Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-02-2009, 04:13 AM   #1036
Originally Posted by T-BODZ Terry B. View Post
Yo Brother!
Mine in the Mail yet? Hope so...
T Dawg
I got mine in the mail yesterday, very nice piece!
Thanks Brad & Roxanne
Dale Jones
djmachinist is offline   Reply With Quote
Old 07-02-2009, 12:01 PM   #1037
MrSlow's Avatar
hello
new to 1/8 scale, basic question...
i am installing a body for the first time and realize that unlike 1/10 and 1/12 cars you cant raise or lower the rear body mount. as it is now the body seems really high in the back. is truing the tires the only way to lower it?
MrSlow is offline   Reply With Quote
Old 07-02-2009, 04:09 PM   #1038
sm1nts2escape's Avatar
You can raise and lower the rear body mount with the different arms that com in the kit.The x version has you install the long mounts.
In construction: Xray t2009
Previous car: MRX4X / MR21R01A/Murnan Modified 35+21 Cordoba
www.301raceway.com
www.cwhits.com
www.murnanmodified.com
sm1nts2escape is offline   Reply With Quote
Old 07-02-2009, 04:11 PM   #1039
CanyonCarverR1's Avatar
Originally Posted by MrSlow View Post
hello
If it's an MRX4-X it came with two sets of "H-arms" that hold up the rear body mount. One set is longer than the other.
Side note - most of us are raising the rear of the body to the maximum allowed by the rules in order to increase downforce. Even to the point of buying extra long aftermarket "H-arms".
CanyonCarverR1 is offline   Reply With Quote
Old 07-02-2009, 04:11 PM   #1040
Itried the zytek and the 909 at exactly 11.5 in front of bumper.Zytek handled great 909 pushed.Moved the 909 to 12.5 and got alot of steering but rear would come loose under normal breaking.The zytek was the best body I ever used.
www.301raceway.com
www.cwhits.com
Old 07-02-2009, 05:41 PM   #1041
MrSlow's Avatar
so does this mean that the molded cut line on a body (mine a Parma R11) may be way off from where you cut? the cut line as the body now sits on my car is way high in back and not parallel with the ground...
Old 07-02-2009, 06:45 PM   #1042
Mount that body off of the rear dimples for the rear body post. Make sure both the front and rear mounts are rotated towards the front.
If I remember correctly you will want to use the short front body post plus the 2mm shim.
Find an old set of tyres and cut them to 63mmF/70mmR, ASSuming the car is set-up and ready to run. Put the car with these tires on a set-up board and mark around the body by laying a sharpie on it's side. That's what you cut...
MugenDrew is offline   Reply With Quote
Old 07-02-2009, 07:16 PM   #1043
wingracer's Avatar
Never go by those cut lines. Just cut the flashing off, mount it then trim to fit.
Sean. Certified speed crazed mowron.
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-03-2009, 08:55 AM   #1044
MrSlow's Avatar
thanks everyone!
Old 07-03-2009, 10:08 AM   #1045
TommyBlazin's Avatar
thats a good way to go about it, obie1!!
Mugen MRX4X... Murnan Modified's for power..
Maxy's Pro Racing Fuel
I'm so fast that last night I turned off the light switch in my hotel room and was in bed before the room was dark. - Muhammad sting like a bee Ali.,.,.,
TommyBlazin is offline   Reply With Quote
Old 07-05-2009, 05:28 PM   #1046
asw7576's Avatar
Sorry guys, .... Can I expect more cornering speed ( without pushing on medium speed corner ) by removing front stabiliser and adding 2mm shim underneath front upper arms ?
Thanks.
On roads || Xray nt1 || Mugen Seiki mrx4-r, mtx4, mtx3 prospec || Tamiya msx, m03, m04 || Yokomo mr4tc-bd || Associate L4
Off roads || Xray xt8 || Hobao hyper8
Radio || Futaba 3pk & 3pks
Old 07-06-2009, 09:42 AM   #1047
Francis M.'s Avatar
Thanks.
The car might be hard to drive in other sections with no front sway bar...
MUGEN SEIKI /Airtronics/Enneti Tyres/NINJA/YBslow/J-GO PAINTS
Francis M. is offline   Reply With Quote
Old 07-06-2009, 02:42 PM   #1048
Thanks.
I wouldn't remove the front stabilizer. Find the "Hudy setup guide" online, you'll find the key to your issue in there.
Old 07-06-2009, 04:29 PM   #1049
Yes sir...
Thanks.
No responce, no corner entry...
Post your set up and a link to the track your having this issue with.
Old 07-06-2009, 08:54 PM   #1050
asw7576's Avatar
Yes sir...
okey....
FRONT :
Track Width : 252mm
Ride Height : 7mm
Camber Angle : 2.5 deg LEFT , 2.0 deg RIGHT
Upper Arm Spacer (Caster ) : 2mm _ neutral
Toe Out : 1 deg
Rebound Stop ( Downstop ) : 0
Lower Arm Spacer ( Wheelbase ) : 0 _ short wheelbase
Upper Arm Spacer ( Roll Center ) : 1mm shim ( i'm going to replace it with 2mm shim )
Anti Roll Bar : flat ** ( i'm going to remove it )
Steering Ackerman : B
Front Damper : 2 holes, white spring, 450w, hole #2 from inside
Tire : Kawahara 35
REAR :
Track Width : 262mm
Ride Height : 9mm
Camber Angle : 4.0 deg LEFT , 3.5 deg RIGHT
Toe In : 2.5 deg LEFT, 2.5 deg RIGHT
Rebound Stop ( Downstop ) : 7
Upper Arm Spacer on Uprights ( Roll Center ) : 2mm shim
Upper Arm Position ( Upper link ) : outside_ shortest upper link
Lower Arm Suspension mount block ( Roll Center ) : 4.5
Anti Roll Bar : stock _ 3mm
Rear Damper : 1 hole, white spring, 450w, hole #2 from inside
1mm shorter wheelbase on rear suspension arms
Body Mount Arm : Highest
Tire : Kawahara 35
Body : Protoform T530 ( maybe this is also the culprit ).
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
