Old 09-10-2009, 07:42 PM   #1171
Grenade10's Avatar
Trader Rating: 37 (100%+)
Originally Posted by FF25510 View Post
guys, need help
except the rear body mount post, does MRX4X rear upright fits MRX3
thanks
There are some MRX-3 uprights on E-Bay currently if you're looking.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 09-10-2009, 11:11 PM   #1172
Originally Posted by Francis M. View Post
Mike hasn't posted here in months...
I know that his car is pretty standard except for YBslow lightened drive train parts and the Taller rear mount with a protoform Body....His set up has been posted here a few pages back....
Chicky03 is more active in these boards and finished 3rd at the Nats behind Mike and Paolo.
I'm guessing Mike S., Ralph Burch, and Paul C./chicky's setup wouldn't be to far off from each other.
Does anyone know what pipe/header combo that Mike used for the Nats?
jepjepjep is offline   Reply With Quote
Old 09-11-2009, 11:31 AM   #1173
epowr_Racing's Avatar
Default Rear Kyosho Mod
Just wanted to share some pics of my MRX-4X with you guys,
Think, Feel, Operate: Control The Power Of Dreams...
Serpent 966TE,.21 Flash Novarossi, AE TC-6 ,17.5 R Speedpassion, Xray NT1 2011 Spec, .12 Novarossi, Ko Propo radio & Servos
epowr_Racing is offline   Reply With Quote
Old 09-11-2009, 06:52 PM   #1174
wingracer's Avatar
Trader Rating: 23 (100%+)
I don't know but I haven't seen him use anything but a 2015 in years.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 09-12-2009, 12:17 AM   #1175
Wanabrc's Avatar
Trader Rating: 70 (100%+)
Nice car.
Wanabrc is offline   Reply With Quote
Old 09-14-2009, 09:32 AM   #1176
djmachinist's Avatar
Originally Posted by chicky03 View Post
We all ran bascially the same setup. It was Mike's setup from Ft.myers but we all ran R rear hubs for stability and moved the rear body supports on top to the inner hole, that made the car chatter less and be more consistent. The track had super grip! The only other thing that was different on my car was I switched the rear wheel base to std/long instead of the -3mm mod. For me it was easier to drive with 32/35. For the main we went to 35/37 and I wish I would have made it short again, Better luck next time, I guess
Paul
Paul,
Did you use the longer upper rear arms and the inside upper arm pin location
with the R rear hubs?
Oh....., P. A. Watson says Hello, and he still thinks you are the best slot racer he ever saw!!
Dale
djmachinist is offline   Reply With Quote
Old 09-14-2009, 09:44 AM   #1177
wingracer's Avatar
Dale
He is, I seen it
Team Shepherd USA
Old 09-14-2009, 02:20 PM   #1178
thanks,
Originally Posted by Wanabrc View Post
Nice car.
Old 09-15-2009, 08:44 AM   #1179
mugenize1's Avatar
guys, need help
thanks
Ok I found this item on ebay. You mite like to look at, Ebay item # 170382183988 - MUGEN SEIKI MRX 3 REAR UPRIGHTS H0179 MRX-3 MRX3 NEW. this item has 3 Days left. Check it out
mugenize1 is offline   Reply With Quote
Old 09-15-2009, 01:35 PM   #1180
FF25510's Avatar
Originally Posted by Boz View Post
I may have some. I'll swap some for a set of MRX2 front uprights(new)
thanks guys
FF25510 is offline   Reply With Quote
Old 09-15-2009, 04:14 PM   #1181
mugenize1's Avatar
thanks guys
Your Welcome
Anytime,
Old 09-17-2009, 01:02 PM   #1182
Default Stiffer Plastic??
Does anyone know anything about stiffer mugen Plastic parts that were rumored to be used by Robert Piesch at the Worlds?
Dale
Old 09-17-2009, 01:12 PM   #1183
Roelof's Avatar
Send a message via ICQ to Roelof
Those parts were supplied to the factory drivers because they suspected it would be hot weather. Before the event I talked to RickV and he said he would not use the harder plastics but I do not know if he did....
In the very past (1991 I belive) BMT did the same and because BMT became world champion there was a special Austin kit. Over here in Holland the harder plastics were just to fragile because the colder weather we have.
Do not think you do need those parts to go faster, you won't go any faster.....
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 09-17-2009, 07:42 PM   #1184
chicky03's Avatar
Send a message via AIM to chicky03
Paul,
Dale
Mike and I used the X upper arm with the shortest position, Ralph used the X in the long position.
Cool, Tell PA I said hello and he was not shabby himself!! Next year for the scale worlds I'm making a come back, hopefully I remember how to do it and don't look a beginner
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 09-18-2009, 04:03 AM   #1185
Paul,
Thanks for the upper arm location info you used at the Nats.
So, You are going slot racing with Monster HP and very little aero help!
Good Luck!!
I race GTP at PA's place, chassis's and bodies are similar to the scale cars,
but with C-can power. You have to drive these things, not just hold full
throttle like you would driving the wing cars.
Dale
