Old 05-22-2008, 06:53 AM   #316
MugenDrew's Avatar
Trader Rating: 28 (100%+)
Well a big KICK AZZ to ya Pual! Very usefull info to say the least. Thanks for sharing this. Good work on the r-10/11, thanks for those to.
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 05-22-2008, 07:08 AM   #317
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Paul do you have the blue springs to test?
Wondering how they fit in with the others.
J.Gonzalez is offline   Reply With Quote
Old 05-22-2008, 07:48 AM   #318
chicky03's Avatar
Send a message via AIM to chicky03
I don't, but if I can get a hold of some I will test them.
Paul
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 05-22-2008, 08:20 AM   #319
T-BODZ Terry B.'s Avatar
Thumbs up Spring Rate Chart!
>> FYI <<
Here's one that I've been using for the past few years.
It doesn't have the Yellow's & Pink's but it has the rest /
Mugen Gray, White, Light Blue, Purple, Dark Blue & Red
as well as some other Manufacturers Front & Rear.
Hope this helps!
T
Special Thanks to Sponsors: Mugen Seiki USA, Futaba America, Murnan Modified Motors, VP-Powermaster Fuel & Faskolor
T-BODZ Terry B. is offline   Reply With Quote
Old 05-23-2008, 03:38 PM   #320
ROBBIE C's Avatar
Send a message via AIM to ROBBIE C Send a message via Yahoo to ROBBIE C
Mugen message board is now on and live as of 5/23 2008
www.mugenracing.com click on message board create an account and start posting just that easy.
Hopefully this will help people with questions in-regards to setup tips and other frequently asked questions.
ROBBIE C is offline   Reply With Quote
Old 05-23-2008, 03:48 PM   #321
sm1nts2escape's Avatar
Hey guys I am building my first onroad kit a mrx4x to run at 301 along with my hpi and am new to onroad.I am wondering about the front roll bar setup.I looked at the setup sheet but didn't see any info on tuning it besides rotating the bar.My question is am I suppose to make the roll bars touch eacother when the arms are all the way down, flat or what?Thanks
sm1nts2escape is offline   Reply With Quote
Old 05-23-2008, 04:50 PM   #322
Trader Rating: 15 (100%+)
The ball should be inside of the cup and both sides should lay flat not up and down. Ask for me at the track and I can help you with the set up. Mike Keely
THE DOCTOR is offline   Reply With Quote
Old 05-26-2008, 05:44 PM   #323
Anyone know who is selling the brass battery plate for the new X?
Old 05-26-2008, 08:01 PM   #324
hey mike its Kevin Johnson I got mine from YBslow ordered it online with pay pal.
younghovaa is offline   Reply With Quote
Old 05-27-2008, 04:33 AM   #325
www.ybslowinc.com
Brian Berry is offline   Reply With Quote
Old 05-29-2008, 07:19 AM   #326
YBSLOW's Avatar
Default Titanium Rear Spool
we have the titanium rear spool for the MRX4-X now as well.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source
POWER MASTER Fuel,
Protoform Bodies, Avid Bearings
YBSLOW is offline   Reply With Quote
Old 05-29-2008, 02:23 PM   #327
grub's Avatar
gidday
can some one shed some light on the mrx-4x clutch set up im new to 1/8 and the clutch set up is diffrent to 1/10
do you just shim the inner bearing so it dosnt drag on the clutch shoe then put the shim in frount of the thrust bearing till you get .3 end play ?that how i read it ,as compeared to a 1/10 were you have a clutch gap then shim the inner bearing till you get the right end play
thanks in advance
This is my xray nt1!
There are many other xray nt1's like it, but this one is mine!
Without my xray nt1,I am nothing!
Without me, my xray nt1 is nothing!
pop corn anyone or maybe some fairy floss
grub is offline   Reply With Quote
Old 05-29-2008, 03:48 PM   #328
German Muscle's Avatar
Originally Posted by grub View Post
gidday
thanks in advance
your bearing/clutchbell shouldnt drag. Mine has no shims in between. You measure the gam in the end of the clutch nut and the spring nut.
German Muscle is offline   Reply With Quote
Old 05-29-2008, 05:22 PM   #329
wingracer's Avatar
Trader Rating: 23 (100%+)
To the best of my memory, Mugen has never said to shim the inside in their instructions though that may have changed with the X. Need to go look at the book. Either way I like to shim the inside so the bell does not rub the shoe. ALWAYS set the endplay FIRST! Then shim the back side to eliminate most of the play.
Oh, and try .4 mm.
wingracer is offline   Reply With Quote
Old 05-31-2008, 10:40 AM   #330
jt415gz's Avatar
Trader Rating: 29 (100%+)
Thumbs up
Hey people,
Anyone know the proper name and place to buy these two products listed below?
1) Roll Bar Handle (silver/chrome color)
2) Rear Wing Mount (body supports) these are the two round pieces that screw into the extreme left/right side of rear body mount. This part do not come in the kit unfortunately.
3) Rear adjustable roll-bar for MRX-4X
Please link any sites that sell them.
I posted a pic and it shows two white rear body supports with flathead screw slots and adj. anti roll-bar
Thanks,
-jT =]
jt415gz is offline   Reply With Quote
