Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 05-10-2009, 07:32 PM   #886
TommyBlazin's Avatar
does anyone have a link/or know where to buy the 7mm higher than the standard X rear body mount h-arms? i thought yb slow made them, didnt see on there site
Mugen MRX4X... Murnan Modified's for power..12r5.1...LRP..SMC...Ko Propo...TQ Racing..
Maxy's Pro Racing Fuel...Novarossi.....
I'm so fast that last night I turned off the light switch in my hotel room and was in bed before the room was dark. - Muhammad sting like a bee Ali.,.,.,
TommyBlazin is offline   Reply With Quote
Old 05-10-2009, 11:17 PM   #887
Roelof's Avatar
Send a message via ICQ to Roelof
I know some are using the Serpent H-arms
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 05-11-2009, 12:29 AM   #888
M7H
M7H's Avatar
Never seen that, I do see some using the kyosho arms, with a small modification to make it fit....
In the end, everybody wants to run a.....
M7H is offline   Reply With Quote
Old 05-11-2009, 01:56 AM   #889
asw7576's Avatar
If I want to increase steering ( medium to low speed steering ), lowering the height of rear wing so the body can be more streamline, is this technic help ?
Or do I simply remove the front sway bar ?
On roads || Xray nt1 || Mugen Seiki mrx4-r, mtx4, mtx3 prospec || Tamiya msx, m03, m04 || Yokomo mr4tc-bd || Associate L4
Off roads || Xray xt8 || Hobao hyper8
Radio || Futaba 3pk & 3pks
Old 05-11-2009, 10:07 AM   #890
the m3 stock ones? and on the serpents, is it a direct fit?
Old 05-11-2009, 12:37 PM   #891
M7H
M7H's Avatar
Mugen and Serpent are not interchangable.
Mugen:
http://www.abc-rc-shop.nl/catalog/fl...X_BLAD_13.html
Serpent:
http://www.abc-rc-shop.nl/catalog/fl..._Assembly.html
With Serpent, the bodymounts are mounted lower on the uprights, that's why they are wide at the bottom.
As far as I know, you get 2 or 3 different lenghts of body arms with a Mugen kit, but still the longest arm is not long enough to lift the rear far enough, a Kyosho arm is just this bit longer....
Yes with the M3 arms, you just have to cut them a bit with a knife.
Old 05-11-2009, 01:32 PM   #892
Francis M.'s Avatar
I use the YBslow body mount that raises the body 5.5mm and it just replaces the actual body mount where the rear bodypins go to.... You use all the stock floating hardware from Mugen....
MUGEN SEIKI /Airtronics/Enneti Tyres/NINJA/YBslow/J-GO PAINTS
Francis M. is offline   Reply With Quote
Old 05-11-2009, 01:52 PM   #893
Roelof's Avatar
With the serpent arms spacers must be used
Old 05-11-2009, 02:30 PM   #894
[quote=M7H;5798498]Mugen and Serpent are not interchangable.
Mugen:
Serpent:
Yes with the M3 arms, you just have to cut them a bit with a knife.[/QUOT
ok arms on the way..m3...they look very tall...lol...i wont need a mrx5 when they come out, ill have a 3mm conver X,R,M3..lol it'll be covered..
Old 05-11-2009, 04:13 PM   #895
Ok Guys I Have 2 Questions I Need Help With
1. What postion (up Or Down Front and Rear) do you put the ECCENTRIC Hubs For The Most Steering
2. By Increasing Front Track Width What Happens Or Narrowing The Front Also What Happens When You Do The Same To The Rear
dfilo456 is offline   Reply With Quote
Old 05-11-2009, 05:44 PM   #896
Mount anybody's body post in place of the Mugen mounts and you can jack it to the moon. I like the machined aluminum ones that are intended as front body post. You can buy 1/4-20 nylon screws at homedepot or ace, borrow somebodies 1/4-20 tap and re-thread the outer body support screw holes.
Front high, locating tab will be at the bottom of the bulk head.
Rear low, locating tab will be at the top of the bulk head.
Eccentric H0188 will offer the most offset and don't forget about T0154 which will offer a little less offset for less dramatic of an effect.
I would suggest going to Hudy.net and down loading the set up book for any of there set up systems.
The wider the front the less steering response you will have. The wider the rear the more steering response you will have. That's the basic's of it.
MugenDrew is offline   Reply With Quote
Old 05-11-2009, 06:18 PM   #897
Yep that's what happens to snake sh-t at the "FORT"..."EXPLODED VIEW"
Old 05-11-2009, 07:31 PM   #898
+1
gotmotor is offline   Reply With Quote
Old 05-12-2009, 01:04 AM   #899
M7H
M7H's Avatar
Old 05-12-2009, 05:25 PM   #900
quicky, with the r uprights/upper arms on the x..do i mount the r upper arms in the innermost or outtermost position, did mod for most rear traction...thanks
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
