Old 03-22-2011, 05:49 PM   #1621
choisan's Avatar
my friend mod on his mrx4x, i call it mrx4.8
choisan is offline   Reply With Quote
Old 03-26-2011, 06:14 AM   #1622
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
Default bunch of mrx4x parts
Mugen Mrx-4x/r Parts lot... CHEAP STUFF ALOT OF GEAR
sorry to plug here, just need them gone...also selling a mrx5 guy looks to be pullin out, check my threads... thanx guys!!!
Thinking on maybe a Tekno 1/8 Nitro Buggy?
TommyBlazin is offline   Reply With Quote
Old 03-28-2011, 12:45 AM   #1623
Hi!
In my last practice I had to replace the one-way because it wasn't pulling in one side. The one-way on the car wasn't from Mugen. It was lightweight one with the alloy pulley included (can't exchange the pulley in it).
Luckily I had one spare (Mugen original) and I was back on the track in minutes.
It is possible to change the one-way bearings or the best to do is buy another one-way shaft with bearings for spare?
Regards!
ratax is offline   Reply With Quote
Old 03-28-2011, 07:09 AM   #1624
YLLIB's Avatar
buy another one. They are hard to change because they are pressed in pretty tight.
YLLIB is offline   Reply With Quote
Old 03-28-2011, 07:32 AM   #1625
Thanks!
Old 03-28-2011, 10:46 AM   #1626
It might not be bad replacing them if you have experience heating the aluminum like you would with a engine bearing, but I would not press it out. The aluminum is soft an may not hold a new bearing tight. I'm not sure you could find the bearings you need though, they are very high quality and close tolerance.
williamw is offline   Reply With Quote
Old 05-07-2011, 12:29 PM   #1627
g-wan's Avatar
Send a message via MSN to g-wan Send a message via Yahoo to g-wan
i just wana share my project due having alot of time on holiday..so my victim mrx3 for the project,just make some conversion kit for it by using mrx4,r,x and 5 part,the rear conversion im using mrx4 x rear upright,lower arm,mrx4 rear body mount,after finish up everything..i notice that the rear width 270mm after setup..so my next part to fit in mrx5 radio plate,front mrx4 or mrx5 conversion..pulley set from mrx5..so will update some picture for it
km k8 / os speed / savox / blitz / contact tyre
km hk1 evo / os speed / savox / sweep
sworkz evo / spower evo s7 / sweep / savox
xray t3 2012 / tekin rs pro / reedy / savox
km racing / sworkz / xray / savox / sanwa / os speed / sweep / ulti / blitz
g-wan is offline   Reply With Quote
Old 05-07-2011, 10:54 PM   #1628
asw7576's Avatar
Hey there,
How do you end up with 270mm rear track width ?
( I wish I could get 264-265mm rear track width in my mrx4 without exposing too many threads in the lower arms ).
( I wonder if MRX5 lower rear arms are wider than MRX4 ? )
Old 05-07-2011, 10:57 PM   #1629
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
i was thinking the same...are your rear driveshafts not coming out
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
Old 05-08-2011, 03:04 AM   #1630
g-wan's Avatar
Originally Posted by asw7576 View Post
Hey there,
its just for fun doing it..the base im using mrx3 kit,the rear conversion only mrx4x,i notice the rear abit wide..so im thinking of getting 262-265 rear,but rear upright from mrx4 is abit wide from mrx3 rear upright...
and for the rear driveshaft im using from mrx4...since mrx3 driveshaft abit short..but since have alot of time to do..will try out the mrx4 conversion to mrx5..
sorry if the picture abit dark and not detail..will upload some picture after finish up everything
Old 05-08-2011, 09:46 AM   #1631
CanyonCarverR1's Avatar
Default Great Deal on MRX4X
Shameless plug for a screamming deal on a very fresh MRX4X
MRX4X w/JP engine, spares, and Aritronics servos
CanyonCarverR1 is offline   Reply With Quote
Old 05-08-2011, 09:58 AM   #1632
asw7576's Avatar
Whoaaa .......... I'll remember that.
Old 05-08-2011, 10:10 AM   #1633
asw7576's Avatar
Ok thanks,
Meanwhile in my freetime, I will bring my spare mrx4r lower rear arms to LHS, and compare it with lower arms of mrx5, rx8, 966. Hopefully I can find longer lower arms with similar shape.
Old 05-08-2011, 08:47 PM   #1634
g-wan's Avatar
some pic of it after finish..
Old 06-25-2011, 10:10 PM   #1635
asw7576's Avatar
I'm looking for longer pivot balls for wider track width for MRX4.
I find Mugen Seiki original pivot balls are too short for my taste.
I want to have more screw threads inserted into the suspension lower arms while getting wider track width too. For examples : I can't get 265mm rear track width and 3 degree rear toe in with MRX4's original pivot balls.
Will arrowmax-rc.com make special longer pivot balls ?
rc market, do you have access to notify arrowmax-rc to create the longer version ? ..... perhaps 6mm longer version, in 1 pair packaging. Thanks bro.
