MRX-4X
Old 09-23-2007, 11:28 PM
  #76
Originally Posted by Taylorm
......i just started in 1/8th this year (but have only raced once due to work) and caught on real fast...if you can drive a .12 sedan, you will catch on and be HOOKED...........
maybe your right lets see what happens...
rick ross is offline
Old 09-26-2007, 11:27 AM
  #77
Erock's Avatar
Default Parking Lot set-up
Chicky,
I ran your parking lot set-up this weekend on our local track that has seen better days.....man, that car ran great!
I can't thank you enough for all the help.
Keep up the good work.
T-bodz, what up dude? Eric here from Kansas City, you know the guy that ran the Delta at the pro series last year in Blue Springs, Mo. Yeah, I have moved over to a Mugen now.
Erock is offline
Old 09-26-2007, 01:39 PM
  #78
T-BODZ Terry B.'s Avatar
Originally Posted by Erock
Chicky,
How's it going Eric?
Glad to see you're still racing .... welcome to the MRX club!
Are you lov'in it or what?
Maybe I'll make it back up that way next season. Had too
much going on this season with my newborn..... The Boss
cut my out of state racing by 40% this year!... ugh!
Got to go out of state 3 times only with the other 8 races
in TX.
Take care!
Terry
T-BODZ Terry B. is offline
Old 09-26-2007, 06:27 PM
  #79
Suspended
when is the complete kit coming out and the price?
MERCCER4LIFE is offline
Old 09-26-2007, 06:45 PM
  #80
choisan's Avatar
check it out from pro-s-futaba.co.jp, they have it on pre-order.
choisan is offline
Old 09-27-2007, 02:24 AM
  #81
M7H
M7H's Avatar
Originally Posted by jca2000au
Wait for full completed kit. It should be release in 2 weeks, from what i heard the clutch is difference too but you wont get that in conversion kit.
yep....
They went to the 3 pins push type of clutch.....
M7H is offline
Old 09-27-2007, 05:05 AM
  #82
sohlman's Avatar
Trader Rating: 92 (100%+)
Default MRX4-X Kit
Pics & specs on: http://www.mugenseiki.com/menueefi.htm
sohlman is offline
Old 09-27-2007, 07:12 AM
  #83
nytaurean's Avatar
Default clutch
What's the advantage of this 3 shoe clutch? The 4 shoe clutch by mugen has been one of the most consistent and reliable clutches in 1/8th scale on road.
nytaurean is offline
Old 09-27-2007, 07:41 AM
  #84
M7H
M7H's Avatar
-rumour mode on-
the "push" type of flyweights might give the Ninja engines more bottom punch.....
-rumour mode off-
M7H is offline
Old 09-27-2007, 08:33 AM
  #85
Roelof's Avatar
With the 4-shoe clutch in a same configuration it will act the same but no one ever did take care to give it a try or did take it in production.
But the 3-shoe will give a better pressure balance of the clutchshoe against the clutchbell.
Roelof is offline
Old 09-27-2007, 09:30 AM
  #86
Seisick's Avatar
just wondering
the 3 shoe weights are captured on the pin right? does this
mean that you can now use more gap without fearing of blowing
the weights?
Seisick is offline
Old 09-27-2007, 10:12 AM
  #87
sohlman's Avatar
Originally Posted by Seisick
just wondering
the weights?
Probably not, but not sure. It may just create a propellor out of your clutch if the gap is too big.
sohlman is offline
Old 09-27-2007, 10:40 AM
  #88
Roelof's Avatar
That I solve way ago....
Attached Thumbnails MRX-4X-clutch1.jpg   MRX-4X-clutch2.jpg   MRX-4X-clutch3.jpg
Roelof is offline
Old 09-27-2007, 11:11 AM
  #89
May not want to increase the gap, as much as "lighten" the flyweights. Since they're pinned, you can either drill a hole or shave a little off the length, which ultimately creates a higher rev prior to moving the spring/clutch.
Darint is offline
Old 09-27-2007, 11:44 AM
  #90
asw7576's Avatar
I won't buy that.
I still believe 4 clutch weights are the best and most reliable system than 3-shoe type.
The reason to change clutch weight & flywheel I think 3-shoe type are cheaper and simpler to produce.
asw7576 is offline
