Old 08-13-2008, 04:41 PM   #451
sm1nts2escape's Avatar
Trader Rating: 16 (100%+)
Just wondering how many of you adjust tweak?
sm1nts2escape is offline   Reply With Quote
Old 08-13-2008, 04:57 PM   #452
Originally Posted by sohlman View Post
Jim, Gotcha covered. Safe travels. And bring some HP, you'll need it.
see ya soon
got my new tundra so we are ready
I will have HP
Jim
DESOTO RACING--SERPENT-977 EVO- 2010/2016 FORGASS -PRES.
RED CUP RACING - EDS TOOLS- -BYRONS FUEL -NUGGETS RACING
PICCO RACING ENGINES - KO RADIOS - - FLORIDA WINTERNATS -winternats.com---R/C AMERICA
jrice is offline   Reply With Quote
Old 08-16-2008, 06:33 PM   #453
MugenDrew's Avatar
Trader Rating: 24 (100%+)
The 5, 5.5 blocks raise the roll center and will "loosen" up the rear. I set tweak at the start of the day, before the main and pay attention to adjustments in between.
MUGEN SEIKI NOVA ROSSI ENETTI TYRES HUDY PROFESSIONAL TOOLS
BYRONS FUEL AIRTRONICS RADIO EQUIPMENT PROTOFORM RACE BODIES
MUGEN RACING RC AMERICA AKA RACING NUGGETS RACING DESOTO RACING
MugenDrew is offline   Reply With Quote
Old 08-17-2008, 06:22 AM   #454
PROVK's Avatar
Trader Rating: 14 (100%+)
Hi Guys
I have done this a million times but first time with a Nova 21.
I am trying to install a mrx-4x clutch to a 35plus21 LC and seems like the clutch screw it too short and I cant get no end play with zero shims
Any help would be apprecaited
George V
Mugen Seiki
Max Power Engines GRP Tires Nitro X Fuels "Mugen Blend"
www.rrcsa.org.au
PROVK is offline   Reply With Quote
Old 08-17-2008, 06:38 AM   #455
choisan's Avatar
Few things to check, assuming you have pulled the shaft and in the same time push the copper collar in so as to ensure no freeplay, then put on the flywheel
1. there should be no shim in between the bearing and the copper collar(come with the engine)
2. if no shim was put, then you may see if the copper collar is too long(compared with any you have)
Hope it works!
choisan is offline   Reply With Quote
Old 08-17-2008, 06:53 AM   #456
PROVK's Avatar
Done that.
I even put on the smaller optional collet that comes with the engine.
Im stumped, as I said I am no noob and this has got me baffled
George V
Mugen Seiki
www.rrcsa.org.au
Old 08-17-2008, 07:30 AM   #457
choisan's Avatar
is your engine brand new? there may be some different scenario
if your engine had changed a new set of bearing, make sure the front smaller one(607Z) is inside the casing completely.
Pick a shorter collet.
see if both bearing inside the endbell are completely in(this seldom happens in mugen parts)
Old 08-17-2008, 08:00 AM   #458
What is the overall length of the crank shaft from the engine case? You must be dealing with a seating issue of some kind, in the case or in the bell.
Support those that support us
http://ActivRC.com http://TeamPowersUSA.net http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 08-17-2008, 09:39 AM   #459
wingracer's Avatar
Trader Rating: 22 (100%+)
If I remember right, Mugen used to have a shorter collar (the piece the thrust bearing rides on) for some other car. Maybe you somehow got a wrong one.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-19-2008, 07:52 PM   #460
Gear ratio/roll out?I was looking at the this sheet that came with my kit and I understand that a larger clutch bell decreases top speed and gives better accelaration as the chart shows but what i don't understand is the numbers on the left side of the page?I was guessing they were tire diameter but that didn't make sense to me because a larger tire should give a higher top speed correct?If it is tire diameter then the chart is saying that top speed should increase as the tires wear becasue the gear ratio number drops with the smaller diameter.I am confused.
Old 08-19-2008, 08:04 PM   #461
wingracer's Avatar
You are backward. A larger pinion (clutch bell) gives more top speed/less torque. Smaller gives more torque/less top speed. It's the same with tire size.
Team Shepherd USA
Old 08-19-2008, 08:10 PM   #462
wingracer's Avatar
Also, gear ratio does not change with tire size. Gear ratio is a factor of spurs, pinions and internal drive ratio ONLY. Tire size changes roll out. Roll out is the distance the car will move per engine rotation. Therefore, less roll out means less top speed (the car will travel a smaller distance for each rotation of the motor) but have more torque at the wheels for faster acceleration.
Team Shepherd USA
Old 08-20-2008, 06:29 AM   #463
MugenDrew's Avatar
First gear on the shift nob in a real car is the lowest number on the knob.
However first gear in the transmission has the highest numerical ratio.
The roll-out sheet is speaking numerically.
Old 08-20-2008, 01:18 PM   #464
Loveless's Avatar
Results depend on driving styles. I drive hard on the gas and hard on the brakes. During longer mains, the two teflon (yellows) will heat up and fade a bit. Won't notice anything in a qual. The black pads have good grip and don't overheat, but also don't last as long. The combo works best for me. And it does not matter which pad goes on which plate.
Sohlman, Where do i get the pads the teflon yellows or the black?.
AIRTRONICS/KEVLAR R.D./MUGEN FUEL/PARMA, CENTRAL BODIES/MUGEN SEIKI/PICCO ENGINES/JP ENGINES/ BELTRANS WHEELS AND HOBBIES, KAMIKAZI RACING.
"Free your mind, and your ass will follow"...
Loveless is offline   Reply With Quote
Old 08-20-2008, 01:46 PM   #465
wingracer's Avatar
The yellow ones come with the kit. The black ones are the ones that originally came with the MRX-3. I believe they are still available as an option.
Team Shepherd USA
SEO by vBSEO 3.5.0
