Old 10-27-2009, 09:38 AM   #1306
YBSLOW's Avatar
Originally Posted by brc358 View Post
How much did the long H arms raise the back of the body.
I have two MRX4X cars, and on one of them I used the Evolva M3 arms. It did help with the rear bite, but the aluminum arms really look good, and I may want to add those to the second car.
thanks
H-Arms have two mounting locations.
The lowest position is about 6.5mm taller than stock.
The highest position is about 10mm taller than stock.
(kyosho arms are about 6 or 7)
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source
POWER MASTER Fuel,
Protoform Bodies, Avid Bearings
YBSLOW is offline   Reply With Quote
Old 10-27-2009, 10:31 AM   #1307
choisan's Avatar
Originally Posted by mugenize1 View Post
On what Engine do you use the o'donnel's plugs I have the Mugen NINJA MR21-R01 I was told that my car still needs to be tuned. That is way I blow plugs.
Mugen Ninja engine is suggested to stick with its original #7, but it seems difficult to find(buy). Mario Rossi is kind of having its engine rebrand, but i don't know it is out or made the same as previous. Hope it will. At least, GRP was a very good plug.
My GRP engine also keeps using the original, and it lasts(now almost 7 litres mileage). I am on 25%.
You may need to add shim in your case, try adding 0.1 may help. adding 0.1 won't hurt.
Many people in my country tried to find GRP #7 for their Flash 21, GRP's plug seems give very stable engine tuning, last long and good performance, but needs a strong glow plug voltage to glow, the next one i would say 0 donnel's. I have not used nova's for long long time.
just my 2 cents
choisan is offline   Reply With Quote
Old 10-27-2009, 12:13 PM   #1308
mugenize1's Avatar
just my 2 cents
Mugen Ninja engine is suggested to stick with its original #7. 7 is a clod plug and I am running in 60% weather should I run #5 or #4
mugenize1 is offline   Reply With Quote
Old 10-27-2009, 12:15 PM   #1309
mugenize1's Avatar
Keep this in mind I live in NYC Bronx and it is cold out here now. should I be running a hot plug.
Old 10-27-2009, 12:47 PM   #1310
mugenize1's Avatar
Hello guys
Can someone school me on plugs, Hot weather use Hot plug or cold plug, Cold weather use cold plugs or Hot? HELP LOL
Old 10-27-2009, 01:05 PM   #1311
wingracer's Avatar
Trader Rating: 22 (100%+)
1/8th onroaders almost always use 7's. Sometimes an 8 for a really long track on a really hot day. But when it gets below 65 or so, I like to break out a 6. Makes the motor a lot more crisp.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 10-28-2009, 11:24 AM   #1312
Loveless's Avatar
Originally Posted by wingracer View Post
1500's work fine. I think I have 2400s in mine now. It was one of those Orion Emaxx 2 pack deals.
By going with the higher batt numbers like 3000"s and 3500 will the batteries keep the charge longer or will they give more torque.
AIRTRONICS/KEVLAR R.D./MUGEN FUEL/PARMA, CENTRAL BODIES/MUGEN SEIKI/PICCO ENGINES/JP ENGINES/ BELTRANS WHEELS AND HOBBIES, KAMIKAZI RACING.
"Free your mind, and your ass will follow"...
Loveless is offline   Reply With Quote
Old 10-28-2009, 12:37 PM   #1313
wingracer's Avatar
Higher mah batteries just last longer on a charge. I had no trouble going a whole day of racing with 1500's but when they died after a few years I picked up the 2400's.
Team Shepherd USA
Old 10-29-2009, 02:48 AM   #1314
asw7576's Avatar
Hello guys
Hot weather climate : use colder plug
Cold weather climate : use hotter plug
High altitude ( mountains ) : higher nitro content
Low altitude ( sea levels ) : lower nitro content
be nice to grup A people and copy their engine setup.
Old 10-31-2009, 05:34 PM   #1315
mugenize1's Avatar
Unhappy
Well guys let me tell you my drama. I found the #7 and the #6 plugs for the mugen ninja mr-.21 on-road. I was told that this engine does not need 30% fuel, 25% was good, But if I was going to run 30% then I need to add a shim under the buttonhead just like wingracer said went to remove the the buttohead and the sleeve came off also I was thinking ok wiggle it off wrong had to heat it up to remove it when I looked at the piston it looked like some one hit with a hammer!!!!!!! the rod is still new not a dent or stretch because I checked it with one of the new ones I have. and enverytime I remove a plug I made sure the spring on the plug was not in the engine. So know I am out an engine and can not run. Looking into New blocks any ideas out there on what I should get I like navorossi plus 35 or is there something better.
Old 10-31-2009, 05:37 PM   #1316
mugenize1's Avatar
I also forgot to say the bearings where done about 3 where split in half
Old 10-31-2009, 07:54 PM   #1317
wingracer's Avatar
Ouch. Remember this for the future though. If you start blowing plugs, STOP. It's time for a tear down.
The 35+21 is about as good as it gets. I think I like it better than the Flash.
Team Shepherd USA
Old 11-01-2009, 06:12 AM   #1318
Trader Rating: 4 (83%+)
mugenize i have a GRP 21 Tuned Onroad engine and pipe for sale $180 shipped ,the engine has six tanks of breakin only so its still new.
Roniel_R is offline   Reply With Quote
Old 11-01-2009, 07:39 AM   #1319
Team Kamikaze's Avatar
Get this:
http://kamikazercracing.com/proddeta...=35plus21TUNED
OR
http://kamikazercracing.com/proddeta...od=NOVS21WCS09
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 11-01-2009, 08:16 AM   #1320
mugenize1's Avatar
What is better the Blue head or the purple head I am looking for the NovaRossi 359 Race .21 Blue head and I can not find it, not even used not that I want it used. LOL
