Old 09-27-2007, 12:33 PM   #91
Originally Posted by M7H View Post
-rumour mode on-
the "push" type of flyweights might give the Ninja engines more bottom punch.....
-rumour mode off-
Very good point indeed! Same as the Orion clutch upgrade.
twoo is offline   Reply With Quote
Old 09-27-2007, 06:36 PM   #92
choisan's Avatar
Originally Posted by asw7576 View Post
I won't buy that.
I still believe 4 clutch weights are the best and most reliable system than 3-shoe type.
The reason to change clutch weight & flywheel I think 3-shoe type are cheaper and simpler to produce.
one thing i noticed when shimo- kyosho driver who came to race, he used serpent 3pcs clutch with tailor made kyosho clutch bell.
choisan is offline   Reply With Quote
Old 09-28-2007, 05:30 PM   #93
Seisick's Avatar
mrx4x available in the us middle of october
beware, it will be use by mugen team drivers at the worlds in argentina
in ten days!
good luck to the team at the worlds
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 09-28-2007, 07:00 PM   #94
asw7576's Avatar
in ten days!
Yea, good luck to mugen seiki team at the worlds !
Old 09-30-2007, 04:10 PM   #95
Slo-MTX4's Avatar
Send a message via ICQ to Slo-MTX4
Was talking to the Australian distributor and he said they were expected this week here.
Slo-MTX4 is offline   Reply With Quote
Old 10-02-2007, 07:25 PM   #96
26mugenmrx07's Avatar
guys what is the factory stock setting of ninja mr21-ro1 low end needle and the top main needle?
Thanks in advance'
301raceway
TEAM BILISRACING
26mugenmrx07 is offline   Reply With Quote
Old 10-03-2007, 06:33 AM   #97
jca2000au's Avatar
Trader Rating: 9 (91%+)
Thanks in advance'
I dont think they have factory setting. I have 2 x MR21R01A and both are difference. Just use your ears to listen when u first started.
jca2000au is offline   Reply With Quote
Old 10-03-2007, 06:34 AM   #98
jca2000au's Avatar
Can anyone confirm the body for –R will fit on –X with exact same position?
Old 10-03-2007, 06:38 AM   #99
sohlman's Avatar
Trader Rating: 89 (100%+)
Originally Posted by jca2000au View Post
Can anyone confirm the body for R will fit on X with exact same position?
Confirmed. The R and the X use the same body holes.
Steve Sohl
sohlman is offline   Reply With Quote
Old 10-03-2007, 06:40 AM   #100
jca2000au's Avatar
sohlman, Thank you
Old 10-03-2007, 06:47 AM   #101
Positive that request. Bodys are interchangable between R and X. X sits a bit higher in the rear, minor difference
fulcrum2 is offline   Reply With Quote
Old 10-15-2007, 11:17 AM   #102
bvalistic's Avatar
Trader Rating: 31 (100%+)
Questions?? curious
for all the people who tried the "x" , is it worth to convert or stay with the "r"...i've seen people who jump from r to x and the only car that i've seen run great is Chris V. and all the other car looks twitchy to me...feedback from those who drove it will be much appreciated by us mugen fans...thanks
p.s
if you changed something from "x" set up that works for you , please let us know
bvalistic is offline   Reply With Quote
Old 10-15-2007, 11:37 AM   #103
chicky03's Avatar
Send a message via AIM to chicky03
p.s
I have the X and it is better. You can make all the setups the same for the X that were on your R but now you have more tuning options that you did not have before. I think it is worth it.
Paul
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 10-15-2007, 11:56 AM   #104
C Verano's Avatar
p.s
The X is good..People just need to work on their set-up for it. With all the adjustments on the car it should be comfortable for everyone to drive.
RC Target, Capricorn RC, Matrix Tires, KO PROPO America, PowerMaster Fuel, Absolute Hobbyz, Bellybutton Paint
C Verano is offline   Reply With Quote
Old 10-15-2007, 12:02 PM   #105
aturbotony's Avatar
p.s
First what do you drive? Second are you fast? Third would you know how to make the X work for you?and this list can go on and on. So before you make a statement like "it looks very twitchy"ask other people driving the X what they think about it. As for me the f^$king thing works GREAT
Tony Thompson / Mugen Seiki USA / RC America / Airtronics / Flashpoint Fuel / Novarossi USA /Jgo paints / DeSoto Racing/ Murnan Modified Motors / Zac Project Tires / My Wife and Kids /
aturbotony is offline   Reply With Quote
