Show Off Your Nitro Touring Car !!
#76
what?? No Impulse pictures? here is one
#80
Re: OFNA OB4 PRO
Originally posted by cybertoolzz
matrix stylee!!
matrix stylee!!
graphite upper deck, front & rear shock towers
graphite vented disk brake
CNC front and rear main blocks
CNC Y-brace
front cvd's - rear dog bones
geared front & rear diiffs
3mm HC stock chassis
TRANSMISSION
Mugen centax 4 shoe clutch
15/45 1st gear 7:1 (yokomo 15t pinion/ofna 45t spur)
19/41 2nd gear 5.0350:1 (mugen 19t pinion/ofna 41t spur)
Ofna stock finger-type 2-speed
MOTOR
STS RS3 .12 turbo - hand modified 3 port turbo - #8 turbo plug - SG turbo crank - 5.5mm slide carb - 4mm head shims (1x.3mm & 1x.1mm)
RD Logics one-piece pipe/header - normal
Motor Saver air filter with GS blue elbow for ram-air effect
RADIO
JR xr3i
JR Z590M bb metal gear steering - JR Z270 throttle servos - JR rx
1000maH NiMh rx battery
Venom fail-safe
antenna routed to rear next to motor - wire cased in blue shink-wrap
SUSPENSION
Ofna ob4 stock shocks - 60wt front - 45wt rear -
Ofna stock (soft) black rear springs - ofna white (med) front springs
GS rear tie rods - orange
no rear sway bar - front sway bar flat
OTHER
Speedmind 26/40 front - 30/40 rear
Traxxas front bumper - shaped and drilled to move front body posts forward
(in case nrbody is interested...)
#81
some really beautiful cars here...
here's a few more
here's a few more
#82
tranny - gawd, i wish it wasn't raining - always fn rain...
#83
here is mine hpi super nitro
#84
how did u do those matrix letters?
#87
then, using an old technique called 'stenciling' - i used a thin sheet of clear plastic - i placed the clear stencil plastic over my printout and cutout three lines of the vertical matrix code - took a while and very painstaking work with a sharp xacto. i now have 3 stencils of the vertical matrix code eack about a 1/2" wide and 4" long.
next, i positioned one of the stencil strips on the underside of the body and masked off the area. using fascolor paint, i sprayed the green to white fade and removed the masking and stencil. did that for each line of the code on the body.
the matrix code on the body is NOT a decal! it is sprayed on from the underside. i think it came out very nice.
#88
#89
Originally posted by RClover
sorry to say dude, yours is outdated already...
#90
Originally posted by td-civ
i think im going to buy this the new trinity g4
