Old 09-05-2009, 12:38 AM   #1156
Roelof's Avatar
Send a message via ICQ to Roelof
Originally Posted by epowr_Racing View Post
Yep i do agree, is not for all conditions, if i do remember the issue at the worlds was the lack of traction,
The explenation can be found in the presentation of the Xray T2 where 2 different cars were made, one stiff chassis for the US where foam tires (high grip) are used and one with a more flex chassis for Europe wher rubber tires (lower grip) are used.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 09-05-2009, 08:36 PM   #1157
epowr_Racing's Avatar
Yep ! that right, Roelof the Xray T2 is the perfecr example of how this mod works, and let us not forget one mod at the time, don't go changing mods on the radio plate,rear bodie post, and rear shock mnt, cause you wont see the effect of the mod.
Think, Feel, Operate: Control The Power Of Dreams...
Serpent 966TE,.21 Flash Novarossi, AE TC-6 ,17.5 R Speedpassion, Xray NT1 2011 Spec, .12 Novarossi, Ko Propo radio & Servos
epowr_Racing is offline   Reply With Quote
Old 09-07-2009, 02:27 PM   #1158
djmachinist's Avatar
Default Congrats Mike Swauger!!!
Mike,
What a year you and the MRX4-X have had!!!!! Second at the Worlds,
and now US National Champion!! Great Job for the TQ spot to my fellow
Texan Ralph Burch!
Mike, when you rest up and take a deep breath, how about posting a
commentary from you about the week long nationals. What your thoughts
are and maybe a few words about the 'Worlds' experience.
Dale
djmachinist is offline   Reply With Quote
Old 09-09-2009, 09:31 AM   #1159
Originally Posted by djmachinist View Post
Mike,
Texan Ralph Burch!
Dale
Sure is quite on this thread......Hm.........Was it something I said?!!!!
Dale
Old 09-09-2009, 10:22 AM   #1160
Francis M.'s Avatar
Mike hasn't posted here in months...
I know that his car is pretty standard except for YBslow lightened drive train parts and the Taller rear mount with a protoform Body....His set up has been posted here a few pages back....
Chicky03 is more active in these boards and finished 3rd at the Nats behind Mike and Paolo.
I'm guessing Mike S., Ralph Burch, and Paul C./chicky's setup wouldn't be to far off from each other.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 09-09-2009, 11:39 AM   #1161
FF25510's Avatar
Default MRX3
guys, need help
except the rear body mount post, does MRX4X rear upright fits MRX3
thanks
FF25510 is offline   Reply With Quote
Old 09-09-2009, 11:41 AM   #1162
wingracer's Avatar
Trader Rating: 23 (100%+)
Originally Posted by FF25510 View Post
guys, need help
thanks
I'm not sure. Probably would but have never tried.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 09-09-2009, 11:47 AM   #1163
wingracer's Avatar
I just went and found one of my old 3 rear uprights to compare. The pivot balls are spaced further out on the 4 then on the 3. Maybe you could make it work somehow but I think you'd be a lot better off finding some 3 uprights.
Team Shepherd USA
Old 09-09-2009, 05:04 PM   #1164
Trader Rating: 15 (100%+)
Originally Posted by Francis M. View Post
I only changed the swing arm to the M3 unit... The car has better turn in and at the same time more predictable with the rear of the body mounted higher in the rear....
What is differant from the stock X arm to make the turn in better? Are you using the M3 hub carrier also?
THE DOCTOR is offline   Reply With Quote
Old 09-09-2009, 05:12 PM   #1165
wingracer's Avatar
No the M3 H arm is longer which raises the rear of the body. The increased rake increases downforce across the whole body, increasing grip front and rear. There is no change in suspension geometry at all, it is merely an aero tweak.
Team Shepherd USA
Old 09-09-2009, 06:07 PM   #1166
FF25510's Avatar
thanks again, no more MRX3 parts here and i want to ran it until new car released.
Old 09-09-2009, 06:40 PM   #1167
I thought he was saying that he was using the A arm. Thanks Sean.
Old 09-10-2009, 02:31 AM   #1168
Boz
guys, need help
thanks
I may have some. I'll swap some for a set of MRX2 front uprights(new)
Boz is offline   Reply With Quote
Old 09-10-2009, 05:31 AM   #1169
MugenDrew's Avatar
Trader Rating: 28 (100%+)
Dale
!Way to go Mike and Ralph!
No were just enjoying the shit eating grin on our faces .
Next stop some race in Brazil.
MugenDrew is offline   Reply With Quote
Old 09-10-2009, 06:33 PM   #1170
chicky03's Avatar
Send a message via AIM to chicky03
We all ran bascially the same setup. It was Mike's setup from Ft.myers but we all ran R rear hubs for stability and moved the rear body supports on top to the inner hole, that made the car chatter less and be more consistent. The track had super grip! The only other thing that was different on my car was I switched the rear wheel base to std/long instead of the -3mm mod. For me it was easier to drive with 32/35. For the main we went to 35/37 and I wish I would have made it short again, Better luck next time, I guess
Paul
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
