Old 04-29-2003, 05:46 AM   #1
Send a message via AIM to tdragon
Default piston
how would u know if a piston n sleeve is going in an hpi 15 fe engine
tdragon is offline   Reply With Quote
Old 04-29-2003, 04:17 PM   #2
Turn the flywheel, you should feel resitance when you get close to top dead center. You could also disassemble the engine. Try to push the piston through the sleave (light presure). if the piston goes up thru the sleave the engine is toast. Finally get a compression gauge. Your engine should have about 30 lb of compression. If it is down to about 20 lb your engine is toast. When you install the compression gauge on the engine pull the pull start about 5 or 6 times.
nitro dipstick is offline   Reply With Quote
I need a piston for an evo .21 nitroburner65 R/C Items: Wanted to Buy 2 07-06-2008 10:06 AM
piston at BDC??????????? nemix Rookie Zone 1 07-29-2007 06:07 AM
WTB USED RB WS7-2 PISTON kwilke R/C Items: Wanted to Buy 0 03-22-2007 09:11 AM
Light Oil & Small Piston Hole vs. Heavy Oil & Large Piston Hole Rich Panganiban Nitro On-Road 2 01-26-2006 03:24 AM
where to get a piston set for a ek4 2mcgrath Monster Trucks 0 03-17-2004 08:15 PM
SEO by vBSEO 3.5.0
