Old 10-26-2009, 11:59 AM   #1291
mugenize1's Avatar
Originally Posted by wingracer View Post
Is this a Nova motor? If you are running Nova plugs, they aren't as good as they used to be. Try GRP or Sirio plugs. Otherwise, add a head shim. If this motor is old it may need a rod.
Ninja MR21-R01 stock plug. The Engine still locks on me when I try to start the car lots of compresion still, and the car runs hard but after 3 tanks and there goes the plug, when I look at the plug it still looks NEW but will not burn red.
mugenize1 is offline   Reply With Quote
Old 10-26-2009, 12:09 PM   #1292
asw7576's Avatar
I still check the bearing for smoothness.
Secondly, I would go for 20% nitro instead of 30% ..... if you tune your engine correctly, 20% nitro is as fast as 30%, with less headache of blowing up glow plugs, and get more runtime.
About quality of ninja glow plugs ..... I don't know anything about ninja.
Old 10-26-2009, 12:12 PM   #1293
wingracer's Avatar
Trader Rating: 22 (100%+)
Add a shim then and you should be fine.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 10-26-2009, 12:35 PM   #1294
Loveless's Avatar
Mugen box all the way. I don't know why the other guy mentioned spare belts. I've been using mine since 1999 and never replaced a belt.
Yo wingracer, what batteries you recommend me using in my mugen box, right now i have two 1500 stick packs, and i really dont care for the lipo's i heard to many horror stories about those things,,,
AIRTRONICS/KEVLAR R.D./MUGEN FUEL/PARMA, CENTRAL BODIES/MUGEN SEIKI/PICCO ENGINES/JP ENGINES/ BELTRANS WHEELS AND HOBBIES, KAMIKAZI RACING.
"Free your mind, and your ass will follow"...
Loveless is offline   Reply With Quote
Old 10-26-2009, 12:46 PM   #1295
mugenize1's Avatar
Ok I will do that, But what plug should I use? Better yet What brand
Old 10-26-2009, 12:48 PM   #1296
mugenize1's Avatar
I opened the Engine and the bearing is smooth.
Old 10-26-2009, 01:57 PM   #1297
mugenize1's Avatar
What # plug should I go with I found GRP plugs at the hobbyshop. I found #4 #5 and they do not say if there hot or cold on them.
Old 10-26-2009, 03:24 PM   #1298
wingracer's Avatar
You want GRP 7's but good luck finding them. You could try Sirio 7's. They work great in Novas but I don't know how they fit in GRP/Ninjas.
Team Shepherd USA
Old 10-26-2009, 03:26 PM   #1299
wingracer's Avatar
1500's work fine. I think I have 2400s in mine now. It was one of those Orion Emaxx 2 pack deals.
Team Shepherd USA
Old 10-26-2009, 05:11 PM   #1300
mugenize1's Avatar
Ok I ordered them from my local Hobbyshop they said they can get there hands on them for me.
Old 10-26-2009, 09:56 PM   #1301
choisan's Avatar
it is true though, some current batch produced nova's plugs got problem, either open pack failure, and some will flame out the engine after running some laps, which then make you believe you have a rusty bearing or loosened rod.
i use o'donnel's 99
choisan is offline   Reply With Quote
Old 10-27-2009, 05:27 AM   #1302
mugenize1's Avatar
i use o'donnel's 99
On what Engine do you use the o'donnel's plugs I have the Mugen NINJA MR21-R01 I was told that my car still needs to be tuned. That is way I blow plugs.
Old 10-27-2009, 10:10 AM   #1303
T-BODZ Terry B.'s Avatar
Default Some Sweet New MRX4X Parts...
Just thought I'd post some pics of some nice MRX4X parts I received the
other day from YBSLOW. http://www.ybslowinc.com/
Magnesium / Lightened Front One-Way
One Way Bearing Removal & Install Tool
Long Rear H-Arms
Rear Aluminum Slide
Rear Body Post
Rear Body Mount Collars
Pretty Sweet!
MRX-4X-1-wa-bearing-removal-replacement-tool.jpg   MRX-4X-body-mount-slide.jpg   MRX-4X-long-rear-h-arm-body-post-collar-slide.jpg   MRX-4X-magnesium-front-one-way.jpg
Special Thanks to Sponsors: Mugen Seiki USA, Futaba America, Murnan Modified Motors, VP-Powermaster Fuel & Faskolor
T-BODZ Terry B. is offline   Reply With Quote
Old 10-27-2009, 10:21 AM   #1304
Trader Rating: 18 (100%+)
Default MRX4X
Long Rear H-Arms
Rear Aluminum Slide
Rear Body Post
Pretty Sweet!
How much did the long H arms raise the back of the body.
I have two MRX4X cars, and on one of them I used the Evolva M3 arms. It did help with the rear bite, but the aluminum arms really look good, and I may want to add those to the second car.
thanks
[COLOR="Red"][FONT="Comic Sans MS"][/FONT][/COLOR]BRC358http://www.kamikazercracing.com
nearest barstool
brc358 is offline   Reply With Quote
Old 10-27-2009, 10:29 AM   #1305
wmay11's Avatar
Be careful with running GRP engines they are dogs to run in, streched my conrod after a couple of litres and was popping rods.
RX8 - Savox - Reds Racing - Ko - Contact - Enneti
wmay11 is offline   Reply With Quote
SEO by vBSEO 3.5.0
