Old 01-13-2009, 11:29 AM   #631
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
Originally Posted by Ron C. View Post
avs,
I can work on a set up sheet that is more thorough which can be posted or emailed over. But here is the basic info:
FRONT:
Track width : 252 mm
Ride Height : 6 mm
Camber : -1.5
Toe : out 0.5 (each)
Shock position : B
Spring : Grey
Shock Oil : 600 (stock)
Steering Ackerman : A
Droop : 1.5 mm up travel
Wheel Base : Short
REAR:
Track width : 262 mm
Ride Height : 7 mm
Camber : - 3.5
Toe : in 1.5 (each)
Shock position : C
Spring : Grey
Shock Oil : 700
Rear Block : 5.0
Droop : 2.0 mm up travel
Floating Body Mount : Long: Part# H0466F (Use outer hole)
GEARING:
16/50 1st
20/46 2nd
Side Pulley : 26T
WHEN YOU GOING BACK OUT
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 01-13-2009, 11:31 AM   #632
Loveless's Avatar
Loveless,
Checking to see you've found where the camber issue is? I believe you race at Crystal Park?? Let me know so I can help solve it and get it ready for the Kamikaze Race.
We were at CP yesterday. Swauger was testing the MRX4-X on the new layout.. Changed a few things from the previous set-up and by the end of the day, we have the car set where it's good for the new track.
Thanks Ron i appreciate it, i'll be at crystal this fri and sat and maybe sunday, i'll try the new set up you have posted to see if it werks for me.
AIRTRONICS/KEVLAR R.D./MUGEN FUEL/PARMA, CENTRAL BODIES/MUGEN SEIKI/PICCO ENGINES/JP ENGINES/ BELTRANS WHEELS AND HOBBIES, KAMIKAZI RACING.
"Free your mind, and your ass will follow"...
Loveless is offline   Reply With Quote
Old 01-13-2009, 06:11 PM   #633
avs
avs's Avatar
avs,
FRONT:
Ride Height : 6 mm
Camber : -1.5
Shock position : B
Spring : Grey
Wheel Base : Short
REAR:
Ride Height : 7 mm
Camber : - 3.5
Toe : in 1.5 (each)
Shock position : C
Spring : Grey
Shock Oil : 700
Rear Block : 5.0
GEARING:
16/50 1st
20/46 2nd
Side Pulley : 26T
Ron, thank you very much for sharing, i appreciate it.
avs is offline   Reply With Quote
Old 01-14-2009, 10:06 AM   #634
Ron C.'s Avatar
Default Zytec
Originally Posted by motojon View Post
Hey Ron can you send me your set-up please and what type body being used
Hi Jon,
I tested first with the Central body and was good.
Swauger was testing with the Zytec. He had me use his body after, and found it to be smoother and predictable when negotiating around corners. It was also more stable especially in the new areas of the track where traction was still green.
Mugen Seiki / MSR / Airtronics / Enneti Tyres / O'Donnell Racing / Checkpoint / Hobbico
Ron C. is offline   Reply With Quote
Old 01-14-2009, 10:09 AM   #635
Ron C.'s Avatar
I plan to be at CP Sunday, how about you?
Old 01-14-2009, 10:17 AM   #636
Ron C.'s Avatar
You're welcome guys... always.
We'll be at CP this weekend and ofcourse next weekend. If you need any help with the car, feel free....
Old 01-14-2009, 10:28 AM   #637
Send a message via Yahoo to motojon
Good I hope to see you there then
My Gpa(RIP)
motojon is offline   Reply With Quote
Old 01-18-2009, 07:16 PM   #638
Thanks Ron and to Mugen team for sharing the setup for Crystal Park. It made it easier to drive.
trebronpay is offline   Reply With Quote
Old 01-21-2009, 08:58 PM   #639
asw7576's Avatar
Can anyone teach me again about steering ackerman A,B,C ?
Is this ABC has something to do with aggressiveness vs smoothness of how the car turns ?
Or, is it something to do with the radius ( the radii ) how the car complete a circle ? I mean wide circle vs small circle ?
I am using C at the moment. I need more steering power ( without understeering ) at the middle of a tight corner. My intial steering is already abundance. The middle steering is problem, it turns wide..... very wide.
Thanks people.
Old 01-21-2009, 10:19 PM   #640
Woodlands Racer's Avatar
Thanks people.
Instead of adding more Ackerman by going to "B" or "A" you may want to try and adjust the "Caster" to give you more turn in. Unfortunately, any adjustment you make will effect all turns, sweepers and tigth hairpins. You will have to adjust the way you drive into the sweeper (slightly reduced steering) and you will then have all you need in a thight turn. I am also including a link that may help if you read the four pages of the ALIGNMENT section;
http://users.telenet.be/elvo/
Good Luck,
Roger
Roger Bourland
The Woodlands, TX
THIRD COAST RACING
Max Power/RC America - Mike's Hobby Shop - SRC Tires/RC America
Getting Faster With Age, Hope to see many more birthdays!
Woodlands Racer is offline   Reply With Quote
Old 01-21-2009, 10:29 PM   #641
Francis M.'s Avatar
Thanks people.
Using (a) will give you smoother turn in and more on power steering coming out of the turns.....
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 01-21-2009, 11:13 PM   #642
asw7576's Avatar
Thank you Francis and Woodland Racer.
Francis, when you said " Using (a) will give you smoother turn in and more on power steering coming out of the turns..... "
Is that also means less push on middle cornering too ?
Thank you.
2ndly, still in regards to push out at the middle cornering problems, my friend(s) in track tell me to put more caster ( more incline ). Oppositely, I read roelof's webpage to put less caster ( more vertical ). Huh ???
Old 01-21-2009, 11:36 PM   #643
Francis M.'s Avatar
Thank you.
Not sure what is causing the push in the middle of the corner for you.... I would just go with Ackerman A first and see how it goes. Some of the handling issues could also be just from the type of body you are using....
Old 01-22-2009, 09:04 AM   #644
Ron C.'s Avatar
Default CP
Hi Jon,
Hi Guys,
In connection with the type of body to use at CP... Swauger tested the new P909 body last weekend and was more happy with it all around (without any set up changes from the prior weekend).
I just thought of posting this here as an alternative or option on body choices... I personally am hoping to get one painted for myself to use this weekend.
Old 01-26-2009, 08:57 AM   #645
Francis M.'s Avatar
Just tried the Set Up most of the mugen team has been running....
