Old 05-12-2008, 01:20 PM   #271
C.Smith's Avatar
Originally Posted by grub View Post
going to start building my mrx4-x tonight does anyone know any tricks and sercrets the pros use when building the car??
Get a 3mm tap and tap all the hole where a machine screw goes into plastic, dont forget the lock tight(blue) especially on the set screws for the pullies,
The kit should go togeather pretty easy
C.Smith is offline   Reply With Quote
Old 05-12-2008, 05:37 PM   #272
Rob D's Avatar
Can anyone give me a good start set up for 301. thanks
Rob D
RC America-X Ray- Team Scream -Pro Line-TQ Wire -LRP-Boom Rc Grapichs & Design - RJD Racing-
Devil Spit Traction Compound
Rob D is offline   Reply With Quote
Old 05-12-2008, 06:06 PM   #273
Trader Rating: 15 (100%+)
Shocks in the stock position, front swaybar flat, rear swaybar 1.5mm in, front droop 0, rear droop 8 or 9, front toe out 1/2 a deg., rear toe in 2 deg., front camber -2 deg., rear camber -1.5 deg., white springs all around, central body, 38 shore tires all around, 6mm front ride height and 7mm in the rear. MAKE SURE THAT YOU BRING LOTS OF HORSEPOWER!!
THE DOCTOR is offline   Reply With Quote
Old 05-12-2008, 07:04 PM   #274
grub's Avatar
dose anyone have a set up for a low/no tight tecnical traction track?
ower track with 3 hairpins one sweeper and 65 meter straight with a tight s secton off the frount 25 meter straight.many thanks in advance
This is my xray nt1!
There are many other xray nt1's like it, but this one is mine!
Without my xray nt1,I am nothing!
Without me, my xray nt1 is nothing!
pop corn anyone or maybe some fairy floss
grub is offline   Reply With Quote
Old 05-12-2008, 08:56 PM   #275
Rob D's Avatar
Thank you for the fast response. What kind of horse power should I bring. What type of motor would be ok. Thanks again.
Rob D
Old 05-12-2008, 09:37 PM   #276
35 plus 21 Novarossi would do great.
Old 05-13-2008, 01:10 AM   #277
German Muscle's Avatar
Picco P9R Evo 2, If you have the money then yes get a Novarossi 35 Plus 21
German Muscle is offline   Reply With Quote
Old 05-13-2008, 03:28 AM   #278
RcLoCo Online's Avatar
why do you do this?and sill put in stock screws that they call for ?thanx
{Mugen Seiki } { RB Concept }
{ Team Durango { JP Motors }
{K.O. PROPO } {SERPENT 811, FOREVER WAITING ON SERVO FIX!!} Nuff Said!!!!
Last edited by RcLoCo Online; 05-13-2008 at 03:30 AM. Reason: spelling""almost 5am TIRED!!!
RcLoCo Online is offline   Reply With Quote
Old 05-13-2008, 07:11 AM   #279
Rob D's Avatar
Thanks again. Do you realy think tthe picco will be ok. That is what I run now.
Rob D
Old 05-13-2008, 10:45 AM   #280
Lil Paul's Avatar
Its not necessary, but does make things easier. the plastic is not pre-threaded, so your wrist will get a work out when putting the kit together for the first time.
Lil Paul is offline   Reply With Quote
Old 05-13-2008, 10:48 AM   #281
Lil Paul's Avatar
In addition to the stock setup, i run the "cut-arms" mod to shorten the wheelbase, which allows the car to rotate better. This works well on smaller tracks. I also run 1.5 deg of toe out up front for better turn-in, that helps with those pesky hairpins.
Old 05-13-2008, 11:01 AM   #282
Lil Paul's Avatar
make sure you setup with the correct gearing. 301 is freaking huge, and to make matters worse, with the right line you can take the sweeper at the end of straight full blast, so now that 240ft airport runway turns into a 255-260ft runway. Motor is needed, but without correct gearing even the best motor will seem slow. i think most guys are running 17/20, 45,48.
Old 05-13-2008, 11:03 AM   #283
Lil Paul's Avatar
the Picco motors have tons of power, however make sure you can get your hands on their exhaust gaskets, as the port is different, and you will tear up a novarossi shaped gasket after each run. Aside from that, I have seen Piccos with a good tune run past some Nova's.
Old 05-13-2008, 07:09 PM   #284
Rob D's Avatar
Thanks alot. I will let you know how I make out.
Rob D
Old 05-14-2008, 05:26 AM   #285
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default short rear arm mod?
I have seen a couple of setup in which people are running short rear arms.
In looking at the car I am a bit confused how to mod the arms. I notice the wing support has a 3mm spacer to move it forward but I am unsure about changes to the arm.
Does anyone have a pic?
J.Gonzalez is offline   Reply With Quote
