Old 11-26-2007, 02:21 PM   #181
chicky03's Avatar
Send a message via AIM to chicky03
Originally Posted by madjack View Post
Anyone care to post their X set-ups or links to info?
Thanks in advance,
john
I have some setups but the files are too big to attach here. PM me your email address and I can send them to anyone who wants them.
Paul
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 11-26-2007, 04:36 PM   #182
Send a message via AIM to munrath
Paul - Congrats in 19T
Tekno RC (RTM) / RadioPost / Tekin / Pro-Match Racing / AKA / PT Racing Oils/Diff Lube
Races for 2015:
PNB, AMS, E-Nats Warm-up, E-Nats, LCRC North East Challenge, RAC, LCRC Halloween, Badlands, ROAR Region 2 Series, and Local Club Racing
munrath is offline   Reply With Quote
Old 11-26-2007, 04:37 PM   #183
Paul - You have PM
Races for 2015:
Old 11-26-2007, 05:10 PM   #184
Default 301 Raceway MRX4-X
Hope this helps. This setup is a combination of several other drivers but modified for my driving style. Easy to drive, the rear end is a little on the loose side depending on traction, so I'll probably go with a little more rear toe or raise the front swaybar a little, since it has plenty of steering.
Front Lower Arm Position = short wheelbase
Hopefully others can post so that we can share the info from track to track.
Mark
Races for 2015:
Old 11-26-2007, 05:43 PM   #185
Boz
Trader Rating: 23 (100%+)
Mark
What tire size are you using?
Boz is offline   Reply With Quote
Old 11-26-2007, 05:59 PM   #186
Normally 69/76 but I've also run 67/74 Depends on the traction and tire wear.
Races for 2015:
Old 11-27-2007, 05:33 PM   #187
madjack's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to madjack
Mark
Thanks much...will be testing this Friday for Toys for Tots this weekend at Crystal Park (weather permitting)
madjack is offline   Reply With Quote
Old 12-01-2007, 01:58 PM   #188
Thumbs up
Is mugen planning on releasing a new car next year or is MRX4X going to be the car to carry over into the next year or two. I am interested in the MRX4X but I will wait if they are going to produce a new car for 2008
antone is offline   Reply With Quote
Old 12-01-2007, 06:11 PM   #189
Trader Rating: 4 (83%+)
i think that the X is going to be the car for a while it just came out ...
Roniel_R is offline   Reply With Quote
Old 12-21-2007, 08:12 AM   #190
madjack's Avatar
Winternats should be a bit more entertaining this year!
http://www.redrc.net/2007/12/mike-sw...ins-jp-racing/
Old 12-21-2007, 09:24 AM   #191
The X will be the only car we have for 2008.
Mike_Swauger is offline   Reply With Quote
Old 01-21-2008, 08:01 PM   #192
madjack's Avatar
MRX4X - Mike Swauger set-up sheet listed in RC Car
http://www.rc-car.com/ME2/dirmod.asp...0942B73EC87393
Old 01-22-2008, 03:58 AM   #193
M7H
M7H's Avatar
Copy Mike's setup and you will be as fast as him....
I don't really understand why people like to copy the setup of the top drivers other then to have a good starting point (and I guess the Mugen has a standard setup to be used as a starting point)
If you don't use the exact same body (which is not mentioned in the setup sheet) the setup might be completely wrong for your body....
Also copying a setup from a driver who drove a race like the winternats, or a WC, is not wise. The grip level on a track increases a lot if drivers run there for a few days in a row, even tractionroll is not uncommon in 1/8th then!!!!
The setup they then have to put in there car, will give you very low grip under "normal" track conditions.... but still people want to copy these setup's......
M7H is offline   Reply With Quote
Old 01-22-2008, 07:03 AM   #194
madjack's Avatar
M7H - To clarify: the set-up posted in RC Car is a base-line for those racers running or that have upgraded to the MRX4X. It is my understanding this is not Mike's exact race set-up for a specific track, but a proven starting point for MRX4X racers to build from.
Question for the all knowing M7H - where would you and your Serpent avatar suggest we look to find a recent and tested set-up for the Mugen MRX4X?
If you can't provide an answer beneficial to Mugen chassis owners, I suggest you try lurking in the "Serpent chassis of the week" thread.
Best regards,
madjack
Old 01-24-2008, 11:56 PM   #195
chookgb's Avatar
Trader Rating: 25 (100%+)
Default black springs
can anyone tell me the part number for the black rear mugen springs
chookgb is offline   Reply With Quote
