Old 08-20-2008, 01:06 PM   #466
Loveless's Avatar
Originally Posted by wingracer View Post
The yellow ones come with the kit. The black ones are the ones that originally came with the MRX-3. I believe they are still available as an option.
Thanks Wingracer, i'll check into those i have a serious breaking problem, dont know whether to fix mechanicly or by the radio, cant seem to stop without the car sliding around.
AIRTRONICS/KEVLAR R.D./MUGEN FUEL/PARMA, CENTRAL BODIES/MUGEN SEIKI/PICCO ENGINES/JP ENGINES/ BELTRANS WHEELS AND HOBBIES, KAMIKAZI RACING.
"Free your mind, and your ass will follow"...
Loveless is offline   Reply With Quote
Old 08-20-2008, 01:07 PM   #467
sohlman's Avatar
Trader Rating: 89 (100%+)
Originally Posted by Loveless View Post
Sohlman, Where do i get the pads the teflon yellows or the black?.
H0355 Black brake pads
H0359 Yellow teflon brake pads
Steve Sohl
sohlman is offline   Reply With Quote
Old 08-20-2008, 01:34 PM   #468
Loveless's Avatar
Thanks bro, i appreciate it.
Old 08-20-2008, 02:13 PM   #469
Lil Paul's Avatar
Originally Posted by PROVK View Post
Done that.
I even put on the smaller optional collet that comes with the engine.
Im stumped, as I said I am no noob and this has got me baffled
I actually have had to put a small washer on the end of the crankshaft before putting the thrust bearing assembly on. I have these small 3mm washers that have the exact OD of the crank, so it makes the crank 1mm longer which gives you more room to play with when shimming.
Lil Paul is offline   Reply With Quote
Old 08-20-2008, 05:20 PM   #470
I run the 35plus21 motors and they use a 5mm wide front bearing. I ordered bearings for my motor and they sent me the standard 6mm wide bearing once. I would check and see if you have the right front bearing in the engine. I have had no problems with crank length. All my motors use 3 to 5 shims in the thrust bearing to achive the right clearance. Just make sure the bearing is flush with the case in the front.
JASON MAC is offline   Reply With Quote
Old 08-29-2008, 07:55 PM   #471
CanyonCarverR1's Avatar
I'm getting ready to buy a MRX4-X to run a few races this fall at RAMS then next season. Can some of you RAMS guys recommend any parts I need for proper set-up. Also, what Novarossi engine are you all running, if any?
Thx,
G
CanyonCarverR1 is offline   Reply With Quote
Old 08-29-2008, 08:02 PM   #472
wingracer's Avatar
Trader Rating: 23 (100%+)
Thx,
G
I don't run at RAMS but the car comes pretty much ready to kick butt. The one piece motor mount is nice but not a must. I use a Serpent 16 tooth aluminum front pulley but most people use the stock plastic one. You might want to pick up a harder clutch spring. Either a MSR black or Orion CRF spring. That's about it.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-29-2008, 08:39 PM   #473
Thx,
G
The car is great out of the box. One peice motor mount & pressure chamber are the most common upgrades. Msr clutch spring is also really good. The rest of it is lightening the car. Titanium screw kits, turnbuckles, mid shaft, MSR light weight pulley adapters, ceramic bearings, ect. But that is all options and not really things you need to do right away. Come by the track and see me, we will get you setup for rams.
As far as Novarossi engines I run the 35plus21 Cordoba with the 2015 pipe. 359 and 35plus21 are really good motors as well. Also alot of guys are really liking the Picco motors. Fast and most of them are making run time.
Old 08-30-2008, 08:26 AM   #474
Thx Jason, can you recommend a parts dealer and someone carrying that engine?
Greg
Old 08-30-2008, 08:27 AM   #475
That engine being the Cordoba
Old 08-30-2008, 09:50 AM   #476
You can talk to Billy from Franciscan Hobbies. He can get what ever you need.
The Cordoba engine is a version of the 35plus21.
Old 08-31-2008, 04:37 PM   #477
Nehpets's Avatar
How far off the front bumper are you guys mounting the Pro-Line Frizbee?
I've already tried one and mounted it way too far back (Like 3mm off the front bumper...)
Maitland Off/On Road Radio Car Club - http://www.morcc.com/
Nehpets is offline   Reply With Quote
Old 09-01-2008, 02:53 AM   #478
Default Tyre wear
Hi there!
Whenever I run a long stint and use up a complete set of tyres I will end up with an incorrect split. Example: I true the tyres to 68F 75R and end the run with 60F 65R. What would you recommend to get more even tyre wear? Switch to a different shore combo F/R od tweak the set-up. What could I change on the chassis in order to have less wear on the rears?
Thanks a lot for letting me hear your thoughts!
Stefan
fulcrum2 is offline   Reply With Quote
Old 09-01-2008, 11:39 AM   #479
Send a message via Yahoo to motojon
are you running a softer shore in the rear or harder
motojon is offline   Reply With Quote
Old 09-01-2008, 11:48 PM   #480
Oops, I forgot to include this piece of information in the original post. I use 35 shore foam all around.
