Old 07-20-2009, 01:11 PM   #1081
djmachinist's Avatar
Drew,
Have you played with the 3 pin clutch anymore?
Any thoughts?
Dale
djmachinist is offline   Reply With Quote
Old 07-20-2009, 06:28 PM   #1082
MugenDrew's Avatar
Trader Rating: 30 (100%+)
If I'm the one your referring to than YES. I have stayed with .4mm shoe to bell clearance at this time. Have only had the time to try different sized drilled holes and spring tension.
At this point I would drill one set to say 3.6?(it's an English sized bit) or 3.75 mm. and another set at 4.0mm or the English equivalent.
This clutch is much smoother than the 4 pin. However as traction builds I will always have a 4 pin ready. Wham Bamm THANK YOU MAMA!
I'm running a MAX POWER XL9, 16/49 first. It is summer time here in Florida so we are running on tracks that have not seen alot of racing, but have seen alot of rain and the azzfualt temps are running a close third place to Arizona and Hell. With the MSR spring, .4mm gap and the 3.75 drilled shoes spring tension has hovered around .7 to .9 . Very drivable and not eating shoe's.
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 07-20-2009, 07:11 PM   #1083
YBSLOW's Avatar
HA HA............ It ws only 117 today, but the pool was a nice 84.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source
POWER MASTER Fuel,
Protoform Bodies, Avid Bearings
YBSLOW is offline   Reply With Quote
Old 07-20-2009, 07:35 PM   #1084
Boz
Trader Rating: 23 (100%+)
When drilling the holes, are you using the outer dimple mark to drill the hole?
Boz is offline   Reply With Quote
Old 07-20-2009, 07:36 PM   #1085
lavaandy's Avatar
where are you drilling? is it in one of the mark spots? thanks
lavaandy is offline   Reply With Quote
Old 07-20-2009, 10:11 PM   #1086
asw7576's Avatar
Flyweights Questions :
Do you guys use : ultra light weight ( 4mm holes ), light weight ( 3mm holes but original mugen seiki ), normal ( no holes, solid ) ?
My friend one time said to me : I should consider to use normal flyweights ( no holes, solid ), more punch he said. I'm currently using light weight version ( 3mm holes ), and I feel the punch is mild ( eventhough I already use ultra hard spring 1mm depth )
What do you think guys ?
Old 07-21-2009, 01:51 AM   #1087
asw7576's Avatar
Friends:
My LHS still runout of protoform 909, so my next alternative probably Blitz Lola R09.
Is BLITZ LOLA R09 body good to use ?
Old 07-21-2009, 05:30 AM   #1088
Thanks for the reply, Yea, its hot and muggy here in Houston also, but not
much rain this summer. Gulf Coast raceway has re-surfaced their track and
we have been running quite a bit of practice the last two weeks preparing for
the SWS series race this coming weekend.
I also have tried the 3 pin clutch using your suggestion from your previous
posting of one 3.5 mm hole put near the end of the flyweight, msr spring, .4 mm gap, spring tension at .82. The clutch is indeed very smooth. I am running
a Murnan Flash 21 with a 16/50 First gear. However, I will more than likely run
an aggressive 4 pin clutch at the SWS series race this weekend. Our track is
tight with some fairly long short chutes. You really need the bottom end grunt
to get out of the corners. The traction on this fine grain asphalt is very good
now with just a few people running on it with no sugar water. I'm sure with a
few more cars running the track the traction will be insane.
Thanks for your help,
Dale
Old 07-21-2009, 10:00 AM   #1089
MugenDrew's Avatar
The Dimple farthest away from the hole for the flywheel pin. Drill by hand, no power tools. The flyweight will fit snug on the flywheel pin when new. Do not ream it. After the first run the flyweights will fit perfectly.
Lighter flyweight will require more engine rpm to enguage the clutch. Higher in the power band, more "punch" It will also have less stored energy behind it because it is lighter. More slip, easier to drive.
Old 07-21-2009, 12:33 PM   #1090
lavaandy's Avatar
great info thanks for answering the question
Old 07-22-2009, 12:15 AM   #1091
@asw7576
Yes, go for the Blitz body. We had a major race here on my local track and the Blitz R09 set TQ against a strong field equipped with Zytec´s and P909´s.
I suggest to mount it 15mm in front of bumper.
fulcrum2 is offline   Reply With Quote
Old 07-22-2009, 06:25 AM   #1092
Default Who makes
Originally Posted by asw7576 View Post
Friends:
Who makes this body?
InstantTilt is offline   Reply With Quote
Old 07-22-2009, 06:40 AM   #1093
Default Toledo Setup
Hey,
Anyone have a setup for Toledo?
Old 07-22-2009, 05:27 PM   #1094
MugenDrew's Avatar
Got some p.m.'s for pic's
Yeah the pics stink, but you get the idea
Old 07-22-2009, 05:34 PM   #1095
Trader Rating: 18 (100%+)
Default Mugen MRX4X
Can any one tell me the difference in handling from going to a lighter shock oil in the front, compared to staying with the same weight oil, and moving the shocks inwards one hole.
Right now I am using Mugen 600 front, 800 rear. Mugen white springs front and rear
[COLOR="Red"][FONT="Comic Sans MS"][/FONT][/COLOR]BRC358http://www.kamikazercracing.com
nearest barstool
brc358 is offline   Reply With Quote
