Old 07-17-2008, 04:44 PM   #421
sohlman's Avatar
Trader Rating: 89 (100%+)
Originally Posted by jrice View Post
i,am also looking for some COOL weather!!!!!!!!!!!!
Steve i wil have a supply of EMPTY RED CUPS for you to fill.
we are driving up be there Tuesday afternoon
See ya soon
Jim, Gotcha covered. Safe travels. And bring some HP, you'll need it.
Steve Sohl
sohlman is offline   Reply With Quote
Old 07-21-2008, 01:51 PM   #422
Built, new mrx-4x (3 tanks of gas to break in an engine anyway) for sale in the for sale forum
msg me for details.
Support those that support us
http://ActivRC.com http://TeamPowersUSA.net http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 07-27-2008, 08:17 AM   #423
choisan's Avatar
congratulation mr. vuga won the european champion
choisan is offline   Reply With Quote
Old 07-27-2008, 05:49 PM   #424
CraigX's Avatar
Trader Rating: 26 (100%+)
Send a message via AIM to CraigX
Mugen took the top 2 spots at the Euro's. Wonder what their setups were?
RC America, Xray, Hudy, Sanwa, Motiv RC, Gravity RC, Max Power America, Protoform, Avid, EA Motorsports, TQ Wire, Prolevel RC, Ulti, 5 Nines
CraigX is offline   Reply With Quote
Old 07-27-2008, 07:51 PM   #425
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
Awesome performance...
with good car and patience driving style, Mugen shows that they still the force to be reckoned.
too bad for sherperd and motonica. bad luck can happen in a strange time.
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 07-28-2008, 12:16 AM   #426
Default Ackermann
Hi there
Got some ?īs for ya:
On Sat I was out on the track and played with the ackermann setting. I could not improve my laptimes with the different settings but ended up wondering what we can achive by using the different options.
First, the X was in short wheelbase config and I started off with the A ackermann. Car was easy to drive. Then I changed to C, the car became more nimble and reacted faster to steering inputs. It seemed to me that it carried more corner speed from turn in to apex, but pushed more on throttle after apex. Just my imagination or does this makes sense from a technical standpoint as well?
How is the "jacking" effect of the front inside wheel affected?
Is the change from A to C giving more ore less ackermann effect? What do you guys usually run with the X in short config?
Thanks a lot in advance!
Stefan
fulcrum2 is offline   Reply With Quote
Old 07-28-2008, 07:55 AM   #427
racer x 1's Avatar
Trader Rating: 27 (100%+)
last i heard A had more ackerman. as far as i go i usually run A or C but it depends on the body that im using on that day. if i run a central then i use A, if i run the parma r-11 then i run C.
Matt Bell
Mugen MRX5 • Ae R5.2 • X6^3 • M11x • All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 07-28-2008, 10:12 AM   #428
MugenDrew's Avatar
Trader Rating: 28 (100%+)
The more angled the tie rods are when viewed from above or below the less the ackerman effect will be. The straighter the tie rods the more ackerman.
It is the difference in angle between the front wheels when turned. So more ackerman means the inside front wheel will be at a greater angle than the outside wheel. Jacking effect is provided by caster. So yes if you increase acerman you will be pushing the inside wheel down earlier. Now the lifting of the outside wheel I'll look into when I get home because I believe the inside wheel will hit it's mechanical travel limit(the holes the pivot balls pass through in the up rite) sooner which will cause an increase in turning radius there by limiting casters ability to lift the out side wheel. BLAA, BLAA, BLAA...
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 07-28-2008, 11:15 AM   #429
Francis M.'s Avatar
Having the inside rod moved all the way forward should give the car more ackerman and should be smoother coming in and have more steering coming out.... this should have the biggest difference in toe angle at full lock...
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 07-28-2008, 04:34 PM   #430
MugenDrew's Avatar
Remember our "bell cranks" center is opposite of the uprites, it's backwards.
Old 07-28-2008, 11:42 PM   #431
Ok guys, thanks a lot for your opinions.
Back to the original question:
What is giving more Ackermann effect: A or C?
Old 07-29-2008, 04:51 AM   #432
MugenDrew's Avatar
A most
D least
This was edited becuase I did not know what I was talking about...
Old 07-29-2008, 04:47 PM   #433
MugenDrew's Avatar
Sorry fellas I AM TOTALLY INCORRECT REGARDING ACKERMAN!!!!!!!!!!!!!!!
Set the car up with "A" making a left hand turn at 15 degs. on the right side of the car and the left showed 20 degs.= +5.
Same set up with "D" and the left showed 18 degs= + 3
I have LEARNED something and would like to thank Francis M.
Old 07-30-2008, 02:27 PM   #434
OK, this makes sense. With C or D we get more turn in but less steering on corner exit.
Thanks a lot! Stefan
Old 08-02-2008, 10:14 AM   #435
Trader Rating: 40 (100%+)
Default mrx4x
Do people put grease on the dogbones. I can only get 2 races and the solid axle and dog bones get pretty wore out. I didn't know if I put lube on them they would last longer or am I making it worse.
Also does anyone have recommendations on a cheap online store, since none of my local hobby shops carry mugen parts.
Scott
scott74dog is offline   Reply With Quote
