Old 10-10-2009, 08:31 AM   #1216
wingracer's Avatar
Trader Rating: 22 (100%+)
+1 The Mugen box is my favorite regardless of the car.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 10-10-2009, 08:54 AM   #1217
mugenize1's Avatar
Default What starter Box to use
Originally Posted by Team Kamikaze View Post
This is the best starter box for your MRX 4X. here: http://kamikazetoysandhobbies.com/pr...?prod=MUGB0220
Really I was told to check the Ofna true start 10255 with the big motor. Thanks I think I will buy the Mugen Box 0220 Thanks again!!!!!!!!!!!
mugenize1 is offline   Reply With Quote
Old 10-10-2009, 09:23 AM   #1218
wingracer's Avatar
Uhg I hate that box. It's big, heavy and doesn't have the power for new super tight onroad motors. Stick with the Mugen.
Team Shepherd USA
Old 10-10-2009, 10:08 AM   #1219
mugenize1's Avatar
Post Starter for mugen MRX4X
Know that is what I want to hear, The power that I need to start the mugen, I heard that the ofna box has more power then the mugen but I never used any of them, But you answered the ? that I had next what has more power the mugen box or the ofna box Thanks alot bro!!!!!!!!!!!
Old 10-10-2009, 10:09 AM   #1220
Hi guys,
I do have difficulties setting up the brakes of my MRX-4X for one particular track.
The track has a fast open section which requires heavy braking at the end of the straight in order to slow the car down for a carousel. I usually set the brakes up (via EPA of my Futaba 3PK transmitter) to have strong braking effect with minimum skidding of the rear tyres in this braking zone.
After the carousel we have a technical infield with two extremely slow and tight hairpins. The car arrives at the hairpins with medium speed and will slide in the rear after a short distance once I hit the brakes. Because of the fast section prior to the carousel I canīt turn down EPA on the brakes, instead I will simulate ABS pulsing with my index finger (if you know what I mean to avoid lock-up. This helps, but is not consistent from lap to lap.
Any ideas on how to improve braking into the slow hairpins? Is anyone running drag brakes in 1/8th? This could probably help - Strong brakes after the straigth by hitting the lever and light braking with a drag brake set-up for the hairpins...
Looking forward to hearing your thoughts!
Best regards, Stefan
fulcrum2 is offline   Reply With Quote
Old 10-10-2009, 10:27 AM   #1221
mugenize1's Avatar
Post
Originally Posted by fulcrum2 View Post
Hi guys,
Use the end point adjustment for the brake side to limit the throw of the servo arm to a comfortable level. This will change with changing grip and layouts of different tracks etc. Use the knob to compensate for pad wear.
Best regards, Manny
Old 10-10-2009, 10:42 AM   #1222
wingracer's Avatar
Options:
1. Reduce brakes for the infield and back off sooner for the one at the end of the straight.
2. Keep the brakes high for the one at the end of the straight and just use a quick stab of the brakes for the infield to help the car rotate.
3. Set-up some drag brake for the infield and use push brake at the end of the straight.
Team Shepherd USA
Old 10-10-2009, 11:05 AM   #1223
Thanks a lot for yor feedback Manny and wingracer!
What is the best way to set up drag brakes on the MRX? I figure if I do it via throttle/brake servo trim I will create a lot of dead play on the throttle side as a side effect. Do you know if some of the pros use drag brake in 1/8th? Is this a common technique?
Old 10-10-2009, 02:00 PM   #1224
wingracer's Avatar
I have heard that Burch uses drag brake but I don't know for sure.
As far as setting it up, you need to tighten or loosen the thumb wheel on the brake rod to adjust it. Setting it with trim will result in a huge dead space on throttle. Once it's set, one or two clicks back on the trim for fine tuning in warmup should be ok with out screwing everything up.
Team Shepherd USA
Old 10-10-2009, 02:45 PM   #1225
mugenize1's Avatar
wingracer is correct that is the way I went on my setup,!!!!!!!!!
Old 10-10-2009, 02:50 PM   #1226
Thanks again guys, much appreciated
Old 10-10-2009, 11:09 PM   #1227
choisan's Avatar
has anyone tried to use the evolva's front and rear steering hubs on 4x? the evolva's can set the lower c.g. of the wheel's axles.
choisan is offline   Reply With Quote
Old 10-11-2009, 02:50 AM   #1228
Suspended
Send a message via ICQ to Roelof
The wheel axle will always stay in the center of the wheel and so on the same hight.....
I believe you can set the axle also forward/backward changing the wgeelbase, that will do more.
Roelof is offline   Reply With Quote
Old 10-11-2009, 05:37 AM   #1229
wingracer's Avatar
You could use the Shepherd eccentric uprights. Pietch used them at the worlds.
Team Shepherd USA
Old 10-11-2009, 08:49 AM   #1230
choisan's Avatar
i know Piestch used it in the world, but the Shepherd's parts are very expensive. this is why i think of using evolva, i do not know evolva's not the same feature as Shepherd's.
