Old 04-03-2008, 04:28 AM   #226
sohlman's Avatar
Trader Rating: 89 (100%+)
Originally Posted by joe hose View Post
What type of glue do you guys use for the brake pads to stick the plates.
I've tried a bunch of glues and Gorilla Glue has been holding the best.
Steve Sohl
sohlman is offline   Reply With Quote
Old 04-03-2008, 07:35 AM   #227
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default Eccentrics?
I am having a difficult time confirming which diff eccentric is which per the instructions. The black and white image in parts sheet is unclear. Looks like a high and low position.
Can anyon post a pic of each and match it to the part numbers?
I would really appreciate it!
Cheers
Jamie
J.Gonzalez is offline   Reply With Quote
Old 04-03-2008, 07:58 AM   #228
Trader Rating: 15 (100%+)
I have been using the 3M rubber contact cement.
THE DOCTOR is offline   Reply With Quote
Old 04-03-2008, 04:39 PM   #229
MugenDrew's Avatar
Trader Rating: 29 (100%+)
I so far am having good luck with 3M weather strip adhesive. It's yellow. Whatever you decide to use be sure to follow the directions. Scuff the mating surfaces of the pad and plate with 200 grit using a figure 8 motion. Clean the mating surfaces with motor spray or anything else that comes in an aerosol can that evaporates very quickly and has a warning label on it stating that the product in the can will kill you etc. Let the parts air dry. Find something that fits the holes of the plates and pads perfectly (shafts of your rc tools). Stick the pads to there perspective plates, align these assemblies pad face to pad face then stick them in a vise. Use light clamping pressure.
Next morning remove them. Remove the excess adhesive from the out-side edges with an x-acto or roto tool. The holes that the pins run threw; you can use a body reamer from the pad side or visit a local tool house and buy a metric drill bit or ream of the exact size.
MAKE SURE you glue the pads rite side up and be SURE that the pad assemblies "float" on there pins.
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 04-03-2008, 07:55 PM   #230
Cheers
Jamie
There are 8 eccentrics in the X-kit. The stock setup wants you to use four eccentric that are thicker in the bottom referencing the pointer being the top portion. I think it is about half to 1 millimeter thicker. The pointer should be pointing up in the back and pointing down in the front.
Sorry no pics.
trebronpay is offline   Reply With Quote
Old 04-04-2008, 10:16 AM   #231
Steve Whats up Can not wait to get back out there! Which Gorilla glue?
joe hose is offline   Reply With Quote
Old 04-04-2008, 10:31 AM   #232
lil-bump's Avatar
Trader Rating: 83 (100%+)
Is it worth it to convert a MRX4 to an MRX4X? Is there a complete kit for the upgrade? cost???
Race you later...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 04-04-2008, 11:05 AM   #233
sohlman's Avatar
Hey Joe, looking forward to getting outdoors too.
Use the original Gorilla Glue: http://www.gorillaglue.com/glues.aspx
Use plenty of glue, let the excess glue spill out. Place the plates with pads in a vice overnight. The next day clean up the glue with a hobby knife and sand the pads down a bit with sandpaper.
Another tip: use one teflon and one black pad for more consistent braking throughout a long main.
Steve Sohl
Old 04-04-2008, 03:47 PM   #234
Woodlands Racer's Avatar
sohlman,
Please explain your recommendation of one black pad and one Teflon pad and the value of such a configuration. Additionally, would it matter which pad is the Teflon one and which is the black pad?
Thanks,
Roger
Roger Bourland
The Woodlands, TX
THIRD COAST RACING
Max Power/RC America - Mike's Hobby Shop - SRC Tires/RC America
Getting Faster With Age, Hope to see many more birthdays!
Woodlands Racer is offline   Reply With Quote
Old 04-04-2008, 04:51 PM   #235
sohlman's Avatar
Originally Posted by Woodlands Racer View Post
sohlman,
Thanks,
Roger
Results depend on driving styles. I drive hard on the gas and hard on the brakes. During longer mains, the two teflon (yellows) will heat up and fade a bit. Won't notice anything in a qual. The black pads have good grip and don't overheat, but also don't last as long. The combo works best for me. And it does not matter which pad goes on which plate.
Steve Sohl
Old 04-04-2008, 05:15 PM   #236
Thanks,
I appreciate the explanation.
Roger
Roger Bourland
The Woodlands, TX
THIRD COAST RACING
Old 04-07-2008, 09:36 AM   #237
asw7576's Avatar
Hi Solhman,
Hi, I would like to ask you about raising the height of front upper arm position by 1mm. Can I expect more steering ?
Secondly, If I increase the height of rear upright's shims from 2mm to 3mm. Can I expect more steering too ?
Thanks.
Edit : my problem is understeering off throttle, especially at mid cornering, the car wont turn at tightly.
Old 04-07-2008, 12:02 PM   #238
sohlman's Avatar
Originally Posted by asw7576 View Post
Hi Solhman,
Thanks.
Yes, raising the front upper arms will give you more off power steering. Raising the shims on the rear uprights will give you more rear side bite...not sure what effects it gives the front end. Try using the 4.5 blocks in the rear to give you more steering. Help this helps.
Steve Sohl
Old 04-07-2008, 07:01 PM   #239
asw7576's Avatar
Thank you.
Old 04-10-2008, 02:18 PM   #240
TC_Tuner's Avatar
Trader Rating: 34 (100%+)
Default MRX 4r > 4x Upgrade kits?
Looking for the upgrade kit to take the Mugen MRX 4r to 4x specs. Please drop me a line if you (or a shop you know of) has one of these available.
I know my chances are slim...but giving it a shot
regards-
Eric
Airtronics | Byron's Fuel | Pro-Line | OS | Kyosho | Ballistic Batteries | Al's Hobby Shop
MRX4-X F180 Cobra Zipper Kart Yokomo BD Cup Racer FM1e Recoil M18 Pro Scalpel dNaNo Baja 5b SS 5T HB D8 Vorza ERevo Savage Flux SCX10 GT2 T4 Slash Ten SCTE Blitz ESE HB Cyclone D4 Mini ERevo Vendetta ST Mini T Micro T
TC_Tuner is offline   Reply With Quote
