Old 12-03-2010, 10:36 AM   #1591
Do the Kyosho rear body uprights fit the MRX-4X without mods? Are the rear hubs needed?
williamw is offline   Reply With Quote
Old 12-03-2010, 11:23 AM   #1592
g-wan's Avatar
Send a message via MSN to g-wan Send a message via Yahoo to g-wan
But not the width of the wheels and so the distance between both uprights.
My gues is that it would fit but there is a chance that some small modifications are needed
well may be i should try with mrx4 rear arm 1st,then if it too wide,then will going back to mrx3,will update the result when i got my rear end conversion tomorow
km k8 / os speed / savox / blitz / contact tyre
km hk1 evo / os speed / savox / sweep
sworkz evo / spower evo s7 / sweep / savox
xray t3 2012 / tekin rs pro / reedy / savox
km racing / sworkz / xray / savox / sanwa / os speed / sweep / ulti / blitz
g-wan is offline   Reply With Quote
Old 12-03-2010, 04:38 PM   #1593
Grenade10's Avatar
Trader Rating: 37 (100%+)
The Kyosho will fit with just a little clearance work. Gets the back of the body up for a little more rear down force. If you also drop the front it gets the Proto Form 909 very well balanced.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 12-03-2010, 04:59 PM   #1594
rpoage's Avatar
The way you get the higher body supports is with the Kyosho hub set (FM602) but I believe you use the Kyosho body supports with the Mugen hubs
Ashford Hobby/FM602
rpoage is offline   Reply With Quote
Old 12-03-2010, 05:50 PM   #1595
wingracer's Avatar
Trader Rating: 22 (100%+)
Yes, you still need to use the Mugen hubs, not the Kyosho ones. You only use the Kyosho H arms to mount the body mount to the hubs. They do require a little work to make them fit but it's not hard.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 12-06-2010, 05:09 AM   #1596
MugenDrew's Avatar
Trader Rating: 28 (100%+)
Order a H0466-C. Yes its for the 5 but is usable on all of the 4s and has the parts you need to crank the body up with no mods. Don't stop there, the 5 front bumper is the bomb and so are the body post. Other parts from the 5 that fit, front body post, front upper arm and up-rite, rear radio plate mount, rear lower arms and up-rites and probabley some other stuff I can't remember. I'm in the process of cutting a 4 radio plate and chassis to except the floating deck parts from the 5 as well as the servo/recevier gimmik.
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 12-06-2010, 07:25 AM   #1597
Grenade10's Avatar
Very good info to know, THANKS!!
Let us know how the floating parts work on the 4X as well.
Old 12-06-2010, 07:57 AM   #1598
Thanks for the info!
Can you please post these part numbers?
Regards!
ratax is offline   Reply With Quote
Old 12-06-2010, 09:54 AM   #1599
MugenDrew's Avatar
Go to mugenseiki.com, click on "products", then click on mrx-5, then finally click on parts list. There are pictures and part numbers. The manuals are also there so you can see how the 5 goes together. Do keep in mind the 5 suspension parts are quite a bit lighter = not the brick --it house that the four stuff is.
Old 12-09-2010, 11:14 AM   #1600
Hi!
Can anyone please post some photos of the NT1 receiver box installed on MRX4-X? I want to make sure where must I drill the holes.
Regards!
Old 12-10-2010, 12:03 AM   #1601
Wanabrc's Avatar
Trader Rating: 70 (100%+)
Maybe you should start a thread on how your modding your 4X with some track results??
Wanabrc is offline   Reply With Quote
Old 12-12-2010, 09:13 AM   #1602
asw7576's Avatar
hi, can anyone gives me ideas how to make the rear end of car very stable. ie. no fishtailing, no hooking.
( i suspect my protoform shadow body is the culprit )
lightweight body vs regular weight body ? which one is more stable?
Old 12-12-2010, 10:57 AM   #1603
MugenDrew's Avatar
Burn the Shadow. Go to the 4.5mm roll center blocks, use MRX-4-R rear up-rites, R rear upper arms in the long position, 3mm sway bar full soft and no spacers under the upper arms outer piviot ball. 35 or 32 shore all the way around the car. Thats as stuck as it gets. Still doing it check front belt. If the belt looks good look at the side belt. If you need to crank a bunch of rear toe in it, I would fix your throttle finger first, then back off the clutch and last but not least find a race track to run it on...
Old 12-12-2010, 11:37 PM   #1604
asw7576's Avatar
okie dokie,
that's good stuffs, thank you.
Old 12-14-2010, 06:00 AM   #1605
MugenDrew's Avatar
I finally had the time to sit down and look at the radio tray deal and it is not going to happen. Buy the time you got dun modifying the 4 deck to accept the sliding bracket there would be no radio deck left behind the tank. The five servo mount wont fit because the rear end of the throttle servo (Airtronics 94931) protrudes into the opening. It might work, maybe with a low profile servo, maybe.
Now if somebody had the time, tools and interest to make a "new" radio deck...this is where a Roelof or a Lucas would come in real handy.
