Old 05-06-2009, 05:49 PM   #856
advfuel's Avatar
Trader Rating: 29 (100%+)
Originally Posted by ChartRacing View Post
To all MRX-4X owners I have tried all kinds of stuff to glue the brake pads.(contack, apoxy, glue and the list goes on)Some work better then others but all fail sooner or later. What is the most common glue to use.
I also had the same problem, when they did stick I had break fade through a final. Some people may disagree but I changed to the K factory break which has a twin disc and a great pad arrangement. Never had a problem since.
http://www.kfactoryracing.com/produc...6901&pageNum=1
advfuel is offline   Reply With Quote
Old 05-06-2009, 06:28 PM   #857
CanyonCarverR1's Avatar
I use shoe-goo and have never had a failure, but I don't use a ton of breaks.
CanyonCarverR1 is offline   Reply With Quote
Old 05-06-2009, 06:50 PM   #858
MugenDrew's Avatar
Trader Rating: 28 (100%+)
Originally Posted by TommyBlazin View Post
wow that ride height is low, I run 7mm in rear and 6 up front..might be good for a qualifier tho..i have to try, how does it affect the car going that low?
Set up tyres. Roll out.
If you start out with a 76mm rear tyre and a 16/49 1st your roll out will be 32.5mm.
a 70mm rear tire provides ABOUT the same with a 17/49. Note the change in pinion.
Looking at the kit set up sheet;
Rear starting diameter is 76mm and ride height is 7.5mm
If we ended with a 70mm tire, ride height would be 4.5mm. Radius effects ride height in the main NOT diameter.
So I'm .5 mm high.
Set it and forget it.
If you chase ride height between every run your never driving the same "droop" value.
Learn something 1fstcarovtheweek
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 05-06-2009, 08:47 PM   #859
TommyBlazin's Avatar
yea i feel safe at the ride height im at, i know about the drop value not being the same as you change spring height, actually do you know the TRUE droop value that should be maintained mugendrewoftheyear?
Thinking on maybe a Tekno 1/8 Nitro Buggy?
TommyBlazin is offline   Reply With Quote
Old 05-07-2009, 02:06 AM   #860
Boz
Trader Rating: 23 (100%+)
Originally Posted by PROVK View Post
I have noticed a few of the top drivers are using the standard rear wire sway bar and not the adjustable blade type, is there any reason for this?
the wire sway-bar can be made stiffer then the adjustable sway-bar set a 90deg by moving pivot balls down on the sway-bar.
Boz is offline   Reply With Quote
Old 05-07-2009, 02:49 AM   #861
PROVK's Avatar
Trader Rating: 14 (100%+)
Thanks Boz
George V
Mugen Seiki
Max Power Engines GRP Tires Nitro X Fuels "Mugen Blend"
www.rrcsa.org.au
PROVK is offline   Reply With Quote
Old 05-07-2009, 04:35 AM   #862
MugenDrew's Avatar
LOL that was pointed at Harrison. That all depends on what your rebound stop is set at. I have never heard anyone mention a specific set of numbers.
Old 05-07-2009, 06:46 AM   #863
Hi there,
has anybody tested the new 3-shoe clutch? Got so many parts for the 4-shoe type in my box and like the performance of this "old" system.
Just wondering if there is much to be gained with the newer version?
Looking forward to hearing your thoughts!
Regards
Stefan
fulcrum2 is offline   Reply With Quote
Old 05-07-2009, 06:57 AM   #864
sohlman's Avatar
Trader Rating: 89 (100%+)
Originally Posted by fulcrum2 View Post
Hi there,
Regards
Stefan
I switched over mid-season last year and it seemed to be more consistent, lasted longer and smoother off the corners. The 4-shoe still works great.
Steve Sohl
sohlman is offline   Reply With Quote
Old 05-07-2009, 07:00 AM   #865
iwk2much's Avatar
Fulcrum:
I am a big fan of the 3 shoe clutch. It is progressive and simply feels better. It is consistent and gave me marked increase in fuel economy. Clutch shoes life also improves. Now, I can't, rather don't, set it up with the same aggressive engagement that you can achieve with the 4 shoe, to get the results above, but it is, IMO, well worth the compromise.
Try it.
Hi there,
Regards
Stefan
Mike Strack
iwk2much is offline   Reply With Quote
Old 05-07-2009, 10:10 AM   #866
wingracer's Avatar
Trader Rating: 22 (100%+)
I too love the 3 shoe clutch. I have been able to get very aggressive set-ups on it and they work great. Just takes a little something different that I'm not telling.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 05-07-2009, 10:33 AM   #867
that aint right
Old 05-07-2009, 11:30 AM   #868
Loveless's Avatar
Chartracing, i use 3M contact cement, but first i scuff the brakes and brake plates with sand paper, then wipe clean with acetone or alcohol, make sure not to get ur fingers on either of these items where the glue will be, otherwise oil from ur fingers will leave residue, then i put 1st coat of glue, when dry i follow with another then when its dry i join them and clamp in a vise over night, hope this helps.
AIRTRONICS/KEVLAR R.D./MUGEN FUEL/PARMA, CENTRAL BODIES/MUGEN SEIKI/PICCO ENGINES/JP ENGINES/ BELTRANS WHEELS AND HOBBIES, KAMIKAZI RACING.
"Free your mind, and your ass will follow"...
Loveless is offline   Reply With Quote
Old 05-07-2009, 03:00 PM   #869
Something to do with...shims? Perhaps an inner bearing race?
Old 05-07-2009, 03:22 PM   #870
Roelof's Avatar
Send a message via ICQ to Roelof
The Orion square spring does add a little bit something different
For the inner bearing I use the one with a flang as the side belt tensioner does.
Oh yes, our own red shoe, aluminium clutchbell and hard coated T7075 lightweight gears.
(one is titanium )
Old 4 pin type:
http://members.ziggo.nl/tooms/ftp/jhp/DSCF2657.JPG
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
