Old 01-05-2009, 04:20 PM   #601
It all depends on how much you want to spend the 35+21 tuned is about $620.00-$670.00 very good motor. Globs of bottom end and and a very strong mid range with good top end.
jp eagle r9 $850.00-$900.00 very costly!!!!!!!!!!!!!
lacks the low end that the 35+21 tuned has
But more than makes up for it with its top end it is stupid fast!!!!!!!!!!!!!!!!!!!!
It also depends on what track you plan on running at if 301 raceway is you track of choice then the top end of the jp eagle r9 or r7 will be more useful.
301 raceway is all about topend rpms!!!!!!!!!!
HoboShop is offline   Reply With Quote
Old 01-05-2009, 04:22 PM   #602
I also got a cyclone tc off ebay and planning to go to debbies.
hopefully it will arrive soon.
powerdrifter is offline   Reply With Quote
Old 01-07-2009, 02:53 PM   #603
Loveless's Avatar
Wingracer, need to know if i can get 3MM camber by doing the short wheel base mod to my car?.
AIRTRONICS/KEVLAR R.D./MUGEN FUEL/PARMA, CENTRAL BODIES/MUGEN SEIKI/PICCO ENGINES/JP ENGINES/ BELTRANS WHEELS AND HOBBIES, KAMIKAZI RACING.
"Free your mind, and your ass will follow"...
Loveless is offline   Reply With Quote
Old 01-07-2009, 06:47 PM   #604
wingracer's Avatar
Trader Rating: 22 (100%+)
I'm not sure what you are asking. The wheelbase mod and camber are two different things. I don't run the wheelbase mod so I'm probably not the one to ask.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 01-07-2009, 07:08 PM   #605
The short wheelbase will not prevent you from using 3mm camber all it will do is push your lower arm foward 3mm,great modification to do you will love it ..
WoodPecker is offline   Reply With Quote
Old 01-07-2009, 07:17 PM   #606
Pooh2's Avatar
Send a message via MSN to Pooh2
I agree 100% The cut arms r really great 4 the car!
MUGEN MRX5/CONTACT TIRES/DESOTO RACING/TEAM LOGIC
"Since the Bible and the church are obviously mistaken in telling us where we came from, how can we trust them to tell us where we are going"?
Pooh2 is offline   Reply With Quote
Old 01-07-2009, 07:24 PM   #607
Pooh2's Avatar
My bad, double post.
Old 01-08-2009, 09:24 AM   #608
Loveless's Avatar
Thanks Wood pecker, thats what i was asking, i guess i have to check something else to see why i only can 2.5 on the camber, i know its something minor, thanks for the help.
Old 01-08-2009, 09:27 AM   #609
wingracer's Avatar
If you are running the rear with a narrow track width or a lot of toe in the rear upright can bind on the arm right at the front pivot ball and prevent any more camber.
Team Shepherd USA
Old 01-08-2009, 11:01 AM   #610
Loveless's Avatar
Im using the 4.5 block with the correct track with, and i have the short wheel base mod on the car.
Old 01-08-2009, 11:19 AM   #611
the only reason why you would have a problem with your camber is your trackwidth is too narrow,the rollcenter 4.5 position has nothing to do with the camber recheck your trackwidth it should be at 267 to 262 any narrower should present you a problem with camber..
Old 01-08-2009, 01:50 PM   #612
Send a message via Yahoo to motojon
What exactly is the shorter wheel base affecting more turn in or turn out?
My Gpa(RIP)
motojon is offline   Reply With Quote
Old 01-08-2009, 01:51 PM   #613
Loveless's Avatar
I have it at the track width it calls out for on the MRX4X set up sheet which is 263MM.
Old 01-08-2009, 07:26 PM   #614
asw7576's Avatar
You get a more aggressive car, tighter cornering sumthing like that.
Old 01-08-2009, 11:44 PM   #615
avs
avs's Avatar
maybe a better way to understand what is wrong:
what is happening when you try to get more than 2.5degrees camber?
if the upper arm is bottoming out, the problem might be the turnbuckle in the upper arm is not threaded 'evenly' or 'equally'(can't think of a better term)
when you try to shorten the upper arm you are running out of thread on one end of the turnbuckle before the other end. in that case you just need to even it up.
avs is offline   Reply With Quote
