Old 06-05-2010, 11:05 PM   #1546
Originally Posted by MugenDrew View Post
Make sure you have the larger pulley for the side belt on the front lay shaft.
I'll double check, but pretty sure it's correct.
williamw is offline   Reply With Quote
Old 06-06-2010, 03:46 AM   #1547
Roelof's Avatar
Send a message via ICQ to Roelof
Originally Posted by williamw View Post
Its a new car, never run.
Just run the car, all will become loose.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 06-06-2010, 11:09 AM   #1548
Cool
I realize that, but was suprised how stiff the belt is. Of course it's probably much more durable, I have not had an 1/8 scale car in almost 10 years.
Thanks for all the feedback.
Old 06-06-2010, 11:17 AM   #1549
Roelof's Avatar
Be sure the tensioner is not set to tight!
Old 06-07-2010, 04:46 PM   #1550
DanielC.'s Avatar
Trader Rating: 56 (100%+)
MRX4-X w/ plenty of extras for sale.
DanielC. is offline   Reply With Quote
Old 06-17-2010, 10:38 AM   #1551
mugenize1's Avatar
Can someone please help me find Part # HO373 it has theRX mount,battery and the on and off switch holder the holder is what I am looking for I am plugging the battery into the RX and I do not want to do that anymore and I can not find mine.
THANKS GUYS,
mugenize1 is offline   Reply With Quote
Old 06-17-2010, 11:49 AM   #1552
Roelof's Avatar
I just use a 10cm servo extension cable which I leave in the receiver and the oter end I use to connect and disconnect the battery. In the past I have used switches and I only have dad experiences with them
Old 06-17-2010, 04:17 PM   #1553
mugenize1's Avatar
WOW! Did not think of that one that works for me. I did not want to put the switch on it but I also did not want to distroy the RX pluging and unpluging the battery.
Old 06-17-2010, 06:40 PM   #1554
wingracer's Avatar
Trader Rating: 22 (100%+)
I use a short servo extension but I cut off the battery end and replace it with a mini deans. Then just put a mini deans on the battery.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 06-17-2010, 06:44 PM   #1555
Trader Rating: 21 (100%+)
Damn Sean, thats a good idea. Ive had problems with extensions coming loose.
VA_Racer is offline   Reply With Quote
Old 06-17-2010, 06:45 PM   #1556
helivaguy's Avatar
Trader Rating: 42 (100%+)
i like that
helivaguy is offline   Reply With Quote
Old 06-17-2010, 06:50 PM   #1557
wingracer's Avatar
Originally Posted by helivaguy View Post
i like that
Yeah I've been a switch guy for years with no problems but the new car just doesn't have a spot for it and regular servo plugs just don't hold up for me. The mini deans seems to be the perfect answer.
Team Shepherd USA
Old 06-18-2010, 05:15 AM   #1558
mugenize1's Avatar
That is a good idea I like that going to try it this weekend
thanks for the help guys.
Old 06-18-2010, 07:12 AM   #1559
helivaguy's Avatar
i did mine also..didnt know why i never did this sooner coming from a guy who flies nitro heli's,thanks for the tip wingracer
also dont forget to add the mini deans to your rx charger.
Old 06-18-2010, 08:34 AM   #1560
mugenize1's Avatar
I forgot about that one I also can make an addapter to fit the charger so I don't have to change it. and I will be able to charge my other batterys.
