Old 06-24-2008, 11:57 PM   #361
Thanks chicky
fulcrum2 is offline   Reply With Quote
Old 06-26-2008, 10:12 AM   #362
Send a message via Yahoo to motojon
Im in the process of auiring a Mugen this Sat. I want to know what type tires and bodys are being used, i will primarily run at Crystal Park and GRLARC
motojon is offline   Reply With Quote
Old 06-26-2008, 10:15 AM   #363
Oh and also gearing
Old 06-26-2008, 11:03 AM   #364
Team Kamikaze's Avatar
Originally Posted by motojon View Post
Oh and also gearing
35's and 37's on tires, and 16/20 or 17/21 on pinions, 45/49 on spur gears.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 06-29-2008, 08:03 PM   #365
Well I finally got my car thanks to Sam and his son at Kamikaze, i just need help with one thing though can someone put a pic of how they route their wiring and stuff, I'm running into problems every time I think I have a good routing.
Old 06-30-2008, 09:38 AM   #366
Ron C.'s Avatar
motojon, bodies being used at both tracks are Parma, Central, and some Protoform.
Personally, I use the Central Body.
Mugen Seiki / MSR / Airtronics / Enneti Tyres / O'Donnell Racing / Checkpoint / Hobbico
Ron C. is offline   Reply With Quote
Old 06-30-2008, 04:53 PM   #367
sm1nts2escape's Avatar
Trader Rating: 16 (100%+)
Well I am new to the mrx so I am sure there are a few other people that have a better layout of there wires than me but here is how mine are routed.I ziptied them all together and stuffed them under and between the throttle servo.I got the futaba low profile servo that allows this but you could still probably stuff them between the throttle servo and the steering servo.
sm1nts2escape is offline   Reply With Quote
Old 06-30-2008, 07:39 PM   #368
Any one have a basic setup for a mrx3???
I have a buddy that bought one and needs a starting point.
Mugen USA-FX Hobbies-Airtronics
TONY CLARK
STRICTLYSERPENT is offline   Reply With Quote
Old 06-30-2008, 08:29 PM   #369
mclarenwest's Avatar
Default GRP tyres
did anyone tried the GRP tyres on MRX? I had a problem in setting the car rear width to 263mm. The GRP rear tyre width is 63mm compare to other tyre makers 61mm. If i turn in too much on the rear width, the tyres will brush against the 2 towers holding the body poles. I have optimize the spacer in the rear upright, but it still dont look good. Any advise?
mclarenwest is offline   Reply With Quote
Old 06-30-2008, 09:12 PM   #370
rpoage's Avatar
On a X car place the two MUG H0189 spacers in back of the outer bearing in the hub and the problem will go away. The GRP has a different off-set so if you measuring the track width on the outside of the rim you need to remember that the GRP AJ/PJ is 63.5mm wide vs. most other rims at 60.2mm. That would mean a track width with most tires of 263mm would translate to 266mm with GRP PJ's (Assumes we are using track width to determine relative center lines of the drive wheels.)
Tire Type_____Kyo Red Box Rear___________GRP PJ Rear
Rim Width_____59.9mm___________________63.27mm
Rim Off-set____19.32mm__________________20.93mm
(thanks to Rick Davis (the suspender guy) for the rim numbers.)
rpoage is offline   Reply With Quote
Old 06-30-2008, 09:29 PM   #371
You are welcome John, glad that you are happy with our service, by the way We can help you with your wiring, just swing by the store with your car on Friday so we can route your wires clean.
Old 07-01-2008, 12:04 AM   #372
well I dont think Friday will work since its 4th of July but hopefully Sat and Sun I'll be at C.P getting comfortable with the car if your going to be there.
Old 07-01-2008, 12:12 AM   #373
You are correct, it's 4th of July on Friday, I'll be at the shop on Saturday and CP on Sunday.
Old 07-01-2008, 07:52 PM   #374
MUGEN SHOW's Avatar
Default curious
has anyone to see the great darren ishitani
MUGENRACING / AIRTRONICS / CORALLY / HOTSPOT
joshua bond
MUGEN SHOW is offline   Reply With Quote
Old 07-01-2008, 08:08 PM   #375
lil-bump's Avatar
Trader Rating: 82 (100%+)
Maybe that is because you see more mugens than snakes around you ?
In the time Serpent started to use the very easy breakable plastic that was a hated issue, people had more than 10 left side parts unused..... In the 12 years I drive Mugen (had the very 1st Sting) I had maybe 2 leftside parts unused. It is all about how strong the parts are....
Regarding Lipo's. So why using 1250mAh Lipo and a Brass tray and a regulator when 2/3A cells of 1500mAh are a lot cheaper and better in handling and give more time ?
If it is all about runtime you must have a least 2000mAh to gain a real advantage and still with current 1500/1600mAh 2/3A cells you can race one hour at least which is only done in the WC finals.
And what I said in another topic is we do drive in the rain and one drop of rain in the regulator can cause many problems and a lot of people do not take care to make the regulator rainproof as they do better with the receiver.
The NIMH may last longer (maybe) but the lipo will stay above 6 volts for the entire charge. Most regulators will alarm or shut-off at 6 volts. Your electronics will not see a voltage drop off. With a NIMH the electronics will see a voltage drop after some time. I use a lipo in my transmitter (1250mah) I can go 5 hours and only see a voltage drop of 1.2 volts.
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
