Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-09-2009, 12:49 AM   #1066
M7H
M7H's Avatar
Originally Posted by asw7576 View Post
ear diff ? Is there any reason not using it ?
Due to the incredible corner speed, with a diff you will loose engine power on the rear inner wheel....
In the end, everybody wants to run a.....
M7H is offline   Reply With Quote
Old 07-09-2009, 03:42 AM   #1067
asw7576's Avatar
Sorry M7H, I'm not trying to argue with you.... I know you are 1/8 expert. But I don't see incredible cornering speed from 1/8 cars vs. 1/10 cars, except on the straight lane.... bigger engine is faster on straight lane. In my home track, the lap times between 1/8 and 1/10 cars are only 2 seconds difference.
On roads || Xray nt1 || Mugen Seiki mrx4-r, mtx4, mtx3 prospec || Tamiya msx, m03, m04 || Yokomo mr4tc-bd || Associate L4
Off roads || Xray xt8 || Hobao hyper8
Radio || Futaba 3pk & 3pks
Old 07-09-2009, 04:10 AM   #1068
M7H
M7H's Avatar
Maybe not on all tracks, but certainly at my home track...
When I drove the Serpent Quattro (some years ago ), ball diffs where normal, but if you had your diff set to loose, you could hear the engine revving up....
Old 07-09-2009, 06:26 AM   #1069
Roelof's Avatar
Send a message via ICQ to Roelof
With the Sprint era the diff was more tightened for a better steering, finally with the design of the Excel the solid axle was standard for a better steering and a light rear axle.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 07-09-2009, 08:29 AM   #1070
Default Tire Width.
Has anyone been able to get a Track Width of 262mm with 61.5mm Tires?
InstantTilt is offline   Reply With Quote
Old 07-09-2009, 08:04 PM   #1071
Default 909 Body.
How slammed is the front of the 909. Should i mount it as low as it will go?
What is the best way to raise the back end in the air?
Old 07-10-2009, 08:23 PM   #1072
CanyonCarverR1's Avatar
Use these:
http://www.ybslowinc.com/products.php?item_id=102
CanyonCarverR1 is offline   Reply With Quote
Old 07-12-2009, 07:15 PM   #1073
Will reducing rear anti-squat reduce oversteer under acceleration?
Old 07-12-2009, 07:18 PM   #1074
Send a message via Yahoo to sheeley
widen your front end a little
sheeley is offline   Reply With Quote
Old 07-12-2009, 07:28 PM   #1075
Thanks for the suggestion but it doesn't really answer my question.
Old 07-12-2009, 07:40 PM   #1076
np, I dont even know what anti-squat is lol
Old 07-12-2009, 09:17 PM   #1077
wingracer's Avatar
Technically speaking, the car doesn't have an anti squat adjustment. Yes I know you can mix and match the pin blocks but I really wouldn't advise this.
Sean. Certified speed crazed mowron.
www.ashfordhobby.com
wingracer is online now   Reply With Quote
Old 07-12-2009, 10:18 PM   #1078
asw7576's Avatar
anti squat : rear lower hinge pins position slightly upward ( front position is higher than rear). The effect : as the name implies, it resists squating on full throttle. Definetely it is wrong approach to fix car's understeering / oversteering problems.
Don't play with this.... trust me... i've been there..... waste of time.
If your car get some oversteer, widen the rear track width, let say 262 - 264mm. Extra Toe In, lets say 3 degree, make sure rear suspension is not too soft and Always use new tires before testing new setup or before racing !!! Some people sometimes too stinggy to use new tires.
Guys : wingracer, francis, fulcrum2
I think I solve the understeering problem..... like you guys suggested:
1. Body problem ( T530 vs. Frizzbee ). Frizzbee is not prefect, but much2 better than T530. I will buy 909 as soon as my LHS has it.
2. Tires. Brand new tires really solve poor handling problems. Sometimes I'm too stinggy to open new box of tires ..... From now on.... I promise to use new tires !!
Got B3 yesterday
Old 07-13-2009, 04:49 AM   #1079
senna555's Avatar
Anyone know the exact difference between the rear upright on the mrx4, mrx4r and mrx4x?
As far as the position of the set screw for upper arm?
This exclusive Ferrari only membership club has many benefits. Including:
Anti overtaking assurance-Been overtaken? Feel a bit silly? Don't worry, we'll rule out the other party, even if it's embarrassingly obvious that they're faster than you
Ferrari International Assistance - Making it up as we go along for over 100 years
senna555 is offline   Reply With Quote
Old 07-17-2009, 04:34 PM   #1080
The 4 set screw is 2mm further away from the chassis. The wheel will also be .5mm closer to the chassis (relationship of the center line of the lower pivot balls and the center of the contact patch).
MugenDrew is offline   Reply With Quote
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
