Old 07-01-2008, 11:10 PM   #376
mike jones's Avatar
Originally Posted by MUGEN SHOW View Post
has anyone to see the great darren ishitani
yeah, Darin is busy at work and had to take a break from racing
SHEPHERD MICRO RACING, CEFX, TEAM C, CONTRAST, PICCO, KO PROPO, NOVAROSSI, BYRON ORIGINALS FUEL, JACO, DCM HOBBIES, JGO PAINTZ
mike jones is offline   Reply With Quote
Old 07-02-2008, 09:30 AM   #377
Ron C.'s Avatar
Originally Posted by motojon View Post
well I dont think Friday will work since its 4th of July but hopefully Sat and Sun I'll be at C.P getting comfortable with the car if your going to be there.
Motojon, Ill be at Crystal Park this Saturday and will be more than happy to help you with your car. See ya.
Ron
Mugen Seiki / MSR / Airtronics / Enneti Tyres / O'Donnell Racing / Checkpoint / Hobbico
Ron C. is offline   Reply With Quote
Old 07-02-2008, 10:19 AM   #378
Send a message via Yahoo to motojon
Ron
Hey thanks I appreciate it I should be easy to spot bright orange body what time will you be there
motojon is offline   Reply With Quote
Old 07-02-2008, 10:24 AM   #379
Ron C.'s Avatar
No prob. Looking to be there around 11:00 am (more or less)...
Old 07-04-2008, 12:49 PM   #380
YBSLOW's Avatar
Default MRX-4X Lite-weight axles
New liteweight axles for MRX. These save 10 grams a set.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings
YBSLOW is offline   Reply With Quote
Old 07-04-2008, 07:13 PM   #381
wingracer's Avatar
Trader Rating: 23 (100%+)
Looks good. Might have to hit you up for a set.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-04-2008, 07:23 PM   #382
quietstorm76's Avatar
Those are beautiful
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 07-05-2008, 07:11 PM   #383
ran today for a few hours...had a great time at Crystal park . the car was awesome, Ron helped me out a little which was great. Man I must of ran 12 tanks today the car ran good with the track sloppy but man when the sauce was thrown down it really hooked up nice. Just really had a good time brought it home in one peice
Old 07-06-2008, 09:45 AM   #384
Default Locked front axle
I have seen in some shops a locked front axle as an option part.
Has anybody tried this? Lap time gained?
4WD braking and maybe more on throttle steering should be on the positive side. Negative side: less turn in speed/ turn in understeer
fulcrum2 is offline   Reply With Quote
Old 07-06-2008, 10:10 AM   #385
wingracer's Avatar
Technically that would be illegal. 4 wheel brakes are not allowed.
Team Shepherd USA
Old 07-06-2008, 01:47 PM   #386
Front wheel braking is allowed! It is not allowed to have independent brakes for the front wheels, but blocking the one-way´s and braking through the transmission is legal...
Old 07-06-2008, 02:54 PM   #387
wingracer's Avatar
You are correct, it has changed somewhere along the line. It used to just say "No 4 wheel brakes". I think I would prefer a diff over a spool but I still think our current drive train set up is best for most tracks.
Team Shepherd USA
Old 07-06-2008, 04:25 PM   #388
lil-bump's Avatar
Trader Rating: 83 (100%+)
I think the off power turn-in would be crap; due to both axiles being locked. IMO
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 07-07-2008, 06:57 PM   #389
sm1nts2escape's Avatar
Trader Rating: 16 (100%+)
How tight do you guys run your servo saver?Mine is all the way down/loose and was wondering if I should givie it a few turns.Thanks
sm1nts2escape is offline   Reply With Quote
Old 07-07-2008, 10:16 PM   #390
Originally Posted by sm1nts2escape View Post
Well I am new to the mrx so I am sure there are a few other people that have a better layout of there wires than me but here is how mine are routed.I ziptied them all together and stuffed them under and between the throttle servo.I got the futaba low profile servo that allows this but you could still probably stuff them between the throttle servo and the steering servo.
I got an Xray NT1 receiver case, turned the MRX4X bracket (the one that you normally stick the receiver to) back to front, and bolted the NT1 receiver case to it. Also, I had to cut off part of the aerial mount. The result is virtually no visible wires at all, looks very clean, and no need to use any double sided tape. I took a photo, but I don't have the necessary software to reduce it down to the small kb size limit for jpeg images on RCTech.
Jongo is offline   Reply With Quote
