec the right choice for a good response and the 10kg is enough, even for an 1/8 scale car.
Currently I run Savox 1257 servo's, they are also 10kg and have no issues with them.
Old 02-13-2010, 06:50 AM   #1479
Thanks for your reply Roelof, much appreciated!
Old 02-13-2010, 06:03 PM   #1480
wingracer's Avatar
Trader Rating: 23 (100%+)
Me personally, I would run the faster one on throttle. I can deal with a slowish steering servo (prefer a bit quicker but can deal with it) but a slow throttle servo drives me nuts.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 02-13-2010, 07:06 PM   #1481
CanyonCarverR1's Avatar
This whole servo conversation makes me wonder how fast is fast enough. I can't turn my steering wheel from lock-to-lock more than about 5 times per second, so isn't any servo that is faster than 0.2 seconds fast enough? If I can't trun the wheel quicker than .2 seconds, why do I need a servo that's faster than me?
CanyonCarverR1 is offline   Reply With Quote
Old 02-13-2010, 08:55 PM   #1482
wingracer's Avatar
I can notice a throttle servo that's slower than .12 or so. It annoys the hell out of me.
Team Shepherd USA
Old 02-14-2010, 12:00 AM   #1483
Default servo
i agree. +1^
ROLLINGaFTGT is offline   Reply With Quote
Old 02-14-2010, 03:56 AM   #1484
asw7576's Avatar
deleted....... no comment on servo.
Old 02-14-2010, 04:35 AM   #1485
staikosn1's Avatar
Send a message via MSN to staikosn1
I would stick with 451...( ill put in my motonica soon)
Is fast enough and if you want can be slower....
But fastest servo doesnt means better steering...(i think)
XRAY NT1 || RB T10 RC || FUTABA BLS || SANWA M11 ||
#FANATIX MODELS# #www.frt.gr#
staikosn1 is offline   Reply With Quote
