Old 06-04-2008, 04:09 PM   #346
wingracer's Avatar
Trader Rating: 22 (100%+)
Originally Posted by airtraficontr View Post
whats wrong whith the rod is it not bushed?
It is bushed but they will break at high RPM's. The motor is extremely tight when new and this really does a number on a rod so I would replace it after break in and maybe one race. After that it should be good if you keep the RPM's down on it. It makes a great motor for short and slick tracks but if you run somewhere like 301 with that super long straight I would go with a Nova based motor just for the superior rod strength. If you can find the motor Nova sold as the mule motor in their 2 motor set it would be a great budget motor. I would also check out the Picco's. The P7's and P9's make great power and seem to be pretty reliable.
wingracer is offline   Reply With Quote
Old 06-05-2008, 07:36 AM   #347
Rick Vessell's Avatar
If you put the crank and rod from the Speed version of the V Spec in you will not have any problems. I run my VZ-Rs this way and have no issues. Top speed is still down, but it's a very reliable engine.
Futaba, O.S. Engines, Trakpower, HB Racing, SpeedPassion USA, Eggroll Inc., Vesselli Racing
Rick Vessell is offline   Reply With Quote
Old 06-08-2008, 11:33 AM   #348
sm1nts2escape's Avatar
Trader Rating: 16 (100%+)
Finished my car yesterday and got it broke in.Fit and finish of the kit is excellent.I was really impressed.This is my first onroad car besides my hpi rs4 3 and it handles waay better even though it isn't even setup yet.Gotta love that downforce.Anyways I cant wait to run it with you guys at 301 and get blown awayI need some help getting it setup though.Thanks
sm1nts2escape is offline   Reply With Quote
Old 06-08-2008, 06:10 PM   #349
wingracer's Avatar
I'll be up there from time to time. Come find me if you need anything.
Sean Tabor. Big hairy dude wearing either a red Penske hat or if I can find it an RB hat.
Old 06-08-2008, 06:11 PM   #350
Suspended
Default 301
1 long straight how many rpm what kinda muscle you got off ? torque ?
airtraficontr is offline   Reply With Quote
Old 06-08-2008, 06:32 PM   #351
Suspended
Default torque
muscle get off the corners so fast you dont no what happened! we dont need 600. 00 dollar motors to get around the civic center its needs torque its the smallest track on the circuit.should i define torque. massive rotating mass like a three wheeler hiting the wall and nobody was killed yet cheers you guys
Old 06-08-2008, 06:40 PM   #352
wingracer's Avatar
I'm backward in that regard. A small track like Ft. Meyers I like a motor with monster top end. Why? Because on a track that short I can run a very low gear and keep the motor wound up all the time. Now on a long track like 301 I need a torque motor. You have to run such a high gear to keep from over revving the motor and throwing a rod that you need all the bottom end grunt you can get through the infield.
Old 06-08-2008, 06:50 PM   #353
Suspended
Default wingracer
rpm=fuel consumtion and motor wear i like grunt every wear i go massive low end and i dont kill the motor thats me thanks for the reply dan!cheers
Old 06-16-2008, 06:31 AM   #354
German Muscle's Avatar
these engines are designed to be pushed to 45,000 RPM on a regular basis. It wont wear them out any quicker.
German Muscle is offline   Reply With Quote
Old 06-16-2008, 09:49 AM   #355
Send a message via AIM to munrath
Sean,
Hit me up when you get time. I will PM you with my cell number. 301 is my home away from home... LOL
Mark Unrath
Tekno RC (RTM) / RadioPost / Tekin / Pro-Match Racing / AKA / PT Racing Oils/Diff Lube
Races for 2015:
PNB, AMS, E-Nats Warm-up, E-Nats, LCRC North East Challenge, RAC, LCRC Halloween, Badlands, ROAR Region 2 Series, and Local Club Racing
munrath is offline   Reply With Quote
Old 06-22-2008, 12:20 PM   #356
Well I got my mrx4x down on the track at 301 for the first time yesterday and am very pleased.The car was handling great and I feel alot more confident since switching from the rs4.Right now I am running the ho767 clutch spring that came in the kit.I am running a clutch gap of .40 and spring tension of .800.I could use a slightly later engaging clutch.I was told to try out the msr1001 clutch spring.How should I set the clutch up with this spring?I am running the yellow shoe.What is everyone else running?Also I am looking at getting the capricorn clutch and trying it out.Is anyone running it and what are your thoughts?Thanks
Old 06-23-2008, 06:36 AM   #357
wingracer's Avatar
With the silver spring go with .5 endgap and 1.1 on the spring.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
Old 06-23-2008, 09:14 AM   #358
chicky03's Avatar
Send a message via AIM to chicky03
I tried the 3 weight clutch this weekend set up with the weights full and it felt "heavy" to me. I used the MSR spring set at 1.8 with a .7 gap. I then tried it with the weights cut like the picture and it was much better. I had to lossen the spring to 1.3 but I still kept the .7 gap. I am not sure yet if it is better than the 4 weight clutch but it seemed to work pertty good like this. I do like the fact that the clutch felt good and I have a lot more room to work with the spring tension than the 4 weight.
Paul
Serpent America, Picco, Blitz Bodies, Team Titan, Desoto Racing, LRP, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa.
chicky03 is offline   Reply With Quote
Old 06-24-2008, 02:17 AM   #359
Default Spring rates
@chicky03
Any news on the Mugen spring rates? The old blue/yellow/black discussion about which one is heavier?
Thanks,
Stefan
fulcrum2 is offline   Reply With Quote
Old 06-24-2008, 06:47 AM   #360
chicky03's Avatar
Originally Posted by fulcrum2 View Post
@chicky03
Thanks,
Stefan
Here's an updated list:
Grey Rear: 33.3
White Rear: 40.7
Grey Front: 42.2
Red Rear: 46.6
Pink Rear 49.8
White Front:51.7
Yellow Front 53.9
Black front 67.5
An option if you need more steering is to run the red or pink rear springs on the front. Sometimes softer springs give less steering because the car dumps over too much but it's something to try.
Paul
