Old 03-25-2010, 07:34 AM   #1516
MugenDrew's Avatar
Trader Rating: 24 (100%+)
T0312. I cover the back of the receiver with "both sides tape" and use the shaft of Hudy tool (3mm dia.) to space the receiver off of the ledge at the bottom of the receiver mount. This ends up giving you a nice track to put the extra wire in. It looked alot cleaner when I was running spectrum pro. This new Airtronics fhss-3 stuff is the bomb, so I can deal with the routing not being exactly like I would like...
MUGEN SEIKI NOVA ROSSI ENETTI TYRES HUDY PROFESSIONAL TOOLS
BYRONS FUEL AIRTRONICS RADIO EQUIPMENT PROTOFORM RACE BODIES
MUGEN RACING RC AMERICA AKA RACING NUGGETS RACING DESOTO RACING
MugenDrew is offline   Reply With Quote
Old 03-27-2010, 12:59 AM   #1517
lavaandy's Avatar
anyone ever try a carbon brake disk?
Team Timezone www.Timezoneracing.com Team CRC, Mukune designs
lavaandy is offline   Reply With Quote
Old 03-27-2010, 01:06 AM   #1518
Roelof's Avatar
Send a message via ICQ to Roelof
In a far past on steel brakepads.... It works but you have to learn it. When heating up it will give more brakepower so when hitting the brake in the beginning there is not mucht and a moment later it will come in.
In the past we had good experience with epoxy/glasfiber disks on steel plates. Currently I the Motonica disk, I have to mount it to give it a try.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 03-31-2010, 09:33 PM   #1519
Suspended
ended up jus using zip ties, its not as bad as it looks. this is after race day lol
Jusleanit is offline   Reply With Quote
Old 04-23-2010, 12:07 PM   #1520
SMcpot's Avatar
Trader Rating: 22 (100%+)
Questions??
How easy is it to get parts for Mugen cars that are obsolete? I'm looking at a 4X, but with the 5X coming out soon, how long should I realistically expect to be able to get parts for this car?
SMcpot is offline   Reply With Quote
Old 04-23-2010, 01:13 PM   #1521
Team Kamikaze's Avatar
Should be good for at least another 2 years (minimum)
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 04-23-2010, 02:04 PM   #1522
MugenDrew's Avatar
5 years. At the end of that or if MugenRacing runs out of stock before that (slow moving part) it can be ordered from Japan. Adds about 2-3 weeks, from the order date to when you get it.
Old 04-23-2010, 03:12 PM   #1523
SMcpot's Avatar
Thumbs up
Sweet...thanks for the replies.
Old 04-23-2010, 06:41 PM   #1524
wingracer's Avatar
If you look around, you can still find MRX-3 parts. You should be fine for at least another season or two and probably long after that.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 04-24-2010, 12:40 AM   #1525
Roelof's Avatar
And if you take a search on Ebay you will always find an older car you can strip for the parts.
Old 04-24-2010, 10:37 AM   #1526
Trader Rating: 17 (100%+)
He's talking about mine. I just built a new MRX4X and decided I will run the 5 this year. It has never been run yet and trying to get $425 shipped out of it. It's a great deal. I'm just looking to move it.
I agree, parts should not be an issue for a long time. Mugen parts do seem to be everywhere, and they also don't put out a new car every year!
seabass2500 is offline   Reply With Quote
Old 04-26-2010, 08:56 PM   #1527
MrSlow's Avatar
is there an easy way to tell between an MRX 4R VS 4X?
i recently bought a few used 4X kits and not certain if they are the same. One car has slightly different front upper arms but i know this is not part of the changes that were made. thanks!
jason
MrSlow is offline   Reply With Quote
Old 04-27-2010, 06:53 AM   #1528
wingracer's Avatar
jason
4R has longer rear shocks, lower front shock tower. 4X has a shorter brake arm, shims on the axles, etc.
Quickest way is to look at the chassis. The receiver pack trays are different.
Team Shepherd USA
Old 04-27-2010, 07:50 AM   #1529
Roelof's Avatar
The battery tray is different, the 4X has a screw comming out into the short middle schaft mount.
The 4X excentrics in front and rear for tensioning the belt has 2 notches, it can be turned 180 degrees for placing the shaft high or low.
Old 04-28-2010, 11:09 PM   #1530
Suspended
Mugen box?
wut batts are most ppl using for the mugen box? (Pro II)
SEO by vBSEO 3.5.0
