MRX-4X
#1396
Looks nice.
Have you seen the upper arm mounts for the Shepherd where you can raise and lower the arms just by tightening and loosening the set screws? That would be a nice feature to add.
#1397
Yo guys ? Will the con rod for the Mugen Ninja MR21-R01 work on the Mugen Ninja MR.28, I heard that it will work with the GRP .21 on-road and the Truggy .28
#1398
I didn't know there was a GRP Ninja .28. If it works in the GRP .28, it should work in a Ninja/GRP too.
#1399
My mistake the ninja and the grp where both made by Rossi I heard that con rod for the MR.21 will fit the MR.28 Ninja if so I think the rod should fit the grp line then. Because I know that the the grp and the ninja.21 you can use each others parts NO?
#1400
Not Rossi, GRP. GRP made the MR line of Ninja's and their own GRP motors. If it works in a GRP .28, it should work in an MR Ninja .28 too. If it's an OS Ninja .28, it will not.
#1401
Yes that is what I heard the JXG ninja is the OS line.
#1402
Amain lists the crank and wrist pin as the same for both the MR21 and MR28 so they have the same stroke and pin sizes so my guess is that it will work.
#1403
I saw that also at Amain your correct. I also think I saw it some where in this forum under GRP I think not to sure.
#1404
I just got this car and it is awesome. I have not run it yet and this is my first run at Nitro Sedan. My question is...When do I use the pins in the front drive?? I do not have the front diff, it is the spool/one way...I assume. Can anyone go into some detail on this for me?
Thanks in advance...
#1405
#1406
LiPo for Mugen Starterbox
Hi there,
does anyone know if those Lipos :http://www.rc-mushroom.com/product_i...ducts_id=18887
would fit into the Mugen Pro Starter II box and if yes, if the C rating is high enough.
Thanks and best regards, Stefan
#1408
#1409
Trader Rating: 9 (91%+)
Hi there,
I am racing 2 times per month and i charge them once every 3 months hahaha love Li-Po !
#1410
Mugen MSR tires
I have for sale 4 sets of Mugen MSR Tires 2-Fronts/2-Rears
The Rears are 42 shore and 40 shore
The Fronts are 42 shore and 32 shore
