Old 08-20-2009, 11:58 AM   #1111
chicky03's Avatar
Send a message via AIM to chicky03
Originally Posted by Wonderkid View Post
Anybody knows what are the differences between the usual mugen white springs 1.9mm and the new mugen blue springs which is also 1.9mm?
thanks
I have never seen them but I imagine they have less coils so the spring is stiffer using the same wire. They would be stiffer than yellows.
Paul
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 08-21-2009, 01:24 PM   #1112
wingracer's Avatar
Trader Rating: 22 (100%+)
I don't see any mention of a new blue spring. They all ready make two blue springs, a light blue and a dark blue. Both are pretty soft for 1/8th use.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-21-2009, 02:05 PM   #1113
John Doucakis's Avatar
Default Robert Pietsch's record breaking MRX4
Reporting from the World Championships currently being held in Lostallo Switzerland I have posted some photos of Robert Pietsch's car which has Top Qualified the event, breaking both the 10 minute record as well as the lap record.
If you watch closely you'll notice that the upper deck is not secured to the middle block but it is floating. There are two tie rods on each side of the fuel tank keeping the chassis rigid to its front/back movement but flexible to its left/right movement. Very smart... Serpent also followed this design for this race and it might be available as an option in the future.
Many more photos here, including Alberto Picco's Mugen and Mike Swauger's Mugen
http://jdracing.blogs.se
John Doucakis is offline   Reply With Quote
Old 08-21-2009, 02:31 PM   #1114
Francis M.'s Avatar
I've been following your blog... Thanks for the updates and pictures..
How is the traction at the worlds track and also tyre wear?
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 08-22-2009, 11:29 AM   #1115
CanyonCarverR1's Avatar
Interesting stuff on this car. It also has the lower rear shock mount moved out wider, and very long H-arms.
CanyonCarverR1 is offline   Reply With Quote
Old 08-22-2009, 11:49 AM   #1116
wingracer's Avatar
And Shepherd uprights. If you look close you can see the blue aluminum eccentrics in them.
I think the long H arms are Kyosho. Nearly everyone is using those things.
Team Shepherd USA
Old 08-23-2009, 08:25 PM   #1117
mugenize1's Avatar
Hello Everyone just posting some pic's of my MRX4X
It has aluminum pulleys.
mugenize1 is offline   Reply With Quote
Old 08-23-2009, 08:30 PM   #1118
mugenize1's Avatar
Here some more pic's
Old 08-24-2009, 05:26 AM   #1119
GMartinez's Avatar
Trader Rating: 85 (100%+)
Congrat's Mikey & the Mugen Team see ya @ the Nat's
GMartinez is offline   Reply With Quote
Old 09-01-2009, 04:05 AM   #1120
djmachinist's Avatar
Default New stiffer Plastic
I wonder if Mugen will offer the stiffer plastic parts that were said
to be supplied to Robert Pietsch at the Worlds?
Dale
djmachinist is offline   Reply With Quote
Old 09-01-2009, 05:32 AM   #1121
Trader Rating: 18 (100%+)
Default MRX4X
I am using the Kyosho uprights on one of my MRX4x cars.<second car has the stock uprights>
It does give the rear of the car much more traction. Kyosho has two size uprights in the package. If you do make the change, use the smaller of the two uprights. It will raise the rear floating body support approx. 8mm. There is a very small amount of dremmel work on the uprights, and you will also need 4 small washers as spacers<two per side>
I can really feel the difference when I drive both cars. This change, and also the change to the P909 body is working great. Now I need to change over the second car.
[COLOR="Red"][FONT="Comic Sans MS"][/FONT][/COLOR]BRC358http://www.kamikazercracing.com
nearest barstool
brc358 is offline   Reply With Quote
Old 09-01-2009, 06:23 AM   #1122
M7H
M7H's Avatar
I think you mean the Kyosho body mount arms, and not the uprights....
Serpent
M7H is offline   Reply With Quote
Old 09-01-2009, 07:23 AM   #1123
Default MRX4X
You are correct that they called body mounts. We just refer to them as rear uprights.. I believe the Mugen part number is HO466B if I remember right.
nearest barstool
Old 09-01-2009, 07:36 AM   #1124
mugenize1's Avatar
What are the Kyosho part # to use on the MRX4X.
Old 09-01-2009, 07:44 AM   #1125
Default Mugen
I dont recall the Kyosho part number, but just order the rear floating body mount and it will come in that package. You will get some other items that wont be needed. Be sure and get the parts for the Evolva M3, and not the older style Evolva.You will also need four small spacer washers, and also a Dremel. Use the shorter of the two mounts.
nearest barstool
